Author Topic: Trekstore surftab - how to rotate display [solved]  (Read 561 times)
Offline LordKaan
  • Peppermint version(s): 6 and 10respin
« on: June 14, 2020, 07:16:41 pm »
System:    Host: Surftab-twin-10-1 Kernel: 5.3.0-59-generic x86_64 bits: 64
Machine:   Device: un-determined System: TREKSTOR product: Surftab twin 10.1 serial: N/A
           Mobo: TS_EMDOOR model: Geminilake_CN4_V01 serial: N/A
           UEFI: American Megatrends v: DHCN4SW01_V1.1.7 date: 10/31/2019
Battery    BAT0: charge: 97.3 Wh 55.0% condition: 177.0/177.0 Wh (100%)
CPU:       Dual core Intel Celeron N4000 (-MCP-) cache: 4096 KB
           clock speeds: max: 2600 MHz 1: 1663 MHz 2: 1359 MHz
Graphics:  Card: Intel UHD Graphics 605
           Display Server: x11 (X.Org 1.20.5 )
           Resolution: 800x1280@60.00hz
           OpenGL: renderer: Mesa DRI Intel UHD Graphics 600 (Geminilake 2x6)
           version: 4.5 Mesa 19.2.8
Audio:     Card Intel Device 3198 driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k5.3.0-59-generic
Network:   Card: Intel Wireless 3165 driver: iwlwifi
           IF: wlp1s0 state: up mac: 50:eb:71:bb:f2:74
Drives:    HDD Total Size: NA (-)
           ID-1: /dev/mmcblk0 model: N/A size: 61.9GB
Partition: ID-1: / size: 32G used: 6.9G (24%) fs: ext4 dev: /dev/mmcblk0p5
Sensors:   System Temperatures: cpu: 55.0C mobo: N/A
Info:      Processes: 183 Uptime: 12 min Memory: 723.2/3757.4MB
I run this Surf-Tablet in Dual-Boot
Win 10 and Peppermint;
After installing PM X
the (grub)StartScreen is rotated 90 degrees, also while loading
and at Desktop (i changed manually at settings) i have the normal picture
It seems that this computer is wired by Linux (cause gyroskop)
I made the instalation on normal desktop;just to proof;
that booth OS work on this unit
Anyone any idea?
(Pls. solution step by step,cause i am not to use inside all this sudo stuff; THX)
« Last Edit: June 15, 2020, 02:32:57 pm by LordKaan »
Offline LordKaan
Re: Trekstore surftab - how to rotatedisplay @ 90 degees
« Reply #1 on: June 14, 2020, 07:29:51 pm »
I cant reply to this thread
Offline LordKaan
« Reply #2 on: June 14, 2020, 07:30:26 pm »
Edit 1:
At Start-Screen (Grub) i just have a weired mix /wrong grafik;
seems he is confuse with the letters; so i just can switch by knowing, which is the next option
Offline LordKaan
« Reply #3 on: June 14, 2020, 07:31:47 pm »
Edit2: After shuting down (Menu-button) the next time, when i want restart under PM X
he came to the "start"-bar (animated) and immidently, he wrote: Shutting down (and switch off)
I never had this before
What s that
Offline LordKaan
« Reply #4 on: June 14, 2020, 07:32:51 pm »
to admin - it seems, i had the answer problems, when inside the text is an "single" apostroph
like it should in "i haven t" be
« Reply #5 on: June 15, 2020, 01:02:38 am »
That you were able to get Peppermint running in Tablet mode at all is a bit astonishing Lord Khan. We have never optimized any of our releases for tablets... at least not to my knowledge... let me get the attention of and refer one of our devs...
 :o
« Last Edit: June 15, 2020, 01:17:51 am by spence »
& '18 Asus VivoBook
Offline pizzalovingnerd
  • Developer
  • CS:GO Addict
    • My Website
- PizzaLovingNerd
Offline LordKaan
« Reply #7 on: June 15, 2020, 10:17:56 am »
Try something like this (the second answer)
https://askubuntu.com/questions/237963/how-do-i-rotate-my-display-when-not-using-an-x-server
Thx;
I will try this this eve
Edit: Modify as recommanded
Result: Semi-Helpfull (but at least it work 4 the moment)
As i could see, after changing line CMD-Line Linux "silent" i could see,
what he is loading;
with the rotate he make this correct; i had to reset on desktop/manually again  rotate right
Now only the Starting (this bar, which fill it slf) is wrong, but this isn t that important
So, thanx for the moment for this link
« Last Edit: June 15, 2020, 12:34:11 pm by LordKaan »
Offline LordKaan
« Reply #8 on: June 15, 2020, 10:27:43 am »
 :o
Tablet-Modus...
I haven t been in absolut tablet-modus (without keyboard) yet (I have few devices here-see other topic)
With keyboard it is just a normal "N4000"-Unit (with mmc) - giving me a lot of troubles, when u switch something inside Bios/UEFI (incl. totaly off of the device - so never touch by this computer the bios)
So i started at Win 10 -> Restart in UEFI -> Switch start device (and only this !!!!!!) and i could start (from usb-Port at keyboard) PM X (Live System) and install
And beside the few probs -which i asked- it run fine;
and this device should only replace an old N3500 Device (no moving, no nothing - just getting Datas)
and it is cheap (200€) and do not use much energie.
In case u are interesed, i can report, if the features of "Tablet-Modus" (Gyroscope etc.) work
When u say: PM was never made 4 tablet modus; i am not surprised, that i get now answer for the virtual keyboard (on the display) - this i allready saw at other Devices, like Raspberry PI (Debian)
But TabletModus is not my priority - nice, when it would work; if not.. it s okay too
Edit:
I had to set up new the device, cause it switch off permanently;
while this i tryed few things -cause i made the settings above-
Touchscreen ist not available
After swapping (took key board on/off from device - keyboard is locked
Gyroscope (changing the view of angle) is not working
So... it s nothing else, than a cheap netbook - only 12 years later
(The Acer Spin1 react a little bit other; i will give u a feedback too; in case u want)
Edit 2:
I wouldn t recomand to use this device for linux
cause there are a lot of trouble, p.e he always went into the shutdown menu - and i have no glue,
why this happend ; I guess it have to do with the updates, or the battery -evenwhen it is full loaded,
or with the shutdown-order - sometimes it works, sometimes not; but always reboot, went  into win10 and shut down from there... isnt usefull
Other linux Distris wouldnt start; but there are the same rotate problrm
so it seems: This device is just cheap - nothing else
THX for all helps
« Last Edit: June 15, 2020, 02:34:42 pm by LordKaan »
