Author Topic: PM 6 and WiFi (Intel-Wireless 3165) - driver missing / No network [PAUSED]  (Read 614 times)
Offline LordKaan
  • Peppermint version(s): 6 and 10
Hi; Standard-Installation of PM-6 incl. updates and search 4 drivers
Wifi -Intel 3165 - Driver (seems so) still missing/ no Connections/No Networks see-able
Pls. don't feel disdurb by WiFi (Stick) (Card-2) RealLink RT2070 - the only stick, which always work
Pls. need help: How to download and install driver. Thx
System:    Host: Classic-C150 Kernel: 3.16.0-77-generic x86_64 (64 bit) Desktop: N/A Distro: Peppermint Six
Machine:   System: TREKSTOR product: Notebook Classic C150 version: Default string
           Mobo: TS_weibu model: Broadwell_C3U_V01 version: Default string
           Bios: American Megatrends version: Notebook Classic C150_V2.1.3 date: 08/20/2019
CPU:       Dual core Intel Core i3-5005U CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx)
           Clock Speeds: 1: 2000.312 MHz 2: 2000.078 MHz 3: 2000.00 MHz 4: 2000.00 MHz
Graphics:  Card: Intel Broadwell-U Integrated Graphics
           X.Org: 1.16.0 drivers: intel (unloaded: fbdev,vesa) Resolution: 1920x1080@60.0hz
           GLX Renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2) GLX Version: 3.0 Mesa 10.3.2
Audio:     Card-1: Intel Wildcat Point-LP High Definition Audio Controller driver: snd_hda_intel
           Card-2: Intel Broadwell-U Audio Controller driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture ver: k3.16.0-77-generic
Network:   Card-1: Intel Wireless 3165
           IF: N/A state: N/A mac: N/A
           Card-2: Ralink RT2070 Wireless Adapter driver: rt2800usb
           IF: wlan0 state: up mac: <filter>
Drives:    HDD Total Size: 512.1GB (0.8% used) 1: id: /dev/sda model: FORESEE_512GB_SS size: 512.1GB
Partition: ID: / size: 16G used: 3.9G (26%) fs: ext4
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C
Info:      Processes: 169 Uptime: 13 min Memory: 517.1/7900.3MB Client: Shell (bash) inxi: 1.9.17
« Last Edit: December 09, 2019, 02:22:37 pm by LordKaan »
Re: PM 6 and WiFi (Intel-Wireless 3165) - driver missing / No network
« Reply #1 on: December 01, 2019, 08:46:47 pm »
Can you see this posting please
https://forum.peppermintos.com/index.php/topic,6713.0.html
then post the relevant output back here.
Offline LordKaan
« Reply #2 on: December 02, 2019, 01:14:12 pm »
Datas from build in WiFi Card from Intel;
(and USB-Stick is just temporal=
and... again thx.
user@Classic-C150 ~ $ sudo lspci -vnn | grep -i net
[sudo] password for user: XYZ
01:00.0 Network controller [0280]: Intel Corporation Wireless 3165 [8086:3165] (rev 79)
user@Classic-C150 ~ $ sudo lshw -C network
  *-network UNGEFORDERT
       Beschreibung: Network controller
       Produkt: Wireless 3165
       Hersteller: Intel Corporation
       Physische ID: 0
       Bus-Informationen: pci@0000:01:00.0
       Version: 79
       Breite: 64 bits
       Takt: 33MHz
       Fähigkeiten: pm msi pciexpress cap_list
       Konfiguration: latency=0
       Ressourcen: memory:aa000000-aa001fff
  *-network
       Beschreibung: Kabellose Verbindung
       Physische ID: 2
       Bus-Informationen: usb@2:3
       Logischer Name: wlan0
       Seriennummer: c8:3a:35:c1:5d:b5
       Fähigkeiten: ethernet physical wireless
       Konfiguration: broadcast=yes driver=rt2800usb driverversion=3.16.0-77-generic firmware=0.29 ip=10.0.0.8 link=yes multicast=yes wireless=IEEE 802.11bg
user@Classic-C150 ~ $ iwconfig
wlan0     IEEE 802.11bg  ESSID:"A1-2f4721"
          Mode:Managed  Frequency:2.412 GHz  Access Point: 8C:59:C3:2F:47:25
          Bit Rate=36 Mb/s   Tx-Power=20 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality=61/70  Signal level=-49 dBm
          Tx excessive retries:5  Invalid misc:43   Missed beacon:0
