Author Topic: Download Faenza Icon Theme  (Read 1589 times)
Offline Dee Bee
  • New To PeppermintOS
« on: May 01, 2020, 06:16:31 am »
Can the Faenza Icon theme be added to Peppermint 10?   Is so I need guidance, please.
Offline rayzer
  • Graphics n Stuff
Re: Download Faenza Icon Theme
« Reply #1 on: May 01, 2020, 11:19:11 am »
copy this into your terminal
sudo apt install faenza-icon-theme
then open Customize Look & Feel from the main menu once installed
Offline Dee Bee
« Reply #2 on: May 02, 2020, 02:20:48 pm »
Rayzar
Thanks  OK  I used sudo command.  The selection does not show up in the pull down menu of the "Customize look and feel"  Any ideas.
Hopeful,
Dee
Offline rayzer
  • Graphics n Stuff
« Reply #3 on: May 02, 2020, 04:18:58 pm »
when you open customize look and feel you need to click on the icons tab, then on the faenza in the list (both ive highlighted yellow) then hit apply on the bottom right. hopefully that works for you
Offline fires
  • Peppermint version(s): Peppermint 10 Ten x86_64//5.3.
« Reply #4 on: June 06, 2020, 04:11:45 am »
and @rayzer
many thanks  this is much easier for me
thank u
Peppermint 10 Ten x86_64//5.3.0-53-generic
Offline LordKaan
  • Peppermint version(s): 6 and 10respin
« Reply #5 on: June 12, 2020, 05:45:15 am »
Hey Rayzer;
(sorry for double posting; cause i ask in the other thread too)
Is there, and how...
a way to do THIS (pls. also step by step)
sudo wget https://peppermintos.info/misc/PM6-Peppermix-Icons.tar.gz
sudo tar xvf PM6-Peppermix-Icons.tar.gz
sudo rm -v PM6-Peppermix-Icons.tar.gz
now close the terminal.
(Original thread: Install -> Medion xxxx, from october 1, 2019 -> « Reply #10 on: October 02, 2019, 05:33:06 pm »
Offline rayzer
  • Graphics n Stuff
« Reply #6 on: June 12, 2020, 07:53:30 am »
the tar file in that tutorial is inaccessible, unless you already have the folder downloaded then its not possible at the moment.
that tutorial basically shows you how to download, extract then remove the source tar afterwards via terminal.
i find using lxappearance the easiest way to install icons as its all gui, otherwise you just take the icons folder and move it to either /usr/share/icons or .local/share.icons in your home directory.
Offline LordKaan
« Reply #7 on: June 12, 2020, 01:27:15 pm »
Yep i got this; and also, that this "version"/Way wouldn t be poss in future too - cause there are no plans, to store the img. too
But maybe there is a other way (cause new notebook) to get the old (peppermint 6 ) Icons back
This way i never made
:blush: Maybe u know a tutorial for this
thx
Offline rayzer
  • Graphics n Stuff
« Reply #8 on: June 12, 2020, 02:13:05 pm »
open customize look and feel from the menu then click on the icons tab. under the list of icons theres a + button. use that and browse to the icons location..
it only uses certain archive formats so if doesnt pick up your archive, youll need to extract the archive then compress it again into the required type
UPDATE:
found an old pep6 live cd and ripped it to an iso then back to usb. managed to grab the peppermix folder off it and here it is.
Peppermix.tar.gz
https://www19.zippyshare.com/v/f11vWprs/file.html
« Last Edit: June 12, 2020, 04:14:09 pm by rayzer »
Offline LordKaan
« Reply #9 on: June 13, 2020, 06:48:20 am »
Great !!!!!;
Okay; i grab the file, i unzip it into download ....
and how do i transfer it from download, into the right folders, so that i can "install" them from the menu??? :blush:
(OT: This is my main problem, when i do have install anything, without the manger)
Thx for ur patient with me
« Reply #10 on: June 13, 2020, 07:01:48 am »
Try reading the post immediately above your last, where instructions were offered.
Offline LordKaan
« Reply #11 on: June 13, 2020, 08:15:28 am »
Sorry, my english isn t the best - be patient with me;
What i understand at the post above my last: The standart Icons are there
Okay, that i allready got
But i duno know to where i should copy the files from this archiv...
(and "how"; i am not used to all this "sudo do this and that")
Formaly i made all, as it is explained in the tutorial
(I never take care, what happend in the background; and whre are all the files etc.; finaly it was working; and this was okay for me)
(and sory, i m just user, not used Terminal and co)
So i do not know if this:
sudo tar xvf Peppermix.tar.gz (and followed)
 made inside the "downloadfolder" by terminal,
is the correct way
If yes... okay, i will be fine,...
if no... than i need the help
in the moment i am unsure, but gratfull from the help of rayzer
Edit: Correction of the name of the tar file
« Last Edit: June 13, 2020, 08:25:00 am by LordKaan »
« Reply #12 on: June 13, 2020, 10:37:08 am »
You browse to the .tar, not what you extracted from it.
Offline LordKaan
« Reply #13 on: June 13, 2020, 11:30:11 am »
Okay
Thank you very much;
I didn know, that works with the tar file too
Thx again !!!!!!!!
Edit:
Made as recommanded !!!
It works perfectly
Thank you both very much
« Last Edit: June 13, 2020, 11:37:46 am by LordKaan »
Offline LordKaan
« Reply #14 on: October 10, 2020, 04:47:42 pm »
UPDATE:
Peppermix.tar.gz
Hi rayzer;
may i please u, to upload the file again; causz zippy isnt anymore available
And 2nd question - it seems, that the peppermint .info url want come back ; no certificat;
and some of the tutorials lead to it... , p.e. how to change whiskamenu the ppm 6 look and feel
