Author Topic: Install Deepin Desktop in Peppermint (Deepermint haha)  (Read 2034 times)
Offline fak77a
  • Peppermint version(s): 5,6,10s
« on: January 06, 2020, 08:16:55 am »
-Screenshots
 :) Hello Peppermint Friend's
-To type:
Add repository:
sudo add-apt-repository ppa:leaeasy/dde
Update the system pack manager:
sudo apt-get update
Install Deepin Desktop:
sudo apt-get install dde
Deepin File Manager:
sudo apt-get install dde-file-manager
Deepind Desktop Theme:
sudo apt install deepin-gtk-them---------------------------------
To change wallpapers
Sudo nemo
/usr/share/backgrounds
Deepin Wallpapers Default
https://drive.google.com/open?id=1EEMoGJB6ZwlERfnbvpRevliH2auYNTmq
https://drive.google.com/open?id=0B8PlygiBTIzBUm1SekdEYllLUWs
https://drive.google.com/open?id=1zI3FW3Ao_jyWrIz9lA77yu3w7CSXWUCK
https://drive.google.com/open?id=16-D3qnzIcigsSWDnZSwFaX_4vINdQRZv
https://drive.google.com/open?id=0B8PlygiBTIzBWVVFV0RDZ1FlWVk
https://drive.google.com/open?id=0B8PlygiBTIzBR3hvQ2pabDYybEE
Just copy the images to the folder and then you have it at the background wallpapers by default
A perfect OS with a good-looking alternative !!  :-*  :P  ;D
Congrats for Peppermint 10 spin
« Last Edit: March 27, 2020, 05:20:22 pm by spence »
Offline Johan
Re: Install Deepin Desktop in Peppermint (without Issues and Extra's)
« Reply #1 on: January 07, 2020, 12:27:30 pm »
Screenshot please?
Offline fak77a
Re: Install Deepin Desktop in Peppermint (Deepermint haha)
« Reply #3 on: January 07, 2020, 03:43:28 pm »
Hi bro!!  :D  - Sorry I'm having troubles with the Dropbox UI, exactly with the file permission option
-Screenshots
https://www.dropbox.com/s/dw1zwqlg4z9ajrs/DeepinScreenshot_20200106125736.png?dl=0
https://www.dropbox.com/s/xi4pvjrexj2hvio/DeepinScreenshot_20200106125817.png?dl=0
https://www.dropbox.com/s/3svio5die8z0z3t/DeepinScreenshot_20200107195547.png?dl=0
Hi fak77a, how's it going?  To post images to this site, you need to use an image hosting site, such as Imgur: imgur.com or Postimage.org: postimage.org.  Upload your image(s) to these sites.  These are good sites to make SSBs with the Ice tool for future use  ;).  You will find links to your images already formatted for different uses.  From Imgur, choose the one for BBCode (message boards & forums).  From Postimage.org, choose the one named  Link and click on the icon to the far right to copy the link.  Paste them into the forum editor.  You do not need to encapsulate the link from imgur.  The link from Postimage.org, needs to be encapsulated with the forum’s image function.  This is found under the B bold function at the left end of the formatting tools icons.   I suggest you have a play around to familiarise yourself with the site’s functions and the image hosting sites’ links.  These sites frequently change the formats.  Use the Preview button in the forum editor to check how they look.  I hope this helps  ;).
Offline fak77a
« Reply #4 on: January 07, 2020, 04:24:02 pm »
Hello AndyInMokum , Thank u for the advice - It's now working with Imgur.com - Down vote for Dropbox hahaha  8)
 I was going to use Mega (drive) but I didn't know If it's forum-compatible - Till later buddies
« Last Edit: January 07, 2020, 04:41:01 pm by fak77a »
Offline ryos
  • Hola amigos (:
« Reply #5 on: March 27, 2020, 04:55:12 pm »
Hi :D
It looks pretty good, but how many RAM does that DE (deepin) is using compared to the default Peppermint DE?  :P
Software Libre & Comunidad
« Reply #6 on: March 27, 2020, 05:26:11 pm »
Hello and Welcome to our forum @fak77a!
In the future, please remember to use the forum tools above the message composition box when copying and pasting terminal outputs, it helps keep the readout formatted properly. Specifically the # button above the laughing and angry emojis...
I've fixed it for you this time around.    ;)
Sorta curious why you like this combo?
& '18 Asus VivoBook