user@Classic-C150 ~ $ ifconfig
lo        Link encap:Lokale Schleife
          inet Adresse:127.0.0.1  Maske:255.0.0.0
          inet6-Adresse: ::1/128 Gültigkeitsbereich:Maschine
          UP LOOPBACK RUNNING  MTU:65536  Metrik:1
          RX-Pakete:1512 Fehler:0 Verloren:0 Überläufe:0 Fenster:0
          TX-Pakete:1512 Fehler:0 Verloren:0 Überläufe:0 Träger:0
          Kollisionen:0 Sendewarteschlangenlänge:0
          RX-Bytes:136427 (136.4 KB)  TX-Bytes:136427 (136.4 KB)
wlan0     Link encap:Ethernet  Hardware Adresse c8:3a:35:c1:5d:b5
          inet Adresse:10.0.0.8  Bcast:10.0.0.255  Maske:255.255.255.0
          inet6-Adresse: fe80::ca3a:35ff:fec1:5db5/64 Gültigkeitsbereich:Verbindung
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metrik:1
          RX-Pakete:151341 Fehler:0 Verloren:0 Überläufe:0 Fenster:0
          TX-Pakete:94144 Fehler:0 Verloren:0 Überläufe:0 Träger:0
          Kollisionen:0 Sendewarteschlangenlänge:1000
          RX-Bytes:199835657 (199.8 MB)  TX-Bytes:11622363 (11.6 MB)
user@Classic-C150 ~ $ sudo iwlist scan
wlan0     Scan completed :
          Cell 01 - Address: 8C:59:C3:2F:47:25
                    Channel:1
                    Frequency:2.412 GHz (Channel 1)
                    Encryption key:on
                    ESSID:"A1-2f4721"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
                              24 Mb/s; 36 Mb/s; 54 Mb/s
                    Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s
                    Mode:Master
                    Extra:tsf=0000003c512b52b0
                    Extra: Last beacon: 40ms ago
                    IE: Unknown: 000941312D326634373231
                    IE: Unknown: 010882848B962430486C
                    IE: Unknown: 030101
                    IE: Unknown: 2A0104
                    IE: Unknown: 32040C121860
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                    IE: Unknown: 0B050400150000
                    IE: Unknown: 46053208010000
                    IE: Unknown: 2D1ABC081BFFFF000000000000000000000000000000000000000000
                    IE: Unknown: 3D1601001700000000000000000000000000000000000000
                    IE: Unknown: 7F03040008
                    IE: Unknown: DDAF0050F204104A00011010440001021041000100103B000103104700103D7D2F903A40576098093678EA196EDD1021000A414442204974616C6961102300065656323232301024001C504931373032363439303154303031303332362D56563232323076321042001C504931373032363439303154303031303332362D56563232323076321054000800060013C804000110110006565632323230100800020000103C0001011049000600372A000120
                    IE: Unknown: DD090010180204000C0000
                    IE: Unknown: DD180050F2020101880003A4000027A4000042435E0062322F00
          Cell 02 - Address: A0:8D:16:36:78:08
                    Channel:1
                    Quality=27/70  Signal level=-83 dBm
                    Encryption key:on
                    ESSID:"3WebCube7805"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s
                              18 Mb/s; 36 Mb/s; 54 Mb/s
                    Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s
                    Mode:Master
                    Extra:tsf=0000068f87b1416f
                    Extra: Last beacon: 556ms ago
                    IE: Unknown: 000C335765624375626537383035
                    IE: Unknown: 010882848B961224486C
                    IE: Unknown: 030101
                    IE: Unknown: 32040C183060
                    IE: Unknown: 0706415420010D14
                    IE: Unknown: 33082001020304050607
                    IE: Unknown: 33082105060708090A0B
                    IE: Unknown: 050400010008
                    IE: Unknown: 2A0104
