Author Topic: Arandr starting at startup with multiple screens  (Read 594 times)
Offline clatterfordslim
« on: January 31, 2020, 07:09:46 am »
Ever wondered how to get all your screens booted in Peppermint? Well I have spent the afternoon trialing different solutions and made this tutorial for someone who asked in the forums.
Create a folder in hidden folders in your home directory pushing
Ctrl+H together will bring hidden folders up
Right Click empty space in home directory Left click Create New Foldercall it
.xsessionrcThe file you originally made in ARandr rename it to
xsession.shPop that
xsession.sh into .xsessionrc folder you just created
Open
Menu/Settings/Default applications for LXSession
When it opens left click
AutostartThen in the box next to Add type
.xsessionrc/xsession.sh then left click addAfter pushing Add it should look like this.
Finally reboot or logout and it should setup your screens.  ;) Also switching off monitors does not reset them back to mirror mode, it stays with xsession.sh.  :D This has been a pleasure to work on.
« Last Edit: January 31, 2020, 07:43:06 am by clatterfordslim »
But so is this Forum :)
