Author Topic: Lost ethernet connection after laptop returns from sleep  (Read 1481 times)
Offline hoeky
« on: July 23, 2020, 11:09:06 am »
When my laptop goes into suspend/sleep mode and then wakes up, the ethernet connection does not reconnect. I find I have to reboot to restore it. Any ideas?
System:    Host: xxxxxx Kernel: 5.4.0-42-generic x86_64 bits: 64 Desktop: N/A
           Distro: Peppermint Ten
Machine:   Device: laptop System: SAMSUNG product: N150/N210/N220 serial: N/A
           Mobo: SAMSUNG model: N150/N210/N220 serial: N/A
           BIOS: Phoenix v: 05JI.M039.20100109.JIP date: 01/09/2010
Battery    BAT1: charge: 30.1 Wh 65.0% condition: 46.3/66.7 Wh (69%)
CPU:       Single core Intel Atom N450 (-MT-) cache: 512 KB
           clock speeds: max: 1667 MHz 1: 1299 MHz 2: 1221 MHz
Graphics:  Card: Intel Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller
           Display Server: x11 (X.Org 1.20.8 )
           drivers: intel (unloaded: modesetting,fbdev,vesa)
           Resolution: 1024x600@60.01hz
           OpenGL: renderer: Mesa DRI Intel Pineview M version: 1.4 Mesa 20.0.8
Audio:     Card Intel NM10/ICH7 Family High Def. Audio Controller
           Sound: Advanced Linux Sound Architecture v: k5.4.0-42-generic
Network:   Card-1: Realtek RTL8192E/RTL8192SE Wireless LAN Controller
           driver: rtl819xE
           IF: enp5s0 state: down mac: <filter>
           Card-2: Marvell 88E8040 PCI-E Fast Ethernet Controller driver: sky2
           IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 250.1GB (3.7% used)
           ID-1: /dev/sda model: SAMSUNG_HM250HI size: 250.1GB
Partition: ID-1: / size: 229G used: 8.8G (5%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 54.0C mobo: N/A
Info:      Processes: 171 Uptime: 45 min Memory: 621.2/1977.3MB
Re: Lost ethernet connection after laptop returns from sleep
« Reply #1 on: July 24, 2020, 02:44:12 am »
Hi hoeky,
Please read these instructions and provide the requested information in your next post.  ;)
Offline hoeky
« Reply #2 on: July 24, 2020, 03:02:08 am »
Hi Slim
This is not a wireless issue, but with a wired ethernet. Do you have a similar set of commands related to wired ethernet?
« Reply #3 on: July 24, 2020, 03:12:01 am »
Hi hoeky,
Sorry about that -- my bad. Unfortunately I am not a network guru by any means. I was hoping that someone out there would see this info and jump in with a solution for your issue. Sorry, but I do not know what sort of cammands will provide info for your ethernet problems.  :(
Hopefully, someone who is a network guru will see this thread and help you.
Offline hoeky
« Reply #4 on: July 24, 2020, 03:34:52 am »
Thanks Slim
I have trawled the forum and found this post
https://forum.peppermintos.com/index.php/topic,8468.0.html
I will have a go and see if it can help.  :)
« Reply #5 on: July 24, 2020, 03:37:52 am »
OK, good luck and let us know how it turns out.  ;)
Offline invisible
  • Peppermint & Ubuntu
« Reply #6 on: July 25, 2020, 09:32:46 am »
I hope that this suggestion may help.
sudo lshw -C network
Find the following line under Ethernet interface
logical name: eno1 (eno1 is my output, your logical name may well be different)
Then try these commands
To turn off ethernet
sudo ip link set down eno1
To turn on ethernet
sudo ip link set up eno1
Don't forget to change eno1 to your own ethernet logical name from the output of the first command.
Offline hoeky
« Reply #7 on: July 27, 2020, 03:19:42 am »
Tried changing to MATE power manager as described in the linked post above - no change.
invisible, will try your suggestion which will turn ethernet back on, but I'm really trying to get it to turn automatically on resume.  ;)
