Author Topic: Update PM X to PM X respin  (Read 422 times)
Offline LordKaan
  • Peppermint version(s): 6 and 10respin
« on: June 29, 2020, 10:46:00 am »
Hi;
I made sudo update/upgrade, i also do it from the taskbar;
so system should be "actual"
But i miss p.e. Settings -> xfce-> the PM 6 setting
(I duno if there are other differences)
How do i update this (pls. explain for a noob, cause i am one);
or is it better, to make a full new install (No datas on PM Partition, so it would be the cheapest way)
thx
Re: Update PM X to PM X respin
« Reply #1 on: July 04, 2020, 01:25:45 pm »
Hi LordKaan, I think you are asking how to upgrade P10 to P10 Respin, is that correct? If so, see
this post.
As you had metioned, a fresh install of P10 Respin may be easier and quicker. Good luck.