                    IE: Unknown: 2D1A8E1117FFFF0000010000000000000000000000000C0000000000
                    IE: Unknown: 3D1601000000000000000000000000000000000000000000
                    IE: Unknown: 4A0E14000A002C01C800140005001900
                    IE: Unknown: 7F0101
                        Group Cipher : CCMP
                    IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
                    IE: Unknown: 0B05000005127A
                    IE: Unknown: DD07000C4307000000
          Cell 03 - Address: 98:9B:CB:DC:81:3C
                    Channel:6
                    Frequency:2.437 GHz (Channel 6)
                    Quality=35/70  Signal level=-75 dBm
                    Encryption key:on
                    ESSID:"X2X"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
                              9 Mb/s; 12 Mb/s; 18 Mb/s
                    Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
                    Mode:Master
                    Extra:tsf=000000031ef91f22
                    IE: Unknown: 0003583258
                    IE: Unknown: 010882848B968C129824
                    IE: Unknown: 030106
                    IE: Unknown: 0706444520010D14
                    IE: Unknown: 2A0100
                    IE: Unknown: 3204B048606C
                    IE: Unknown: 0B050000E90000
                    IE: Unknown: 460573D000000C
                    IE: Unknown: 2D1AAD011BFFFFFF00000000000000000001000000000406E6470D00
                    IE: Unknown: 3D1606000100000000000000000000000000000000000000
                    IE: Unknown: 7F0805000F0000000040
                    IE: Unknown: DD0900037F01010000FF7F
                    IE: Unknown: DD0C00040E010102010000000000
                    IE: Unknown: DD168CFDF004000049000003020972010000000039000000
                    IE: Unknown: DD6F0050F204104A0001101044000102103B00010310470010D9D7259DDC58FCC282ED989BCBDC813C1021000341564D1023000446426F78102400043030303010420004303030301054000800060050F20400011011000446426F78100800022388103C0001031049000600372A000120
                        Group Cipher : CCMP
                    IE: Unknown: DD088CFDF00101020100
          Cell 04 - Address: 00:26:44:1F:CA:7B
                    Channel:6
                    Quality=33/70  Signal level=-77 dBm
                    Encryption key:on
                    ESSID:"Thomson9B81BC"
                    Mode:Master
                    Extra:tsf=00000194d16a731d
                    IE: Unknown: 000D54686F6D736F6E394238314243
                    IE: Unknown: 030106
                    IE: Unknown: 2A0100
                    IE: Unknown: 2F0100
                    IE: Unknown: DD060010180201F0
                    IE: WPA Version 1
                        Group Cipher : TKIP
                        Pairwise Ciphers (1) : TKIP
          Cell 05 - Address: E8:08:8B:26:34:1F
                    Channel:9
                    Frequency:2.452 GHz (Channel 9)
                    Quality=29/70  Signal level=-81 dBm
                    Encryption key:on
                    ESSID:"TMOBILE-85613"
                    Mode:Master
                    Extra:tsf=000001693b51d092
                    IE: Unknown: 000D544D4F42494C452D3835363133
                    IE: Unknown: 030109
                    IE: Unknown: 2A0100
                    IE: Unknown: 2F0100
                        Group Cipher : TKIP
                        Pairwise Ciphers (2) : CCMP TKIP
                    IE: Unknown: 2D1ABC191AFFFF000000000000000000000000000000000000000000
                    IE: Unknown: 3D1609080400000000000000000000000000000000000000
                    IE: Unknown: 7F080000000000000040
                    IE: Unknown: DD090010180201000C0000
                    IE: WPA Version 1
