Author Topic: Installation does not finiz at the end  (Read 616 times)
Offline sisqonrw
« on: December 15, 2019, 12:13:11 pm »
hi,
i can not install on my asus x541U notebook peppermint os
i have also the same problem with ubuntu mate, lubuntu, LXLE, etc.
at the end of the installation where he copy the data he does not finish. it still stay there. the here
https://photos.app.goo.gl/tbQescR1LLguTcie7
what is the problem here? how can i solve it.
i like peppermint. i try it on a live usb it is very fast and nice.
Re: Installation does not finiz at the end
« Reply #1 on: December 15, 2019, 12:56:58 pm »
Do you know how to add a kernel boot parameter ?
if so adding these 2 parameters:-
pci=noaer pcie_aspm=off
does it install now ?
« Last Edit: December 15, 2019, 01:00:16 pm by PCNetSpec »
Offline sisqonrw
« Reply #2 on: December 15, 2019, 02:12:39 pm »
hi,
where can i type it?
how can i go there?
there is no OS on this notebook.
« Reply #3 on: December 16, 2019, 03:14:22 am »
Boot to the Peppermint LiveUSB .. when you get to the screen where it offers you "Try Peppermint" and "Install Peppermint" ..  hit the "Tab" key
You'll then see some white writing at the bottom of screen that ends with
quiet splash --instead make it end with
quiet splash pci=noaer pcie_aspm=off -- pci=noaer pcie_aspm=offthen hit Enter to continue booting.
Now see if the installation will finish.
NOTE (further information):-
Adding boot parameters on a LiveUSB BEFORE the "--" delimiter tells the kernel to use the parameter on the Live session, adding it a second time AFTER the "--" delimiter causes it to get added to the:-
GRUB_CMDLINE_LINUX=""
line of
/etc/default/grub
OF THE INSTALLED OS (should you install from that Live session).
Offline sisqonrw
« Reply #4 on: December 16, 2019, 08:40:36 am »
it works, but after installation. it is everything very slow. not like on the live usb version.
is peppermint not fast.
i have an asus notebook X541U
intel core i3 6006U, 2,0 GHz
8GB RAM
1 TB HDD
it isnt an old notebook. pretty new.
Offline The Omen
« Reply #5 on: December 16, 2019, 09:09:11 am »
To help you with slowness, can you please copy and paste the following commands into your terminal and post them back here in the forum so we can all see what might be causing you this kinda problem.
inxi -Fxzd
systemd-analyze
systemd-analyze blame
systemd-analyze critical-chainAlso any desktop applications too.
ls /usr/share/applications | awk -F '.desktop' ' { print $1}' -
Thank-you,
The Omen
« Last Edit: December 16, 2019, 09:43:07 am by The Omen »
« Reply #6 on: December 16, 2019, 10:54:37 am »
Can you post the contents of
xed /etc/default/gruband the output from:
dmesg | grep -i "error\|fail\|warn"
Offline sisqonrw
« Reply #7 on: December 16, 2019, 11:04:14 am »
inxi -Fxzd
System:    Host: ali-X541UAK Kernel: 4.18.0-18-generic i686 bits: 32 gcc: 7.3.0
Machine:   Device: laptop System: ASUSTeK product: X541UAK v: 1.0 serial: N/A
           Mobo: ASUSTeK model: X541UAK v: 1.0 serial: N/A
           UEFI [Legacy]: American Megatrends v: X541UAK.303 date: 03/30/2017
Battery    BAT0: charge: 32.7 Wh 97.1% condition: 33.7/34.6 Wh (97%)
           model: ASUSTeK ASUS status: Not charging
CPU:       Dual core Intel Core i3-6006U (-MT-MCP-)
           arch: Skylake rev.3 cache: 3072 KB
           flags: (lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 7968
           clock speeds: max: 2000 MHz 1: 798 MHz 2: 798 MHz 3: 798 MHz 4: 798 MHz
Graphics:  Card: Intel Skylake GT2 [HD Graphics 520] bus-ID: 00:02.0
           Resolution: 1366x768@60.05hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2) x86/MMX/SSE2
           version: 4.5 Mesa 18.2.8 Direct Render: Yes
Audio:     Card Intel Sunrise Point-LP HD Audio
           driver: snd_hda_intel bus-ID: 00:1f.3
           Sound: Advanced Linux Sound Architecture v: k4.18.0-18-generic
Network:   Card-1: Realtek RTL810xE PCIE Fast Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 02:00.2
           IF: enp2s0f2 state: down mac: <filter>
           Card-2: Realtek RTL8723BE PCIe Wireless Network Adapter
           driver: rtl8723be port: d000 bus-ID: 03:00.0
Drives:    HDD Total Size: 1008.0GB (0.7% used)
           ID-1: /dev/sda model: ST1000LM035 size: 1000.2GB
           ID-2: USB /dev/sdb model: Transcend_8GB size: 7.8GB
           Optical-1: /dev/sr0 model: HL-DT-ST DVDRAM GUE1N
           rev: AS00 dev-links: cdrom,cdrw,dvd,dvdrw
           Features: speed: 24x multisession: yes
           audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
Partition: ID-1: / size: 916G used: 6.2G (1%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 31.5C mobo: N/A
Info:      Processes: 191 Uptime: 2:39 Memory: 598.2/7913.2MB
           Init: systemd runlevel: 5 Gcc sys: 7.4.0
           Client: Shell (bash 4.4.191) inxi: 2.3.56
systemd-analyze
Startup finished in 7.185s (kernel) + 6min 37.118s (userspace) = 6min 44.304s
graphical.target reached after 6min 37.108s in userspace
     3min 1.977s snapd.seeded.service
      3min 497ms smbd.service
    1min 42.796s mintsystem.service
    1min 30.226s nmbd.service
         33.026s udisks2.service
         31.965s networkd-dispatcher.service
         31.363s NetworkManager-wait-online.service
         31.354s NetworkManager.service
         31.349s grub-common.service
         29.083s wpa_supplicant.service
         26.749s ModemManager.service
         25.614s accounts-daemon.service
         25.397s upower.service
         24.564s lm-sensors.service
         22.948s lightdm.service
         22.942s plymouth-quit-wait.service
         22.192s dev-sda1.device
         15.569s polkit.service
         12.096s apparmor.service
         10.781s systemd-udevd.service
         10.315s systemd-sysctl.service
          9.234s plymouth-read-write.service
          7.599s alsa-restore.service
          6.475s ntp.service
          6.261s run-rpc_pipefs.mount
The time after the unit is active or started is printed after the "@" character.
