Author Topic: Weather Conditions Using INXI  (Read 446 times)
« on: May 27, 2020, 12:24:18 am »
Well I'll be damned   :o
I was fooling around tonight, trying to figure out how to use Inxi to scrape weather conditions for Conky.
Reading the Man, I knew Inxi was capable of displaying weather conditions, but I was missing a piece of the puzzle.
Finally figured it out, and the pieces fell into place.   ;D
Code: (EXAMPLE) [Select]
╭─vindsl@Boogaloo-6 ~
╰─$ inxi -wxxx -W tucson,az
Weather:
  Temperature: 25.2 C (77 F) Conditions: Clear sky
  Wind: from WSW at 0.5 m/s (2 km/h, 1 mph) Cloud Cover: 0% Humidity: 15%
  Dew Point: -3.3 C (26 F) Pressure: 930.2 mb (31 in) Location: Tucson, Az
  Current Time: Wed 27 May 2020 12:12:26 AM MST
  Observation Time: 2020-05-26 23:47:00 (America/Phoenix -0700)
  Source: WeatherBit.io
Now I just need to haxor an algo to scrape the data for Conky...
Re: Weather Conditions Using INXI
« Reply #1 on: May 27, 2020, 12:52:12 am »
Hi VinDSL,
Here's what I get:
Weather:   Weather data failure: Wed May 27 09:35:05 CEST 2020
           Error: weather info downloaded but no data detected.
Maybe they're on a coffee break ...  ;D
« Reply #2 on: May 27, 2020, 01:32:44 am »
Right. You haven't discovered the 'missing link' yet.   :)
Here's the trick...
Edit and save your '/etc/inxi.conf' file, so it reads like this:
## We want to use the distro to track the package
B_ALLOW_UPDATE=true
To test it, when you're done, run this command from CLI:
cat /etc/inxi.confYour should see something like this:
╰─$ cat /etc/inxi.conf
B_ALLOW_UPDATE=true
Then, update Inxi by running this command from CLI:
$ sudo inxi -U This is what I see on my machine:
╰─$ sudo inxi -U
[sudo] password for vindsl:
Starting inxi self updater.
Using tiny as downloader.
Currently running inxi version number: 3.1.00
Current version patch number: 00
Current version release date: 2020-04-22
Updating inxi in /usr/bin using main branch as download source...
Successfully updated to main branch version: 3.1.00
New main branch version patch number: 00
New main branch version release date: 2020-04-22
To run the new version, just start inxi again.
Starting download of man page file now.
Downloading Man page file...
Download successful. Compressing file...
Download and install of man page successful.
Check to make sure it works: man inxi
Finally, try it again:
╰─$ inxi -w -W flagtaff,az
Weather:
  Temperature: 9.4 C (49 F) Conditions: Clear sky
  Current Time: Wed 27 May 2020 01:28:14 AM MST Source: WeatherBit.io
« Last Edit: May 27, 2020, 01:40:35 am by VinDSL »
« Reply #3 on: May 27, 2020, 01:48:38 am »
Hi VinDSL,
Got it:
Weather:
  Temperature: 23.2 C (74 F) Conditions: Clear sky
  Wind: from ESE at 0.5 m/s (2 km/h, 1 mph) Cloud Cover: 0% Humidity: 18%
  Dew Point: -2.3 C (28 F) Pressure: 929.6 mb (31 in) Location: Tucson, Az
  Current Time: Mi 27 Mai 2020 01:46:45 MST
  Observation Time: 2020-05-27 01:17:00 (America/Phoenix -0700)
Thank you !!  8)
« Reply #4 on: May 27, 2020, 01:55:17 am »
BTW, this boosts the Inxi ver from 2.3.56-1  => 3.1.00-00   ;)
« Reply #5 on: May 27, 2020, 02:08:31 am »
Heh! Inxi found and correctly identified my Plantronics Voyager Legend headset now   ;D
INXI 3.1.00-00