                        Group Cipher : TKIP
                    IE: Unknown: DD180050F2020101040003A4000027A4000042435E0062322F00
          Cell 06 - Address: 00:BE:3B:8D:82:17
                    Channel:10
                    Frequency:2.457 GHz (Channel 10)
                    Quality=53/70  Signal level=-57 dBm
                    Encryption key:on
                    ESSID:"HUAWEI-B525-8217"
                    Mode:Master
                    Extra:tsf=0000005ce086a4e3
                    IE: Unknown: 00104855415745492D423532352D38323137
                    IE: Unknown: 010882840B162430486C
                    IE: Unknown: 03010A
                    IE: Unknown: 2A0104
                        Group Cipher : CCMP
                    IE: Unknown: 0B050300170000
                    IE: Unknown: 2D1AFE191BFFFF000001000000000000000000000000000000000000
                    IE: Unknown: 3D160A0F1600000000000000000000000000000000000000
                    IE: Unknown: 7F080500080000000040
                    IE: Unknown: DD7A0050F204104A0001101044000102103B00010310470010D96C7EFC2F8938F1EFBD6E5148BFA81210210006487561776569102300064875617765691024000631323334353610420004313233341054000800060050F2040001101100084875617765694150100800020000103C0001031049000600372A000120
                    IE: Unknown: DD090010180203000C0000
                    IE: Unknown: DD180050F2020101840003A4000027A4000042435E0062322F00
          Cell 07 - Address: E2:28:6D:73:BD:E2
                    Channel:6
                    Quality=41/70  Signal level=-69 dBm
                    Encryption key:on
                    ESSID:"ROBERT"
                    Mode:Master
                    Extra:tsf=000008463380d380
                    Extra: Last beacon: 2672ms ago
                    IE: Unknown: 0006524F42455254
                    IE: Unknown: 030106
                    IE: Unknown: 050400010000
                    IE: Unknown: 2A0100
                    IE: Unknown: 0B050000E80000
                    IE: Unknown: 2D1AAD0903FFFFFFFF00000000000000000100000000000000000000
                    IE: Unknown: 3D1606001700000000000000000000000000000000000000
                    IE: Unknown: BF0CB2798B33AAFF0000AAFF0020
                    IE: Unknown: C005000000FCFF
                    IE: Unknown: DD1A00904C0408BF0CB2798B33AAFF0000AAFF0020C005000000FCFF
                    IE: Unknown: DD168CFDF004000049000003020972018C16000046000000
                    IE: Unknown: DD1D0050F204104A0001101044000102103C0001031049000600372A000120
                        Group Cipher : CCMP
          Cell 08 - Address: 9A:9B:CB:DC:81:3C
                    Channel:6
                    Encryption key:on
                    ESSID:"ROBERT"
                    Mode:Master
                    Extra:tsf=000000031efa0a6e
                    IE: Unknown: 030106
                    IE: Unknown: 2A0100
                    IE: Unknown: DD6F0050F204104A0001101044000102103B00010310470010B16112FD9E5B806702A7B70EEC0488E11021000341564D1023000446426F78102400043030303010420004303030301054000800060050F20400011011000446426F78100800022388103C0001031049000600372A000120
                        Group Cipher : CCMP
          Cell 09 - Address: 1E:12:B0:EE:3B:D1
                    Channel:10
                    Quality=45/70  Signal level=-65 dBm
                    Encryption key:on
                    ESSID:"\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00"
                    Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s
                    Mode:Master
                    Extra:tsf=0000005cdf1a904f
                    Extra: Last beacon: 1452ms ago
                    IE: Unknown: 0015000000000000000000000000000000000000000000
                    IE: Unknown: 01088C129824B048606C