The time the unit takes to start is printed after the "+" character.
graphical.target @6min 37.108s
└─multi-user.target @6min 37.108s
  └─snapd.seeded.service @3min 35.129s +3min 1.977s
    └─snapd.service @3min 35.351s +3.496s
      └─basic.target @29.512s
        └─sockets.target @29.512s
          └─snapd.socket @29.499s +12ms
            └─sysinit.target @29.474s
              └─apparmor.service @9.174s +12.096s
                └─local-fs.target @9.172s
                  └─local-fs-pre.target @9.172s
                    └─keyboard-setup.service @3.307s +5.864s
                      └─systemd-journald.socket @3.255s
                        └─system.slice @3.255s
                          └─-.slice @3.233s
advert-block
arandr
blueman-adapters
blueman-manager
ca.desrt.dconf-editor
compton
debian-uxterm
debian-xterm
defaults.list
dropbox
exo-file-manager
exo-mail-reader
exo-preferred-applications
exo-terminal-emulator
exo-web-browser
file-roller
firefox
flatpak-launchers
gcr-prompter
gcr-viewer
gdebi
gksu
gnome-disk-image-mounter
gnome-disk-image-writer
gnome-language-selector
gnome-search-tool
gnome-software-local-file
gucharmap
gufw
guvcview
hplj1020
htop
ice
im-config
lightdm-settings
light-locker-settings
lxappearance
lxsession-default-apps
mate-calc
menulibre
metacity
mimeinfo.cache
mintinstall
mintinstall-fp-handler
mintinstall-kde
mintstick
mintstick-format
mintUpdate
nemo-autorun-software
nemo-autostart
nemo
network
nitrogen
nm-applet
nm-connection-editor
notification-daemon
numix-folders
org.gnome.DiskUtility
org.gnome.FileRoller
org.gnome.Software
org.gnome.Software.Editor
panel
panel-preferences
pavucontrol
peppermint-control-center
peppermint-firefox-themer
peppermint-font-dpi-settings
peppermint-logout
peppermint-proxy-configuration
peppermint-screenlock
peppermint-scrot-helper
peppermint-settings-panel
peppermint-system-info
peppermint-thunderbird-themer
pulseaudio-equalizer
python2.7
python3.6
sakura
shares
simple-scan
snap-handle-link
snap-launchers
software-properties-drivers
software-properties-gtk
synaptic
system-config-printer
system-config-samba
time
transmission-gtk
users
xdg
xed
xfce4-accessibility-settings
xfce4-appfinder
xfce4-mime-settings
xfce4-notifyd-config
xfce4-power-manager-settings
xfce4-run
xfce4-screenshooter
xfce4-settings-editor
xfce4-taskmanager
xfce-display-settings
xfce-keyboard-settings
xfce-mouse-settings
xfce-settings-manager
xfce-ui-settings
xfce-wm-settings
xfce-wmtweaks-settings
xfce-workspaces-settings
xfpanel-switch
xplayer
xreader
xviewer
yad-icon-browser
yelp
Offline sisqonrw
« Reply #8 on: December 16, 2019, 11:05:59 am »
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX="pci=noaer pci_aspm=off"
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
[    0.959878] tpm tpm0: A TPM error (-1) occurred attempting the self test
[    0.964489] tpm tpm0: A TPM error (-1) occurred attempting the self test
[    0.964497] tpm_crb: probe of MSFT0101:00 failed with error -1
[    7.309454] random: 7 urandom warning(s) missed due to ratelimiting
[   11.560262] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[   27.007419] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 1425.705496] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
« Reply #9 on: December 16, 2019, 01:49:32 pm »
Try this
run:
gksudo xed /etc/default/grubfind the line
GRUB_CMDLINE_LINUX="pci=noaer pci_aspm=off"and change it to
GRUB_CMDLINE_LINUX="pci=noaer"SAVE the file and exit the text editor.
Back in the terminal run:
sudo update-grubthen REBOOT.
Did that make any difference ?
Offline sisqonrw
« Reply #10 on: December 16, 2019, 02:35:48 pm »
hi thank you. i have edit it. i have to check it over many days. i think it is a little bit better.
« Reply #11 on: December 17, 2019, 01:06:00 am »
Hi sisqonrw,
Do you use/need snap packages? Or samba? If not, then you can also purge those from your system to see if that speeds things up (at least the boot process) for you.  ;)
Offline sisqonrw
« Reply #12 on: December 17, 2019, 05:12:09 am »
i dont use it. i will try it. thank you!
« Reply #13 on: December 17, 2019, 05:16:46 am »
You might also be able to get rid of the pci=noaer kernel boot parameter now .. but I suspect if you do that you'll end up with your log files growing uncontrollably with error report spam.
But you could temporarily remove it and see if it makes any difference.
