Author Topic: cbx viwer for peppermint 10  (Read 504 times)
Offline harperbass
  • New To PeppermintOS
« on: July 27, 2020, 03:02:31 pm »
Can't get any comix viewer to work/install. Peppermint 10. MComix 1.2.1 highly reccomended but after downloading won't install.... but can't figure to get it to work. That regular .cbx file.
Regards
Rick
Re: cbx viwer for peppermint 10
« Reply #1 on: July 29, 2020, 03:39:29 pm »
Hi harperbass, how did you install it?
Offline m1k3
  • Peppermint version(s): Ten
« Reply #2 on: July 29, 2020, 05:55:36 pm »
If you add this PPA you can install it with apt/synaptic.
sudo add-apt-repository ppa:nilarimogard/webupd8
sudo apt update
sudo apt install mcomix