                    IE: Unknown: 03010A
                    IE: Unknown: 050401020000
                    IE: Unknown: 2A0100
                        Group Cipher : CCMP
                    IE: Unknown: 2D1AAD0117FFFF000000000000000000000000000000000000000000
                    IE: Unknown: 3D160A080000000000000000000000000000000000000000
                    IE: Unknown: 7F0104
                    IE: Unknown: DD3C0050F204104A00011010440001021049000600372A00012010110014506574657273204669726520545620537469636B1054000800010050F2040009
                    IE: Unknown: DD090010180200001C0000
                    IE: Unknown: DD180050F2020101800003A4000027A4000042435E0062322F00
                    IE: Unknown: DD12506F9A0902020025AB0306001E12B0EEBBD1
user@Classic-C150 ~ $ rfkill list
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
« Reply #3 on: December 02, 2019, 05:13:09 pm »
can you post the output (if any) from
ls /lib/firmware | grep iwlwifi-7265
dmesg | grep -i "error\|fail\|warn\|iwlwifi\|firm"
This link is only here for my future reference
https://www.intel.com/content/www/us/en/support/articles/000005511/network-and-io/wireless-networking.html
Offline LordKaan
« Reply #4 on: December 02, 2019, 05:17:26 pm »
user@Classic-C150 ~ $ ls /lib/firmware | grep iwlwifi-7265
iwlwifi-7265-10.ucode
iwlwifi-7265-12.ucode
iwlwifi-7265-13.ucode
iwlwifi-7265-16.ucode
iwlwifi-7265-17.ucode
iwlwifi-7265-8.ucode
iwlwifi-7265-9.ucode
iwlwifi-7265D-10.ucode
iwlwifi-7265D-12.ucode
iwlwifi-7265D-13.ucode
iwlwifi-7265D-16.ucode
iwlwifi-7265D-29.ucode
user@Classic-C150 ~ $ dmesg | grep -i "error\|fail\|warn\|iwlwifi\|firm"
[    1.065061] ata2.00: failed to get NCQ Send/Recv Log Emask 0x1
[    1.066626] ata2.00: failed to get NCQ Send/Recv Log Emask 0x1
[    2.083978] EXT4-fs (sda8): re-mounted. Opts: errors=remount-ro
[    2.437382] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-1.10.3.11.e.bseq
[    2.523217] Bluetooth: hci0: Intel Bluetooth firmware patch completed and activated
[    2.527099] i2c_hid i2c-HTIX5288:00: error in i2c_hid_init_report size:4 / ret_size:5
[    2.540191] i2c_hid i2c-HTIX5288:00: error in i2c_hid_init_report size:4 / ret_size:3
[    2.708316] init: failsafe main process (651) killed by TERM signal
[   11.018995] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[   11.019794] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
« Reply #5 on: December 02, 2019, 05:48:08 pm »
Okay, run
cd /lib/firmware
sudo wget https://wireless.wiki.kernel.org/_media/en/users/drivers/iwlwifi-7265-ucode-25.30.14.0.tgz
sudo tar xvf iwlwifi-7265-ucode-25.30.14.0.tgz
sudo cp -v iwlwifi-7265-ucode-25.30.14.0/iwlwifi-7265-14.ucode ./
sudo cp -v iwlwifi-7265-ucode-25.30.14.0/iwlwifi-7265D-14.ucode ./
sudo rm -rv /lib/firmware/iwlwifi-7265-ucode-25.30.14.0
sudo rm -v /lib/firmware/iwlwifi-7265-ucode-25.30.14.0.tgz
okay now you should have the right firmware at least.
Now what happens if you run:
sudo modprobe iwlwifi
does wireless spring to life ?
Offline LordKaan
« Reply #6 on: December 02, 2019, 07:08:02 pm »
>>does wireless spring to life ?<<
Nope
and no output/msg. after:
(All steps made by copy&paste and "enter")
OT: But thx 4 ur quick return/taking care !!!!!!
« Reply #7 on: December 03, 2019, 05:51:46 am »
What's the output from:
And can you reboot .. then post the output from
lsmod
and do you get any output from:
modinfo iwlwifi | grep 3165
Something tells me the old version of iwlwifi you're using isn't aware of this new wifi adapter .. this would likely require a kernel update (or a newer version of Peppermint).
Is there any reason you're sticking with Pep6 ? .. which BTW is end of life, so won't be getting security updates (including the meltdown/spectre patches).
