Author Topic: I tried to open my downloaded driver,message dependency not satisfied [SOLVED]  (Read 7175 times)
Offline susan365
  • Peppermint version(s): 5
When I went to open the downloaded driver I got a message
ERROR: Dependency is not satisfiable: lsb(>=3.2)
in the description it says:
This product supports only EPSON ESC/P-R printers. This package can be used for all EPSON ESC/P-R printers.
For detail list of supported printer, please refer to below site: http://download.ebz.epson.net/dsc/search/01/search/?OSC=LX
(Converted from a rpm package by alien version 8.79ubuntu0.1.)
It also says this:
No lintian available.
Please install using sudo apt-get install lintian
any suggestions,
Thanks again, Susan
« Last Edit: September 06, 2014, 11:41:28 am by susan365 »
Which printer model are we talking about here ?
and what's the output from:
uname -a
Offline susan365
susan@st779 ~ $ uname -a
Linux st779 3.13.0-30-generic #55-Ubuntu SMP Fri Jul 4 21:43:42 UTC 2014 i686 i686 i686 GNU/Linux
Epson Stylus NX430
I've uploaded the drivers you'll require to my dropbox because it's hard to directly link to them on the Epson website.
mkdir ~/Epson-Driversthen
cd ~/Epson-Driversthen
wget https://dl.dropboxusercontent.com/u/11876059/NX430.tar.gzthen
tar xvf NX430.tar.gzthen
cd ~/Epson-Drivers/NX430then
sudo dpkg -i epson-inkjet-printer-201105w_1.0.0-1lsb3.2_i386.debWhen that's done, go to
menu > System Tools > Printers
and click the "+Add" button
Hopefully your printer will be detected.
When asked to select a driver, select
Espon >  NX430 TX435 > Epson NX430 TX435 Series - epson-inkjet-printer 1.0.0-1lsb3.2 (Seiko blah blah blah)
Keep those drivers (as I'll probably remove them from my dropbox eventually) and let me know if you need further assistance .. such as for the scanner.
For reference, the archive in my dropbox contains these packages:-
epson-inkjet-printer-escpr_1.4.1-1lsb3.2_i386.deb
iscan_2.29.3-1~usb0.1.ltdl7_i386.deb
iscan-data_1.29.0-2_all.deb
iscan-network-nt_1.1.1-1_i386.deb
The above instructions only install the one in red .. the others are there "just in case".
« Last Edit: September 05, 2014, 04:04:14 pm by PCNetSpec »
Offline susan365
Thanks so much for your help
I got this far then another error message popped up
susan@st779 ~/Epson-Drivers/NX430 $ sudo dpkg -i epson-inkjet-printer-201105w_1.0.0-1lsb3.2_i386.deb
[sudo] password for susan:
Selecting previously unselected package epson-inkjet-printer-201105w.
(Reading database ... 188966 files and directories currently installed.)
Preparing to unpack epson-inkjet-printer-201105w_1.0.0-1lsb3.2_i386.deb ...
Unpacking epson-inkjet-printer-201105w (1.0.0-1lsb3.2) ...
dpkg: dependency problems prevent configuration of epson-inkjet-printer-201105w:
 epson-inkjet-printer-201105w depends on lsb (>= 3.2); however:
  Package lsb is not installed.
dpkg: error processing package epson-inkjet-printer-201105w (--install):
 dependency problems - leaving unconfigured
OK,let's try manually installing lsb first
sudo apt install lsbIf that runs without error, run:
pcmanfm ~/Epson-Drivers/NX430and in the resulting file manager window .. double-click the "epson-inkjet-printer-201105w_1.0.0-1lsb3.2_i386.deb" file to install.
Any errors post them here.
