Author Topic: square brackets  (Read 1043 times)
Offline clatterfordslim
Re: square brackets
« Reply #15 on: June 02, 2020, 06:15:43 am »
I don't know about your machine but on mine, the square brackets indicate windows that have been minimized.  To get rid of the brackets, just restore the window.
hth.
Bruce
Thanks. Knew that too ;) But I don't want them to show at all. Is that possible?
I don't think it is possible Johan, I will see if there is a way of changing it in the script to window buttons. Bare with me I'll be back.
But so is this Forum :)
Re: square brackets
« Reply #16 on: June 02, 2020, 06:59:34 am »
Unfortunately there is nothing that can be done, it seems it is setup to this as default and the only way to not have the brackets at all is either have icons only, or only show minimized windows only, but that still does not get rid of the brackets.  :-\ Puzzled I be.
Offline Johan
Re: square brackets
« Reply #17 on: June 05, 2020, 12:39:52 pm »
It's okay Slim thanks ;)
