Author Topic: Peppermint 10 issues with RTL8723DE  (Read 309 times)
Offline dgregory
« on: January 24, 2020, 07:09:28 pm »
Another person trying to get Linux working on an HP laptop!
I am running a dual boot with  Peppermint 10 and WIndows 10. and I consistently get what looks like a low signal on wi-fi in Linux, looks good on Windows.
Peppermint was loaded fresh within the last couple of days, and driver was downloaded and installed today.
Speedtest.net shows similar upload and ping times between Windows and Peppermint, but download speeds are about 12 mbps in Linux, and 80+ mbps in Windows.
I have also had the Linux connection drop completely a few times.
I have tried two different things I found in searches here.  Running a command then editing /etc/modprobe.d/rtl8723de.conf
options rtl8723be ant_sel=2
options rtl8723be ant_sel=1 swenc=Y fwlps=0 ips=0
I even tried combining the two (my current configuration):
options rtl8723be ant_sel=2 swenc=Y fwlps=0 ips=0
I rebooted after changes to make sure they took effect.
They all perform similarly.
Any thoughts on what I should try?
Here is the info from the requested commands:
01:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
Subsystem: Hewlett-Packard Company RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [103c:832a]
02:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8723DE 802.11b/g/n PCIe Adapter [10ec:d723]
  *-network
       physical id: 0
       bus info: pci@0000:01:00.0
       logical name: eno1
       version: 15
       serial: 48:ba:4e:e8:96:1c
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=MII
       resources: irq:16 ioport:4000(size=256) memory:b1104000-b1104fff memory:b1100000-b1103fff
  *-network
       product: RTL8723DE 802.11b/g/n PCIe Adapter
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: wlo1
       version: 00
       serial: d4:6a:6a:68:0c:d5
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=rtl8723de driverversion=5.3.0-26-generic firmware=N/A ip=192.168.1.127 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:130 ioport:3000(size=256) memory:b1000000-b100ffff
wlo1      IEEE 802.11  ESSID:"TheThinker"
          Mode:Managed  Frequency:2.447 GHz  Access Point: C0:56:27:C4:D2:57
          Bit Rate=150 Mb/s   Tx-Power=20 dBm
          Retry short limit:7   RTS thr=2347 B   Fragment thr:off
          Power Management:off
          Link Quality=42/70  Signal level=-68 dBm
          Tx excessive retries:0  Invalid misc:23   Missed beacon:0
eno1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 48:ba:4e:e8:96:1c  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 1068  bytes 114172 (114.1 KB)
        TX packets 1068  bytes 114172 (114.1 KB)
wlo1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.127  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::9e60:c990:915e:4261  prefixlen 64  scopeid 0x20<link>
        ether d4:6a:6a:68:0c:d5  txqueuelen 1000  (Ethernet)
        RX packets 26769  bytes 27459661 (27.4 MB)
        TX packets 24299  bytes 15069367 (15.0 MB)
wlo1      Scan completed :
          Cell 01 - Address: C0:56:27:C4:D2:57
                    Channel:8
                    Frequency:2.447 GHz (Channel 8)
                    Encryption key:on
                    ESSID:"TheThinker"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
                              9 Mb/s; 12 Mb/s; 18 Mb/s
                    Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
                    Mode:Master
                    Extra:tsf=000000f398fb7c74
                    Extra: Last beacon: 20ms ago
                    IE: Unknown: 000A5468655468696E6B6572
                    IE: Unknown: 010882848B960C121824
                    IE: Unknown: 030108
                    IE: Unknown: 0406000200000000
                    IE: Unknown: 2A0100
                    IE: Unknown: 32043048606C
                        Group Cipher : TKIP
                        Pairwise Ciphers (1) : CCMP
                    IE: Unknown: 2D1A6E1017FFFF000000000000000000000000000000000000000000
                    IE: Unknown: 3D1608070400000000000000000000000000000000000000
                    IE: Unknown: 4A0E14000A00B400C800140005001900
                    IE: Unknown: 7F0101
                    IE: Unknown: DD1E00904C336E1017FFFF000000000000000000000000000000000000000000
                    IE: Unknown: DD1A00904C3408070400000000000000000000000000000000000000
                    IE: Unknown: DD06005043030000
                    IE: WPA Version 1
                        Group Cipher : TKIP
                        Pairwise Ciphers (1) : TKIP
                    IE: Unknown: DD180050F2020101800003A4000027A4000042435E0062322F00
                    IE: Unknown: DD780050F204104A0001101044000102103B000103104700102802D00D0F67041970025D3CC8451293102100074C696E6B73797310230003574150102400033132331042000531323334351054000800060050F20400011011000A5468655468696E6B657210080002200C103C0001011049000600372A000120
          Cell 02 - Address: 0E:62:A6:AA:1F:4D
                    Channel:8
                    Quality=40/70  Signal level=-70 dBm
                    Encryption key:on
                    ESSID:""
                    Mode:Master
                    Extra:tsf=000000f399158064
                    Extra: Last beacon: 152ms ago
                    IE: Unknown: 0000
                    IE: Unknown: 010882848B968C129824
                    IE: Unknown: 030108
                    IE: Unknown: 050400010000
                    IE: Unknown: 0721555320010B802401802801802C01803001809501809901809D0180A10180A50180
                    IE: Unknown: 2A0104
                        Group Cipher : CCMP
                    IE: Unknown: 2D1A2C081FFFFF0000000000000000B80B0100000000000000000000
                    IE: Unknown: 3204B048606C
                    IE: Unknown: 3D1608000000000000000000000000000000000000000000
                    IE: Unknown: DD180050F2020101800003A4000027A4000042435D0061112E00
                    IE: Unknown: DD370050F204104A00011010440001021049000600372A0001201011000F3439222054434C20526F6B752054561054000800070050F2040001
                    IE: Unknown: DD12506F9A09020200210B0306000E62A6AA1F4D
                    IE: Unknown: DD0D506F9A0A00000601111C440032
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
« Last Edit: January 24, 2020, 07:11:27 pm by dgregory »
Offline kendall
  • Co-Founder
Re: Peppermint 10 issues with RTL8723DE
« Reply #1 on: January 24, 2020, 07:36:23 pm »
Hmmmmm.....
Try downloading the rtl8723be files from the following link, put them in the /etc/firmware/rtlwifi directory (create it if it doesn't exist), and reboot your system.
https://github.com/lwfinger/rtlwifi_new/tree/master/firmware/rtlwifi
After that, recheck and see if it's any better.
Offline dgregory
« Reply #2 on: January 25, 2020, 09:58:37 pm »
Thanks for the info.
I grabbed the 2 firmware files. tried them together. one at a time. and with/without the modprode settings... no difference.
After some more poking around I decided to just buy a Panda USB wifi dongle that just works on payday.
So my somewhat related question is once I get the dongle, and set the wifi connection to use the new connection, is it helpful to remove the RTL driver?  I don't use Bluetooth on my system, but I may want to in the future...
Offline kendall
  • Co-Founder
« Reply #3 on: January 26, 2020, 12:35:33 pm »
The OS kernel shouldn't be using the driver for the new hardware so it shouldn't matter if it's there or not. That said, personally I would remove it just to have a clean system.
Offline dgregory
« Reply #4 on: January 27, 2020, 06:13:49 pm »
Good point.  Thanks.