« Last Edit: December 03, 2019, 05:59:52 am by PCNetSpec »
Offline LordKaan
« Reply #8 on: December 03, 2019, 02:36:02 pm »
After reboot:
user@Classic-C150 ~ $ lsmod
Module                  Size  Used by
ctr                    13049  2
ccm                    17773  2
arc4                   12608  2
uvcvideo               81073  0
videobuf2_vmalloc      13216  1 uvcvideo
rt2800usb              27189  0
rtsx_usb_ms            18697  0
rt2x00usb              20742  1 rt2800usb
rtsx_usb_sdmmc         27787  0
memstick               16966  1 rtsx_usb_ms
rt2800lib              89076  1 rt2800usb
videobuf2_memops       13362  1 videobuf2_vmalloc
rt2x00lib              55307  3 rt2x00usb,rt2800lib,rt2800usb
videobuf2_core         59104  1 uvcvideo
v4l2_common            15681  1 videobuf2_core
rtsx_usb               20987  2 rtsx_usb_sdmmc,rtsx_usb_ms
mac80211              660855  3 rt2x00lib,rt2x00usb,rt2800lib
videodev              153793  3 uvcvideo,v4l2_common,videobuf2_core
media                  21903  2 uvcvideo,videodev
cfg80211              506619  2 mac80211,rt2x00lib
crc_ccitt              12707  1 rt2800lib
btusb                  32497  0
rfcomm                 69509  8
bnep                   19624  2
bluetooth             446409  22 bnep,btusb,rfcomm
6lowpan_iphc           18702  1 bluetooth
nls_iso8859_1          12713  1
joydev                 17393  0
snd_hda_codec_hdmi     47548  1
hid_multitouch         17419  0
intel_rapl             18783  0
x86_pkg_temp_thermal    14205  0
intel_powerclamp       18823  0
coretemp               13441  0
kvm_intel             143630  0
kvm                   456273  1 kvm_intel
crct10dif_pclmul       14307  0
crc32_pclmul           13133  0
aesni_intel           152552  5
aes_x86_64             17131  1 aesni_intel
lrw                    13286  1 aesni_intel
gf128mul               14951  1 lrw
glue_helper            13990  1 aesni_intel
ablk_helper            13597  1 aesni_intel
cryptd                 20359  2 aesni_intel,ablk_helper
serio_raw              13483  0
i915                  910411  7
snd_hda_codec_realtek    77696  1
shpchp                 37047  0
lpc_ich                21093  0
snd_hda_codec_generic    69011  1 snd_hda_codec_realtek
snd_soc_rt5640         93124  0
drm_kms_helper         61574  1 i915
snd_soc_rl6231         13037  1 snd_soc_rt5640
mei_me                 19696  0
snd_hda_intel          30549  5
mei                    87875  1 mei_me
snd_hda_controller     30228  1 snd_hda_intel
snd_hda_codec         139719  5 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel,snd_hda_controller
drm                   311061  6 i915,drm_kms_helper
snd_soc_core          200418  1 snd_soc_rt5640
snd_hwdep              17698  1 snd_hda_codec
i2c_algo_bit           13413  1 i915
snd_compress           19200  1 snd_soc_core
snd_pcm_dmaengine      15172  1 snd_soc_core
snd_pcm               104112  7 snd_soc_rt5640,snd_soc_core,snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_controller,snd_pcm_dmaengine
snd_seq_midi           13564  0
snd_seq_midi_event     14899  1 snd_seq_midi
snd_rawmidi            31463  1 snd_seq_midi
snd_seq                62570  2 snd_seq_midi_event,snd_seq_midi
snd_seq_device         14497  3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer              29616  2 snd_pcm,snd_seq
snd                    79562  23 snd_hda_codec_realtek,snd_soc_core,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device,snd_compress
soundcore              15047  2 snd,snd_hda_codec
i2c_hid                18726  0
dw_dmac                12835  0
dw_dmac_core           24251  1 dw_dmac
video                  20128  1 i915
snd_soc_sst_acpi       13007  0
parport_pc             32741  0
8250_dw                13551  0
i2c_designware_platform    13025  0
i2c_designware_core    14768  1 i2c_designware_platform
spi_pxa2xx_platform    23079  0
ppdev                  17671  0
acpi_pad               17942  0
mac_hid                13227  0
lp                     17759  0
parport                42348  3 lp,ppdev,parport_pc
btrfs                 907733  0
xor                    21411  1 btrfs
hid_generic            12559  0
usbhid                 52616  0
hid                   110426  4 i2c_hid,hid_multitouch,hid_generic,usbhid
raid6_pq               97812  1 btrfs
ahci                   34142  2
libahci                32424  1 ahci
sdhci_acpi             13351  0
sdhci                  43693  1 sdhci_acpi
And no output
user@Classic-C150 ~ $ modinfo iwlwifi | grep 3165
« Last Edit: December 03, 2019, 02:39:32 pm by LordKaan »
Offline LordKaan
« Reply #9 on: December 03, 2019, 02:44:39 pm »
It's an "old" i3 - 7th generation
So... 3 or 4 years
You asked me once, and yep, i prefer PM 6;
inckls. the old chromium, and -maybe just a feeling.. but for me it feels "faster"/more stable (Programs)
Mint 17  and Lubuntu 16 have no probs.
