Author Topic: Lock screen does not work  (Read 1893 times)
Offline gtownspartan
  • Peppermint version(s): 5
« on: September 05, 2014, 12:50:06 am »
Hello,
Pressing control-alt-l does not enable the screen lock for some reason. This is huge security risk. Can somebody please assist. Thx. >:(
Re: Lock screen does not work
« Reply #1 on: September 05, 2014, 07:39:31 am »
Go to:-
menu > Preferences > Light Locker Settings
set
Enable light-locker: ON
Click "Apply"
Now try Ctrl+Alt+L
(or "Lock Screen" from the logout screen)
« Last Edit: September 05, 2014, 07:42:18 am by PCNetSpec »
« Reply #2 on: October 17, 2014, 07:38:30 pm »
To make the "Lock Screen" button (from the logout screen) and the Ctrl+Alt+L keybaord shortcut work with Light Locker
Go to:-
menu > Preferences > Default applications for LXSession > Core applications (tab)
Find the blank entry for "Screensaver", and in the empty box enter "light-locker" (without the quotation marks)
then log off/on
This is ONLY for Light Locker .. DO NOT make this change if you've replaced light-locker with xscreensaver
