Author Topic: grub problem after installing peppermint 10 respin on acer aspire one  (Read 695 times)
Offline alpage2
  • Peppermint version(s): 10R 32bit
I used the USB Image Writer tool on an original Peppermint 10 (64bit) to create a usb installer for the recent peppermint 10 Respin - 32 bit version, for installing on an old acer aspire one netbook, model AOA 110-Ap, which had been able to run peppermint 9 - 32bit, just fine.
The install appeared to go fine and finished by requiring a reboot into the new system, but on rebooting, and every subsequent boot, I just get a black screen with the message:
error: symbol 'grub_file_filters_all' not found
grub rescue>
I'd be grateful for some help as to how to resolve this.
Thanks
Alan
Offline Howling Wolf
Re: grub problem after installing peppermint 10 respin on acer aspire one
« Reply #1 on: January 12, 2020, 12:57:03 pm »
Hi,
1) did you wipe out the HDD before installing (IMHO it is recommeded)
2) during installation, you have to check carefully where the grub will be put (/sda recommended, without any number after sda)
3) did you test the integrity of the installer file (I mean SHA etc., recommended also)
4) I suggest check the above and try once more. Let us know what happened.
Offline rayzer
  • Graphics n Stuff
« Reply #3 on: January 17, 2020, 12:47:05 pm »
i use the rescatux live iso to fix grub issues, you can check it out here
https://www.supergrubdisk.org/rescatux/
