Author Topic: Archer T4U wireless adapter driver v3 Install/ NEED HELP!  (Read 254 times)
Offline DonJuanTheOne
  • Peppermint version(s): Kernel: 5.0.0-29-generic x86_64
« on: March 04, 2020, 08:48:50 am »
Im looking for help installing the driver for my archer t4u wireless adapter, been multiple years since running linux and could use some peer support.
Re: Archer T4U wireless adapter driver v3 Install/ NEED HELP!
« Reply #1 on: March 04, 2020, 12:57:09 pm »
Hi DonJuanTheOne,
To help us help you, please open a terminal and run the following command:
inxi -FzThen copy the output that you get and paste it into your next reply here.
« Reply #2 on: March 04, 2020, 04:55:44 pm »
Thank you for your reply, sorry if im spotty responding as i have to tether my phone for access at the moment and its spotty, here are the results of the command.
System:    Host: Duke-EL1352 Kernel: 5.0.0-29-generic x86_64 bits: 64 Desktop: N/A
           Distro: Peppermint Ten
Machine:   Device: desktop System: eMachines product: EL1352 v: P01-A1 serial: N/A
           Mobo: eMachines model: EL1352 serial: N/A
           BIOS: American Megatrends v: P01-A1 date: 01/28/2010
CPU:       Dual core AMD Athlon II X2 220 (-MCP-) cache: 1024 KB
           clock speeds: max: 2800 MHz 1: 1600 MHz 2: 1600 MHz
Graphics:  Card: NVIDIA C61 [GeForce 6150SE nForce 430]
           drivers: nouveau (unloaded: modesetting,fbdev,vesa)
           Resolution: 1366x768@59.79hz
           OpenGL: renderer: NV4C version: 2.1 Mesa 18.2.8
Audio:     Card NVIDIA MCP61 High Def. Audio driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k5.0.0-29-generic
Network:   Card: NVIDIA MCP61 Ethernet driver: forcedeth
           IF: enp0s7 state: down mac: <filter>
Drives:    HDD Total Size: 500.1GB (5.7% used)
           ID-1: /dev/sdc model: WDC_WD5000LPCX size: 500.1GB
Partition: ID-1: / size: 458G used: 27G (7%) fs: ext4 dev: /dev/sdc1
Sensors:   System Temperatures: cpu: 26.0C mobo: N/A
Info:      Processes: 167 Uptime: 1 day Memory: 647.2/2746.2MB
« Reply #3 on: March 10, 2020, 09:48:57 am »
Hi DonJuanThe One, welcome to Peppermint, have you verified that there is a linux compatible driver for your adaptor? Have you checked in Software and Updates for additional drivers?
