Author Topic: [SOLVED]Speaker recognized but no sound from Speaker  (Read 1155 times)
Offline mayank9018
  • New To PeppermintOS
  • Peppermint version(s): Version 10
« on: April 18, 2020, 03:38:06 am »
I'm a newbie to Peppermint and Linux. I'm receiving no sound from speaker. I've tried many solutions from forum, but none seems to be working. In the pavecontrol, output device section I see:
"Port:Line Out(plugged in)"
I've checked the speakers with my phone and they work fine. Please help.
Here is a screenshot of pavucontrol:
Audio:     Card Intel NM10/ICH7 Family High Def. Audio Controller
           Sound: Advanced Linux Sound Architecture v: k5.3.0-46-generic
« Last Edit: April 27, 2020, 07:10:53 pm by mayank9018 »
Re: Speaker recognized but no sound from Speaker
« Reply #1 on: April 20, 2020, 02:51:05 pm »
Try opening a terminal type in  alsamixer. Hit enter then press f6 and toggle down to HD- Audio generic and hit enter. at the bottom of the columns, change the mm's to 00's and add volume using the up arrow on your keyboard. Move from column to column using the side arrows. Here's a shot of what my setup looks like, The rear mic is not shown.
If that doesn't work, let us know.
Offline mayank9018
« Reply #2 on: April 20, 2020, 07:30:35 pm »
Thanks for the reply.
I did what you said, but still no sound:
« Reply #3 on: April 21, 2020, 05:37:05 pm »
Do headphones work?
could you open a terminal and run
inxi -Fz   and post the results here?
Offline mayank9018
« Reply #4 on: April 21, 2020, 07:37:42 pm »
My front port does not work, so I cannot plug in headphone in the front audio jack but I've tried plugging the headphones in the rear audio jack but it doesn't work.
System:    Host: mayank-System-Product-Name Kernel: 5.3.0-46-generic i686 bits: 32
Machine:   Device: desktop Mobo: ASUSTeK model: P5GC-MX v: Rev x.xx serial: N/A
           BIOS: American Megatrends v: 0205 date: 07/20/2007
CPU:       Dual core Intel Core2 Duo E4500 (-MCP-) cache: 2048 KB
           clock speeds: max: 2200 MHz 1: 1251 MHz 2: 1206 MHz
Graphics:  Card: Intel 82945G/GZ Integrated Graphics Controller
           Display Server: x11 (X.Org 1.20.5 )
           drivers: intel (unloaded: modesetting,fbdev,vesa)
           Resolution: 1360x768@60.02hz
           OpenGL: renderer: Mesa DRI Intel 945G x86/MMX/SSE2
           version: 1.4 Mesa 19.2.8
Network:   Card-1: Qualcomm Atheros Attansic L2 Fast Ethernet driver: atl2
           Card-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter
           driver: r8188eu
           IF: wlxf4f26d0f4b44 state: N/A mac: N/A
Drives:    HDD Total Size: 221.5GB (7.2% used)
           ID-1: /dev/sda model: ExcelStor_Techno size: 61.5GB
           ID-2: /dev/sdb model: WDC_WD1600AABS size: 160.0GB
Partition: ID-1: / size: 146G used: 15G (11%) fs: ext4 dev: /dev/sdb1
Sensors:   System Temperatures: cpu: 54.0C mobo: N/A
           Fan Speeds (in rpm): cpu: 2070 sys-1: 0
Info:      Processes: 177 Uptime: 6 min Memory: 736.6/1933.4MB
Offline rayzer
  • Graphics n Stuff
« Reply #5 on: April 22, 2020, 05:12:13 pm »
ive had this happen to me before, only way i got around it was to install a second soundcard i had lying about and my audio worked straight away. maybe try picking up one of those cheap usb dongle cards off ebay, something like this
https://www.amazon.com/Syba-external-Adapter-Windows-C-Media/dp/B001MSS6CS/ref=sr_1_14?dchild=1&keywords=usb+sound+card&qid=1587600526&sr=8-14
Offline mayank9018
« Reply #6 on: April 22, 2020, 07:31:35 pm »
Thanks for the reply. I'll try it when the lockdown is over.
Offline rayzer
  • Graphics n Stuff
Re: [SOLVED]Speaker recognized but no sound from Speaker
« Reply #7 on: April 22, 2020, 07:44:19 pm »
try loading up another distro too just to rule out a peppermint specific issue, mint xfce for example. running it off a live usb should be enough to test it
Offline mayank9018
« Reply #8 on: April 24, 2020, 05:22:22 am »
I've tried but no sound in other os too.
Offline mayank9018
« Reply #9 on: April 24, 2020, 05:24:54 am »
Should I buy an usb audio card or a usb bluetooth adapter because my speaker also has bluetooth connectivity?
Which one has a better chance of working?
Re: [PAUSED]Speaker recognized but no sound from Speaker
« Reply #10 on: April 24, 2020, 06:33:32 am »
Hi mayank9018,
Ideally you would test each device (before purchasing anything) using your own hardware. As this is often not possible, I would suggest making a short list of several usb audio cards and several usb bluetooth adapters. Then go online and do a little research, such as reading what the manufacturers say about supporting linux (unfortunately that is often quickly finished since so many totally ignore linux) and then do some searches (with DuckDuckGo, Google or whatever you prefer) using search terms that include the card/adapter make and model as well as "linux compatibility" or Ubuntu and see what you find. This is frequently what we would do and I suggest you do it as well. There are surely reports that you can find this way to help you make a decision.  ;)
« Reply #11 on: April 24, 2020, 06:41:22 am »
Did you test the cable too or just bluetooth from the phone?
Offline mayank9018
« Reply #12 on: April 24, 2020, 09:13:37 pm »
Hi mayank9018,
Thank you for the info. I'll do the same.
Offline mayank9018
« Reply #13 on: April 24, 2020, 09:14:52 pm »
It works both the ways-with cable and Bluetooth.
Offline mayank9018
« Reply #14 on: April 27, 2020, 07:33:46 am »
Thanks for recommending this!!!!!!!!!
This worked !!!!1
