Author Topic: Can't access VirtualBox shared folder  (Read 349 times)
Offline pstrg
« on: December 29, 2019, 07:59:16 am »
Installed Peppermint on VirtualBox (6.1.0) running on Windows 10 - very smooth.
Next, installed VirtualBox Guest Additions, so that a new folder sf_lin-win started appearing to me after reboot.
However, when I tried to make that folder the Firefox download folder I got
Error opening directory '/media/sf_lin-win': Permission denied.
p.s. Should I inform I'm a Linux newbie?
Offline pstrg
Re: Can't access VirtualBox shared folder
« Reply #1 on: December 29, 2019, 03:04:08 pm »
Well... solved it by myself.
For the sake of other clueless newbies like me: what I did was just to add my username to group vboxsf, which is automatically created by VirtualBox.
sudo usermod -aG vboxsf <username>
sudo reboot
Now, why on Hell (or Heaven, I'm not sure where) do Ubuntu-based distros perform so differently from one another?
What I did is not necessary on some... it's really confusing.
Offline clatterfordslim
« Reply #2 on: December 30, 2019, 01:30:23 am »
sudo reboot
Yes all you have to do is add yourself to VirtualBox users in
Menu/System/Users and Groups
Choose
Manage Groups
Scroll down to
vboxusers
Then
Left Click Properties
Tick the box under
Group MembersThe one next to your usermame
Click OK
Pop in your Password and click OK
Reboot your system and fire up Virtualbox and then you can add external devices.  :)
But so is this Forum :)
