Author Topic: Can I manually upgrade Peppermint 10 to Peppermint 10 Respin ?  (Read 2094 times)
« on: December 30, 2019, 06:37:00 pm »
Here are the instructions to manually upgrade Peppermint 10 to Peppermint 10 Respin .. you use these at your own risk, but they should be safe enough (I've tested them in a VM).
First of all MAKE SURE PEPPERMINT 10 IS FULLY UPDATED before you begin below
Now in Peppermint 10, open a terminal and run:
gksudo xed /etc/apt/sources.list.d/peppermint.list
and make it read:-
deb http://ppa.launchpad.net/peppermintos/p10-release/ubuntu bionic main
# deb-src http://ppa.launchpad.net/peppermintos/p10-release/ubuntu bionic main
deb http://ppa.launchpad.net/peppermintos/p10-respin/ubuntu bionic main
# deb-src http://ppa.launchpad.net/peppermintos/p10-respin/ubuntu bionic main
Back in the terminal run:
gksudo xed /etc/apt/sources.list.d/peppermint.list.save
and make it read:-
sudo rm -v /etc/skel/.local/share/applications/spidersolitaire.desktop
then:
sudo rm -v /etc/skel/.local/share/applications/solitaire.desktop
then:
sudo apt-get update
then:
sudo apt-get dist-upgrade
then:
sudo apt-get remove --purge pulseaudio-equalizer
then:
sudo apt-get autoremove
then:
sudo apt-get install --reinstall arc-color-gtk-themes p7zip-full peppermint-browser-manager peppermint-cursor-resizer peppermint-keyring pulseaudio-equalizer
Now go to:-
Menu > Settings > Customise Look and Feel
and on the "Widget" tab, select the "Arc-Red-Dark" theme, and "Apply" it.
gksudo xed /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf
and make it read:-
# trackpoint users want wheel emulation
Section "InputClass"
Identifier "trackpoint catchall"
MatchIsPointer "true"
MatchProduct "TrackPoint|DualPoint Stick"
MatchDevicePath "/dev/input/event*"
Option "Emulate3Buttons" "true"
Option "EmulateWheel" "true"
Option "EmulateWheelButton" "2"
Option "XAxisMapping" "6 7"
Option "YAxisMapping" "4 5"
EndSection
REBOOT.
Once rebooted, run:
sudo apt-get install --reinstall pepirus-icon-theme peppermint-firefox-themer peppermint-thunderbird-themer ice advert-block peppermint-default-settings peppermint-default-session peppermint-settings-panel peppermint-system pulseaudio-equalizer
then:
xfce4-panel -r
Now go to:-
Menu > Settings > Peppermint Control Center
and on the "Window Manager" tab, set:-
Theme: Arc-Red-Xfwm4
then close the control center.
sudo mv -v /etc/skel/.local/share/applications/solitaire.desktop.dpkg-dist /etc/skel/.local/share/applications/solitaire.desktop
then:
sudo mv -v /etc/skel/.local/share/applications/solitaire.desktop.dpkg-new /etc/skel/.local/share/applications/solitaire.desktop
then:
sudo mv -v /etc/xdg/menus/peppermint-hierarchical.menu.dpkg-dist /etc/xdg/menus/peppermint-hierarchical.menu
then:
sudo mv -v /etc/xdg/menus/peppermint-hierarchical.menu.dpkg-new /etc/xdg/menus/peppermint-hierarchical.menu
(if any or all of those last four commands fail, don't worry about it .. it just means the files didn't need renaming)
Open:-
Menu > Internet > Ice
select the "Remove" tab .. and delete/remove the "Solitaire" and "Spider Solitaire" SSB's
then close ICE
Back in a terminal add the two new SSB's by running:
cp -v /etc/skel/.local/share/applications/pinball.desktop ~/.local/share/applications/pinball.desktop
then:
cp -v /etc/skel/.local/share/applications/solitaire.desktop ~/.local/share/applications/solitaire.desktop
and just in case anything got stuck, run these 4 commands in sequence:
sudo dpkg --configure -a
then:
sudo apt-get update
then:
sudo apt-get upgrade
then finally:
Okay at this point you're pretty much done, except you may want to resize the whiskermenu slightly as the theme change may have left it a bit too tall for its default contents.
« Last Edit: December 31, 2019, 05:45:42 am by PCNetSpec »
Re: Can I manually upgrade Peppermint 10 to Peppermint 10 Respin ?
