Author Topic: External Hard Drive not appearing on desktop when mounted  (Read 366 times)
Offline Peewee_1985
« on: April 08, 2020, 02:29:04 pm »
Hey guys!
Hope you're all well....
Everytime I connect my old external hd the drive through the usb port it appears in nemo -and it works perfectly- but it's not showing up on the desktop although the option for that is selected in the adjustments (you know, personal folder, bin and mounted drives...).
Any idea why???
Thanks a lot!
Re: External Hard Drive not appearing on desktop when mounted
« Reply #1 on: April 08, 2020, 04:23:29 pm »
somewhere along the line, automount was removed... err well @PCNetSpec decided to, after a discussion with the rest of the team.
Offline rayzer
  • Graphics n Stuff
« Reply #2 on: April 08, 2020, 05:42:24 pm »
right click the desktop > customize > in new window click desktop settings > enable mounted drives. that might fix your problem
« Reply #3 on: April 26, 2020, 03:09:50 pm »
Hi Peewee_1985. Have you set that option in dconf Editor?
