Author Topic: Internet on laptop (SOLVED)  (Read 2609 times)
Offline Steve M
  • New To PeppermintOS
Re: Internet on laptop
« Reply #45 on: April 29, 2020, 06:19:29 am »
The page has some updated info with it working on Ubuntu 19
http://ubuntuhandbook.org/index.php/2019/04/nstall-rtl8723de-wifi-driver-ubuntu-19-04/
I think that is the page I used to install the rtlwifi software.
Whether Peppermint uses ubuntu19 or not, I'm not sure but it is now working. (As mentioned in my previous post.)
The problem seems to be the Secure Boot in the BIOS which was preventing software changes. I'm not sure why it was only affecting that one thing, but poking around in the settings of the BIOS has got the wifi working.
The thing I initially installed was rtlwifi_new-extended. The 'extended' bit wasn't mentioned in various guides, so whether it is updated or Peppermint is updated so it works, I'm not sure - but it works!
Offline stevesveryown
  • Peppermint Fan
    • stevesveryown
Re: Internet on laptop (SOLVED)
« Reply #46 on: April 29, 2020, 11:50:46 am »
I'm glad for you. Peppermint is not based on the 19 series but sometimes fixes span across versions. As you do more and more in linux you will find things easier. I'm glad you didn't give up. Welcome to the New World!
Sent from my SM-G950U using Tapatalk
« Reply #47 on: April 30, 2020, 09:57:20 am »
Glad you stuck with it and found a solution. Also thank you for remembering to mark it (SOLVED)
Happy Pepperminting!
  8)
& '18 Asus VivoBook
Offline mintspider
  • Solus Budgie, Peppermint, & FreeBSD user
    • Spider's Webtrail
  • Peppermint version(s): 10R
« Reply #48 on: May 02, 2020, 08:17:58 am »
Steve M, so glad to hear your wifi is now working... took me a few days to catch up on the forum.
I have been working almost as many hours as StevesVeryOwn.
Peter Paterson
Scotsman in Kentucky
Solus, Peppermint, & FreeBSD user
BDLL Tester
Believer in Jesus Christ
« Reply #49 on: May 02, 2020, 04:22:38 pm »
I'm just curious, Steve M, was secure boot settings the only settings you changed in bios that enabled things to work?
