Author Topic: PULSE-SERVER error - (SOLVED)  (Read 305 times)
Offline s2
« on: March 23, 2020, 06:21:48 pm »
still a Noob after all these years. have to ask for help from the gurus.
Peppermint 8 running on a Lenovo Thinkpad W500
was having problems with sound quality using Bluetooth portable speaker.
this message popped up and after a number of failed attempts i am unable to resolve the issue.
error message:   run start-PULSE-AUDIO x11
thanks much...
« Last Edit: March 25, 2020, 12:36:23 pm by s2 »
Re: PULSE-SERVER error -
« Reply #1 on: March 23, 2020, 08:40:08 pm »
As the error message suggests, you could try opening a terminal (Ctrl+Alt+T) and typing:
start-pulseaudio-x11
Offline s2
« Reply #2 on: March 24, 2020, 07:45:22 am »
hey murraymint, thanks.
i typed in ( start-pulseaudio-x11 ) and got:
Connection failure Connection refused
pa_context_connect() failed Connection refused
« Reply #3 on: March 24, 2020, 10:08:41 am »
Here's a procedure to reset Pulseaudio to defaults, hopefully it still works:
https://forum.peppermintos.com/index.php/topic,662.msg5519.html#msg5519
Offline s2
« Reply #4 on: March 24, 2020, 05:10:23 pm »
yes sir, worked like a charm.
rebooted after changes made.
thank you so much.
have a great evening and a great day tomorrow.
Re: PULSE-SERVER error - (SOLVED)
« Reply #5 on: March 24, 2020, 05:23:46 pm »
Good stuff, thanks for marking it solved :)
