Author Topic: Updating Peppermint 10 Bsdutils error  (Read 274 times)
Offline mckenney56
« on: February 08, 2020, 09:05:44 am »
When applying updates with update manager I keep getting the following:
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/main/u/util-linux/bsdutils_2.31.1-0.4ubuntu3.5_amd64.deb
  Connection failed [IP: 2001:67c:1562::16 80]
Re: Updating Peppermint 10 Bsdutils error
« Reply #1 on: February 08, 2020, 08:54:34 pm »
Hi Mckenney56, welcome to Peppermint. Try changing you software source in Software & Updates.
Offline mckenney56
« Reply #2 on: February 09, 2020, 08:28:50 am »
I got it to work by changing the "Download From" to "Main Server".  It originally was set to something that said United States in it.  I went back in and that United States option is now gone.  the only other option is "Other".  When you open "Other" is a long list of servers in the U.S.  The question now is do I change it back to one of those servers, and if so which one?
Offline jlschwartz
  • Forum User
« Reply #3 on: February 09, 2020, 10:51:48 am »
If you select other, on the next screen at the top you see an option that says Select Best Server.  If you select that option, it will run a series of tests to find the best server for your location.  Then you can choose that server.
