Author Topic: HDMI not working? (SOLVED)  (Read 311 times)
Offline Peewee_1985
« on: January 01, 2020, 03:57:54 pm »
Happy new year!
HI there folks,
I was just wondering if you could help me.
Today I tried to connect my laptop to a TV screen with the HDMI cable and, to my surprise (back in the windows days it worked) it's not recognizing the computer.
SInce it worked a couple of months ago on WIndows I don't think the issue might be the cable...
Any idea?
Thanks a lot for your great distro and support.
Xavi
« Last Edit: January 15, 2020, 02:49:26 pm by Peewee_1985 »
Re: HDMI not working?
« Reply #1 on: January 01, 2020, 06:20:13 pm »
Hi Peewee_1985
Can we have the terminal output please from
So we can better understand the machine you are using and it's spec
Offline Peewee_1985
« Reply #2 on: January 02, 2020, 04:37:47 am »
Sure!
System:    Host: xavi-NC-E1-572G-54208 Kernel: 5.0.0-37-generic x86_64 bits: 64
Machine:   Device: laptop System: Acer product: NC-E1-572G-54208 v: V2.17 serial: N/A
           Mobo: Acer model: EA50_HW v: V2.17 serial: N/A
           UEFI: Insyde v: V2.17 date: 09/02/2014
Battery    BAT1: charge: 31.6 Wh 100.0% condition: 31.6/37.0 Wh (85%)
CPU:       Dual core Intel Core i5-4200U (-MT-MCP-) cache: 3072 KB
           clock speeds: max: 2600 MHz 1: 2280 MHz 2: 2437 MHz 3: 1933 MHz
           4: 1969 MHz
Graphics:  Card-1: Intel Haswell-ULT Integrated Graphics Controller
           Card-2: Advanced Micro Devices [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / R7 M520]
           Display Server: x11 (X.Org 1.20.4 )
           drivers: modesetting,ati,radeon (unloaded: fbdev,vesa)
           Resolution: 1366x768@59.99hz
           OpenGL: renderer: Mesa DRI Intel Haswell Mobile version: 4.5 Mesa 19.0.8
Audio:     Card-1 Intel 8 Series HD Audio Controller driver: snd_hda_intel
           Card-2 Intel Haswell-ULT HD Audio Controller driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k5.0.0-37-generic
Network:   Card-1: Broadcom and subsidiaries NetXtreme BCM57786 Gigabit Ethernet PCIe
           driver: tg3
           IF: enp1s0f0 state: down mac: <filter>
           Card-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
           driver: ath9k
Drives:    HDD Total Size: 240.1GB (8.3% used)
           ID-1: /dev/sda model: KINGSTON_SA400S3 size: 240.1GB
Partition: ID-1: / size: 219G used: 19G (9%) fs: ext4 dev: /dev/sda2
Sensors:   System Temperatures: cpu: 35.0C mobo: N/A gpu: 25.0
Info:      Processes: 207 Uptime: 2 min Memory: 867.2/7853.5MB
Thanks a lot for your help, Zeb.
« Last Edit: January 02, 2020, 06:23:17 am by AndyInMokum »
« Reply #3 on: January 02, 2020, 11:58:03 am »
Hi peewee_1985
Now can I have the output from
xrandr
when the external TV screen is attached by the hdmi cable and is switched on please
Offline Peewee_1985
« Reply #4 on: January 02, 2020, 12:14:35 pm »
Thanks!
There you go:
Screen 0: minimum 320 x 200, current 1366 x 768, maximum 8192 x 8192
eDP-1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 345mm x 194mm
   1366x768      59.99*+
   1360x768      59.80    59.96
   1280x720      60.00    59.99    59.86    59.74
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   1024x576      59.95    59.96    59.90    59.82
   960x600       59.93    60.00
   960x540       59.96    59.99    59.63    59.82
   800x600       60.00    60.32    56.25
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   640x360       59.86    59.83    59.84    59.32
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
HDMI-2 disconnected (normal left inverted right x axis y axis)
« Reply #5 on: January 02, 2020, 03:06:44 pm »
The fact that xrandr is only showing one display means either the cable is faulty / the hdmi out on the laptop or the hdmi in on the TV
Do you have another cable and or another monitor to test the laptop with.
Offline Peewee_1985
« Reply #6 on: January 02, 2020, 03:15:11 pm »
I will try then!
Thanks again, Zeb. :)
Offline Peewee_1985
« Reply #7 on: January 15, 2020, 02:49:02 pm »
Back again!
Zeb, you were right.
The issue was the cable. A new one works perfectly.
Thanks for your kind help.
