Author Topic: Reminder to mark solved problems as (SOLVED).  (Read 13494 times)
Offline kendall
  • Co-Founder
« on: March 13, 2014, 10:16:27 am »
Hello all.
Just a quick reminder to everyone that when you have a resolution to your issue, please edit the post title to mark the problem as (SOLVED). We ask that you do this for a few reasons.
  • People volunteering support can skip over a solved problem in order to focus on unresolved issues.
  • Users looking for a solution to the same problem or a similar one can know to look in your post.
  • When someone performs a web search for the problem, they'll know which posts they can go to for accurate information.
  • Forum mods and admins can more easily archive and/or catalog properly labeled posts.
We're here to help so please help us to better help you by keeping things clean and organized.
Thanks a bunch.
Re: Reminder to mark solved problems as (SOLVED).
« Reply #1 on: April 07, 2014, 05:37:26 pm »
To mark a topic solved, please edit the FIRST posting in the topic and append (SOLVED) to the end of the "Subject" line, then save.
Be sure to add it to the FIRST posting in the topic, not the last.
Thanks in advance :)