« Last Edit: September 06, 2014, 04:45:48 am by PCNetSpec »
Offline susan365
This what I get:
susan@st779 ~/Epson-Drivers/NX430 $ sudo apt install lsb
Reading package lists... Done
Building dependency tree
Package lsb is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'lsb' has no installation candidate
Run:
sudo apt updatethen try again with:
sudo apt install lsbif that works, run:
sudo dpkg --configure -aif it doesn't work, run:
gedit /etc/apt/sources.listand post the contents of the file that opens
Offline susan365
it did not work so here is the post from gedit
# deb cdrom:[Peppermint 5 _Five_ - Release i386 (20140617.2)]/ trusty main multiverse restricted universe
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://us.archive.ubuntu.com/ubuntu/ trusty restricted
deb-src http://us.archive.ubuntu.com/ubuntu/ trusty restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates restricted
deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-updates restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://us.archive.ubuntu.com/ubuntu/ trusty universe
deb-src http://us.archive.ubuntu.com/ubuntu/ trusty universe
deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates universe
deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://us.archive.ubuntu.com/ubuntu/ trusty multiverse
deb-src http://us.archive.ubuntu.com/ubuntu/ trusty multiverse
deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates multiverse
deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://us.archive.ubuntu.com/ubuntu/ trusty-backports restricted universe multiverse
deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-backports restricted universe multiverse
deb http://security.ubuntu.com/ubuntu trusty-security restricted
deb-src http://security.ubuntu.com/ubuntu trusty-security restricted
deb http://security.ubuntu.com/ubuntu trusty-security universe
deb-src http://security.ubuntu.com/ubuntu trusty-security universe
deb http://security.ubuntu.com/ubuntu trusty-security multiverse
deb-src http://security.ubuntu.com/ubuntu trusty-security multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu trusty partner
# deb-src http://archive.canonical.com/ubuntu trusty partner
## This software is not part of Ubuntu, but is offered by third-party
## developers who want to ship their latest software.
deb http://extras.ubuntu.com/ubuntu trusty main
deb-src http://extras.ubuntu.com/ubuntu trusty main
Well that's just plain odd .. you're sources list is missing the "main" section from 6 lines
First let's backup your sources.list:
sudo cp -v /etc/apt/sources.list /etc/apt/sources.list.baknow open sources.list for editing:
sudo gedit /etc/apt/sources.listand add in the 6 "main" entries I've highlighted below:-
deb http://us.archive.ubuntu.com/ubuntu/ trusty main restricted
deb-src http://us.archive.ubuntu.com/ubuntu/ trusty main restricted
## distribution.
deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates main restricted
deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-updates main restricted
## security team.
deb http://security.ubuntu.com/ubuntu trusty-security main restricted
deb-src http://security.ubuntu.com/ubuntu trusty-security main restricted
Once added, SAVE the file and exit gedit.
Back in the terminal run:
sudo apt updateand if there are any errors, post them here.
If there are no errors, run:
sudo apt install lsbdid it work this time ?
« Last Edit: September 06, 2014, 10:24:41 am by PCNetSpec »
Offline susan365
it said it was a read only file
Sorry, I missed "gedit" out of the second command .. fixed above now  :-[
(that command will open it in gedit with read/write privileges)
« Last Edit: September 06, 2014, 10:27:14 am by PCNetSpec »
Offline susan365
I did the update and got this message
susan@st779 ~ $ sudo apt install lsb
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
 lsb : Depends: lsb-core (>= 4.1+Debian11ubuntu6) but it is not going to be installed
       Depends: lsb-graphics (>= 4.1+Debian11ubuntu6) but it is not going to be installed
       Depends: lsb-cxx (>= 4.1+Debian11ubuntu6) but it is not going to be installed
       Depends: lsb-desktop (>= 4.1+Debian11ubuntu6) but it is not going to be installed
       Depends: lsb-printing (>= 4.1+Debian11ubuntu6) but it is not going to be installed
       Depends: lsb-languages (>= 4.1+Debian11ubuntu6) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
run:
sudo apt-get -f installthen if that comletes without error .. try installing the printer driver by double-clicking the epson-inkjet-printer-201105w_1.0.0-1lsb3.2_i386.deb file.
Offline susan365
SUCCESS !!! :D
Thank you, Thank you, Thank you
Susan
