Author Topic: Having trouble installing drivers for Netgear WNDA3100v2  (Read 16185 times)
Re: Having trouble installing drivers for Netgear WNDA3100v2
« Reply #30 on: March 28, 2014, 05:07:09 pm »
OK, I'm stumped .. besides your phone using a different wireless channel, the signal strength, and the fact your phone is offering lower speeds connections I can see no difference.
Are you sure you haven't got something like mac address filtering switched on in the router ?
Maybe try changing the routers channel to 11 (or 1 as the phone is offering)
Offline LeMiguel72
« Reply #31 on: March 28, 2014, 05:14:15 pm »
I'm sure I don't have mac address filtering switched on, I just checked. Changing the routers channel to 1 or 11 doesn't do anything new either
« Reply #32 on: March 28, 2014, 05:19:25 pm »
OK, I'm outa ideas here
this adapter is one huge pain in Linux .. most people never get it working.
I'll keep looking for a while and post if I find anything useful, but I wouldn't hold your breath.
Is that the only wireless adapter you have ?
Offline LeMiguel72
« Reply #33 on: March 28, 2014, 05:34:20 pm »
I have a WiFiMAX adapter, but I only ever used that to connect my nintendo ds with.. can you work that?  :-\
Bus 001 Device 006: ID 0ace:1215 ZyDAS ZD1211B 802.11g
« Last Edit: March 28, 2014, 05:38:09 pm by LeMiguel72 »
« Reply #34 on: March 28, 2014, 06:05:45 pm »
Can you plug it in and post the output from:
lsusb
sudo lshw -C network
If it's what I think it is, it should work out of the box with the zd1211rw driver
0ACE:1215
maybe ?
Offline LeMiguel72
« Reply #35 on: March 28, 2014, 06:13:17 pm »
Bus 001 Device 007: ID 0ace:1215 ZyDAS ZD1211B 802.11g
  *-network
       physical id: 1
       bus info: usb@1:3
       logical name: wlan1
       serial: 00:0e:8e:0d:b4:02
       configuration: broadcast=yes driver=zd1211rw driverversion=3.8.0-35-generic firmware=4725 link=no multicast=yes wireless=IEEE 802.11bg
« Reply #36 on: March 28, 2014, 06:19:16 pm »
Looks like it's good to go .. will it connect ?
Offline LeMiguel72
« Reply #37 on: March 28, 2014, 06:23:00 pm »
Yeah.. it actually connected  :o The signal isn't that great, but hey-- it's working ;D
Thank you so much for your help!
« Reply #38 on: March 28, 2014, 06:44:55 pm »
No problem :)
