Author Topic: Sound settings pannel disappeared (SOLVED)  (Read 452 times)
Offline bsr6563
« on: February 07, 2020, 01:38:47 pm »
Hello,
I am newbie to linux. I have been using peppermint os since past 6 months. The experience has been fantastic as the OS is rock stable.
I cannot find the sound settings , neither in the panel nor in the menu. I get this issue after  updated the software recently.
Is it possible to restore the 'sound settings'  packag  again?
Best regards,
bsr656
« Last Edit: February 10, 2020, 03:46:09 am by Slim.Fatz »
Offline bsr6563
Re: Sound settings pannel disappeared
« Reply #1 on: February 08, 2020, 12:57:04 pm »
After looking over internet for a while, I figured out that the some of the pulseaudio related packages were uninstalled, when I had run some commands to fix the bluetooth connection issue . :)
So now I installed the application by running the command,
sudo apt-get install pulseaudio pulseaudio-utils pavucontrol
But still plugin to add it in the task panel is still missing.
Can anyone tell me how to install the plugins for volume control?
« Reply #2 on: February 09, 2020, 05:21:22 am »
Hi bsr6563,
Check that you have the xfce4-pulseaudio-plugin package installed. If it is not installed then install it with the following command in a terminal:
sudo apt-get install xfce4-pulseaudio-plugin
Then restart the panel to pick up the plugin with this command:
xfce4-panel -r
Offline bsr6563
« Reply #3 on: February 10, 2020, 03:40:48 am »
This solved the issue. Thank you Slim.
« Reply #4 on: February 10, 2020, 03:45:45 am »
Hi bsr6563,
Glad to hear that your issue has been solved. In the future, when an issue has been solved to your satisfaction, please go back to your initial message about the issue, click on the button Modify and then add (SOLVED) to the end of the line Subject:  Finally, save the result. I have done it for you this time.  :)
Offline bsr6563
Re: Sound settings pannel disappeared (SOLVED)
« Reply #5 on: February 10, 2020, 03:47:18 am »
I will do that from next time. Thanks again.