« Reply #1 on: December 30, 2019, 11:55:19 pm »
Hi
Only one issue for me
zebedee@threadripper-2950x ~ $ cp -v /etc/skel/.local/share/applications/solitaire.desktop ~/.local/share/applications/solitaire.desktop
cp: cannot stat '/etc/skel/.local/share/applications/solitaire.desktop': No such file or directory
during one of the terminal sessions you had a usual "what do you want to do" questions - the default being "N" - I think answering No, maybe why, Solitaire is now not there ?
PS - Thank you so much for doing these upgrade instructions.    I hope your back is on the mend too  :)
« Last Edit: December 31, 2019, 12:04:11 am by zebedeeboss »
Offline franksmcb
« Reply #2 on: December 31, 2019, 01:39:59 am »
I followed the process as written.
I had the same experiences as Zeb.
Well done! Thank you
This was done on a Dell Inspiron 15 which had been installed with Peppermint 10
« Reply #3 on: December 31, 2019, 05:01:46 am »
what's the output from:
ls /etc/skel/.local/share/applications
« Reply #4 on: December 31, 2019, 05:03:50 am »
zebedee@threadripper-2950x ~ $ ls /etc/skel/.local/share/applications
betterthanchess.desktop  firefoxsend.desktop        mahjong.desktop                    mimeapps.list
dlnnetwork.desktop       firstpersontetris.desktop  microsoftexcelonline.desktop       onlineuserguide.desktop
editorbypixlr.desktop    gmail.desktop              microsoftonenoteonline.desktop     peppermintforum.desktop
entanglement.desktop     googlecalendar.desktop     microsoftpowerpointonline.desktop  pinball.desktop
expressbypixlr.desktop   googledrive.desktop        microsoftwordonline.desktop        solitaire.desktop.dpkg-dist
« Reply #5 on: December 31, 2019, 05:14:04 am »
Run:
and can you now confirm that
Menu > Games > Solitaire
takes you to a solitaire game with a wooden background ?
Can you also confirm whether you get ANY output from:
« Last Edit: December 31, 2019, 05:24:01 am by PCNetSpec »
« Reply #6 on: December 31, 2019, 05:17:46 am »
zebedee@threadripper-2950x ~ $ sudo mv - /etc/skel/.local/share/applications/solitaire.desktop.dpkg-dist /etc/skel/.local/share/applications/solitaire.desktop
[sudo] password for zebedee:
mv: target '/etc/skel/.local/share/applications/solitaire.desktop' is not a directory
« Reply #7 on: December 31, 2019, 05:24:40 am »
Fixed command in last response .. please try again.
« Reply #8 on: December 31, 2019, 05:26:17 am »
Yeah, that fixed it and nothing from running dpkg command
« Reply #9 on: December 31, 2019, 05:27:40 am »
Does the solitaire SSB have a wooden background when started .. ie. is it the new one (with the wooden background) ?
If you're not sure what I'm asking, please post the output from:
cat ~/.local/share/applications/solitaire.desktop
« Last Edit: December 31, 2019, 05:30:40 am by PCNetSpec »
« Reply #10 on: December 31, 2019, 05:35:45 am »
I think it's Laminate not Wood though  :P
« Reply #11 on: December 31, 2019, 05:37:07 am »
Perfect, thanks .. I'll now fix the original instructions :)
« Reply #12 on: December 31, 2019, 02:25:26 pm »
Just now completed the upgrade to P 10R. Boots up super quick and only thing I notice is the nemo creep I was complaining about in the P 10 upgrade from P 9, that is items take a couple of seconds to load up, is still present. I won't know if there is any freezing involved until I do some heavy modifying of files, etc. I was hoping the creep would be gone but it's not.
Offline mintspider
  • Solus Budgie - Peppermint - Linux User
    • Spider's Webtrail
  • Peppermint version(s): 10R
« Reply #13 on: December 31, 2019, 06:47:55 pm »
Mark, perfect instructions!
Alienware M15x laptop is now manually upgraded to Peppermint 10 respin.
Such a wonderful New Year gift!!!  8)
Scotsman in Kentucky
Solus and Peppermint User
BDLL Tester
Believer in Jesus Christ
Offline stevesveryown
  • Peppermint Fan
    • stevesveryown
« Reply #14 on: January 01, 2020, 04:12:54 pm »
Thanks Mark!  All went well on the laptop.  Question, do I have to make fresh ICE SSBs to take advantage of the bug fix?  I'm still having the same issues in my original Facebook SSB.
