Author Topic: Linksys WUSB6300 Wireless Dongle[SOLVED]  (Read 365 times)
Offline alan
« on: January 31, 2020, 08:35:20 am »
Trying to get this to work.  I've Googled and tried everything I could find, but most of the "solutions" were over 10 years old and don't seem to work today.  Any help would be appreciated.  I wasn't sure if I should post this here or in the network forum..it's here for now.
« Last Edit: February 01, 2020, 09:07:24 am by alan »
    • My MeWe profile
Re: Linksys WUSB6300 Wireless Dongle
« Reply #1 on: January 31, 2020, 03:19:34 pm »
We'll need some more info @Alan before we can suss things out...   :-\
https://forum.peppermintos.com/index.php/topic,6713.0.html
« Last Edit: January 31, 2020, 03:44:06 pm by spence »
 '18 Asus VivoBook
Offline alan
« Reply #2 on: January 31, 2020, 03:52:00 pm »
Thanks for the reply @spence.
Does the dongle need to be plugged in before running the lsusb command?  I'm new to Linux, so I need some hand holding.  :)
    • My MeWe profile
« Reply #3 on: January 31, 2020, 04:12:05 pm »
Yes.. needs to be plugged in... to see if your machine is able to connect with it if my memory serves me...
 '18 Asus VivoBook
Offline alan
« Reply #4 on: January 31, 2020, 04:23:08 pm »
Ok, great.
Bus 002 Device 003: ID 413c:2003 Dell Computer Corp. Keyboard
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 001 Device 005: ID 1058:0704 Western Digital Technologies, Inc. My Passport Essential (WDME)
Bus 001 Device 006: ID 13b1:003f Linksys WUSB6300 802.11a/b/g/n/ac Wireless Adapter [Realtek RTL8812AU]
Bus 001 Device 003: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 002: ID 8087:8008 Intel Corp.
*-network
       product: Ethernet Connection I217-LM
       vendor: Intel Corporation
       physical id: 19
       bus info: pci@0000:00:19.0
       logical name: eno1
       version: 04
       serial: 34:17:eb:b0:c2:9d
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k duplex=full firmware=0.13-4 ip=192.168.0.102 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:27 memory:f7c00000-f7c1ffff memory:f7c3d000-f7c3dfff ioport:f080(size=32)
eno1      no wireless extensions.
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.102  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 fe80::3457:a423:408f:d7dc  prefixlen 64  scopeid 0x20<link>
        ether 34:17:eb:b0:c2:9d  txqueuelen 1000  (Ethernet)
        RX packets 309636  bytes 445851142 (445.8 MB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 81458  bytes 7724763 (7.7 MB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 20  memory 0xf7c00000-f7c20000
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 1650  bytes 154724 (154.7 KB)
        TX packets 1650  bytes 154724 (154.7 KB)
eno1      Interface doesn't support scanning.
rfkill list
no output at all
« Last Edit: January 31, 2020, 06:21:55 pm by AndyInMokum, Reason: Encapsulating with [code]. »
    • My MeWe profile
« Reply #5 on: January 31, 2020, 04:43:49 pm »
This must be @PCNetSpec's way of kicking my arse, and laughing, from beyond the grave... for we have the same driver for our wireless dongle... give me a minute to sort thru my posts...
 :D
Are you able to connect this device to the www via an ethernet cord?
« Last Edit: January 31, 2020, 05:13:45 pm by spence »
 '18 Asus VivoBook
« Reply #6 on: January 31, 2020, 06:28:08 pm »
Hi alan, how's it going  :)?   For future reference, could you please remember to encapsulate terminal outputs with the Insert, Code # function.  For extra long outputs, please use the Spoiler, Sp function.  If you're using either the Chromium Browser or Google Chrome, don't combine the functions.  Only use one or the other per output  ;).  These functions preserve the original format of the output.  This makes it easier for future visitors to relate to their own issues.  These functions are found in the forum editor, above the,  :-[ Embarrassed and  the :'( Cry emoticon respectively.  Use the Preview button to see how it'll look in the forum.  This time, I've done it for you - many thanks  ;).
    • My MeWe profile
« Reply #7 on: January 31, 2020, 07:14:34 pm »
Assuming you are connected to the internet via an ethernet cable follow the instructions in the 9th post in this thread, then let us know how you got along:
https://forum.peppermintos.com/index.php/topic,5018.0.html
In Future: Remember to use the forum search feature in the menu bar as many questions have already been solved. I used it to to turn up all related posts to the  RTL8812AU driver...
If you end up solving your issue, please remember to edit your OP (Original Post) and append [SOLVED] at the end of the Subject: to let other future users know we found a solution
« Last Edit: January 31, 2020, 07:20:57 pm by spence »
 '18 Asus VivoBook
Offline alan
« Reply #8 on: February 01, 2020, 08:32:42 am »
Thanks.
Yes, I'm connected via ethernet now.  I tried the search, but I searched for WUSB6300.  I'll check out the thread you linked to.
Thanks again.  We'll see how it goes.
Offline alan
Re: Linksys WUSB6300 Wireless Dongle[SOLVED]
« Reply #9 on: February 01, 2020, 08:58:10 am »
Winnere, winner, chicken dinner.  Bingo.  It worked.  Thank you so much.  Hopefully it will stick after reboots and such.
    • My MeWe profile
« Reply #10 on: February 01, 2020, 03:31:00 pm »
Glad it worked @alan, and thank you for remembering to mark it [SOLVED]... The RTL8812AU driver will hold on thru reboots, but kernel updates often require a short little jig... plug it back into www via ethernet and then
sudo apt remove --purge rtl8812au-dkms
sudo apt install rtl8812au-dkms
sudo modprobe 8812au
you might also bookmark these two threads for future reference
« Last Edit: February 01, 2020, 11:28:46 pm by spence »
 '18 Asus VivoBook
