Author Topic: Display settings reset after a while (SOLVED)  (Read 1008 times)
Offline 36m2jones
« on: March 23, 2020, 04:39:20 pm »
I changed my display settings to what worked for me, but after a while it just resets to where it was.  It was usually after the screen locked, so I made it where the screen doesn't lock.. no hibernation.. nothing.  It just stays on.  If I leave for a while and come back, the display settings have changed again.
Does anybody know how I can fix that?
« Last Edit: April 03, 2020, 05:05:06 pm by 36m2jones »
Re: Display settings reset after a while
« Reply #1 on: March 23, 2020, 06:07:13 pm »
Please help us help you by providing the terminal output for :
Then I used the Search function on the forum's title bar, lets see if this thread might lead you to a solution.
https://forum.peppermintos.com/index.php/topic,8700.0.html
« Last Edit: March 23, 2020, 06:10:53 pm by spence »
& '18 Asus VivoBook
Offline 36m2jones
« Reply #2 on: March 27, 2020, 12:33:19 pm »
This is what I got.
System:    Host: mrnunya-HP-Compaq-Pro-6305-SFF Kernel: 5.0.0-37-generic x86_64
           bits: 64
Machine:   Device: desktop System: Hewlett-Packard product: HP Compaq Pro 6305 SFF serial: N/A
           Mobo: Hewlett-Packard model: 1850 serial: N/A
           UEFI: Hewlett-Packard v: K06 v02.04 date: 09/26/2012
CPU:       Dual core AMD A4-5300B APU with Radeon HD Graphics (-MCP-)
           cache: 2048 KB
           clock speeds: max: 3400 MHz 1: 1755 MHz 2: 1802 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Trinity 2 [Radeon HD 7480D]
           Display Server: x11 (X.Org 1.20.4 )
           drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
           Resolution: 1024x768@60.00hz
           OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 5.0.0-37-generic, LLVM 8.0.0)
           version: 4.3 Mesa 19.0.8
Audio:     Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller
           Card-2 Advanced Micro Devices [AMD/ATI] Trinity HDMI Audio Controller
           Sound: ALSA v: k5.0.0-37-generic
Network:   Card: Broadcom and subsidiaries NetXtreme BCM5761 Gigabit Ethernet PCIe
           driver: tg3
           IF: enp3s0 state: down mac: <filter>
Drives:    HDD Total Size: 250.1GB (12.4% used)
           ID-1: /dev/sda model: ST3250318AS size: 250.1GB
Partition: ID-1: / size: 228G used: 29G (14%) fs: ext4 dev: /dev/sda2
Sensors:   System Temperatures: cpu: 0.0C mobo: N/A gpu: -3.0
Info:      Processes: 201 Uptime: 12 days Memory: 1402.8/2445.1MB
Thank you.
« Last Edit: March 27, 2020, 12:44:17 pm by spence »
« Reply #3 on: March 27, 2020, 12:53:15 pm »
G'afternoon @36m2jones! or morning or evening as the case may be wherever you are
Please remember to use the forum tools above the message composition box when copying and pasting terminal outputs, it helps keep the readout formatted properly. Specifically the # button above the laughing and angry emojis...
I've fixed it for you this time around.
I'll need other forum moderators to chime in on this support request though.
« Last Edit: March 27, 2020, 12:56:08 pm by spence »
& '18 Asus VivoBook
Offline 36m2jones
« Reply #4 on: March 27, 2020, 08:18:22 pm »
I don't know how I'm supposed to use those buttons.  I'm inexperienced.  I tried the # button just to see how it works, and it just says "
".   How do I know if I'm doing it right?
« Reply #5 on: March 27, 2020, 09:05:54 pm »
After pressing the # button you copy and paste your terminal output...  in between the code] markers[/code
« Last Edit: March 27, 2020, 09:55:31 pm by spence »
& '18 Asus VivoBook
« Reply #6 on: March 28, 2020, 01:06:45 am »
Hi 36m2jones,
Here is a short explanation  (click on the underlined text link to the left of this parenthetical remark) about how to do something like that.
Offline 36m2jones
« Reply #7 on: March 28, 2020, 04:30:07 pm »
Got it.  Thanks.
Offline 36m2jones
« Reply #8 on: March 30, 2020, 09:48:37 am »
No ideas how to fix this?
When I come back and find the display reset, the online radio I had playing has stopped too; and desktop dimmer stopped.
When I fix the display the dimmer starts again.
« Reply #9 on: March 30, 2020, 10:36:19 am »
Off the top of my head, still having my first coffee of the day out here in quarantine land, it sounds like a screensaver/powermanager issue. Please doublecheck that your powermanager settings don't include a screen timeout. Also, have you enabled or disabled screensavers in any way?
try unchecking the "Dim display when idle" option in the Power Management Preferences window. To get there, right-click the battery icon in your panel, click preferences, and remove the check-mark if it's present.
« Last Edit: April 02, 2020, 09:30:46 am by spence »
& '18 Asus VivoBook
Offline 36m2jones
« Reply #10 on: March 31, 2020, 06:39:04 pm »
Looks like I'm in quarantine land now too. I live with my parents and sister and the doctor assumed she has the virus.
"Automatically lock the session:" was set to "when screen saver is activated".  I changed it to never.  All the rest I had already disabled so it would never go to sleep.  Maybe that will work.  I'll have to wait and find out.
Thank you.  Enjoy the coffee.
Offline 36m2jones
« Reply #11 on: April 03, 2020, 12:15:35 am »
It's still doing it.
Offline 36m2jones
« Reply #12 on: April 03, 2020, 02:01:03 pm »
https://forum.peppermintos.com/index.php/topic,9564.0.html
This worked.
I tried it yesterday and checked today, and the display didn't reset.  I rebooted the computer and when I got past the login screen it was still set the way I had it. 8)
How do I mark this as resolved?
« Last Edit: April 03, 2020, 02:02:34 pm by 36m2jones »
« Reply #13 on: April 03, 2020, 03:05:08 pm »
Glad you found a solution! Edit the original post in your thread and append (SOLVED) at the end of the subject line...
& '18 Asus VivoBook
Offline 36m2jones
« Reply #14 on: April 03, 2020, 05:03:49 pm »
Thank you.