And -maybe this helps: On Windows Side, he don't accept anymore 32-Bit
So,  we talked once about it; and at least (Thx. to your helps on the other stuffs...) i could use 10; but i would prefer 6
« Reply #10 on: December 03, 2019, 03:42:06 pm »
which Mint 17 ? .. 17.3 by any chance ?
In Peppermint, what's the output from:
Offline LordKaan
« Reply #11 on: December 03, 2019, 05:43:55 pm »
Linux Mint LXDE (Always "as small as poss")
LM 17.1 - installed with USB-WIFI-Stick incl. updates, while installing (afterwards no more Stick needed)
LM 17.3 - out of the Box
Source from LinuxMintUsers.de
(LXDE (unofficial) ist the smaller Version of xfce; p.a. startmenu with on row ; as i asked once earlier before)
And Sory; CPU (I3 ) is 5th Generation (not 7th, as i wrote before) - and !!!! it don't accept any 32 Bit
Inxi result of LM 17.3 LXDE - incl. WIFi-Mouse, excl. USB-WiFiStick
user@Classic-C150 ~ $ inxi -Fx
System:    Host: Classic-C150 Kernel: 4.4.0-81-generic x86_64 (64 bit gcc: 4.8.4)
           Desktop: LXDE (Openbox 3.5.2) Distro: Linux Mint 17.3 Rosa
Machine:   System: TREKSTOR product: Notebook Classic C150 v: Default string
           Mobo: TS_weibu model: Broadwell_C3U_V01 v: Default string
           Bios: American Megatrends v: Notebook Classic C150_V2.1.3 date: 08/20/2019
CPU:       Dual core Intel Core i3-5005U (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 7981
           clock speeds: max: 2000 MHz 1: 800 MHz 2: 801 MHz 3: 800 MHz
           4: 800 MHz
Graphics:  Card: Intel Broadwell-U Integrated Graphics bus-ID: 00:02.0
           Display Server: X.Org 1.18.3 drivers: intel (unloaded: fbdev,vesa)
           GLX Version: 3.0 Mesa 11.2.0 Direct Rendering: Yes
Audio:     Card-1 Intel Wildcat Point-LP High Definition Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0
           Card-2 Intel Broadwell-U Audio Controller
           driver: snd_hda_intel bus-ID: 00:03.0
           Sound: Advanced Linux Sound Architecture v: k4.4.0-81-generic
Network:   Card: Intel Wireless 3165 driver: iwlwifi bus-ID: 01:00.0
           IF: wlan0 state: up mac: dc:71:96:ce:56:99
Drives:    HDD Total Size: 542.9GB (1.4% used)
           ID-1: /dev/sda model: FORESEE_512GB_SS size: 512.1GB
           ID-2: USB /dev/sdb model: Ultra_USB_3.0 size: 30.8GB
Partition: ID-1: / size: 15G used: 5.4G (41%) fs: ext4 dev: /dev/sda12
Info:      Processes: 168 Uptime: 5 min Memory: 515.1/7899.1MB
           Init: Upstart runlevel: 2 Gcc sys: 4.8.4
           Client: Shell (bash 4.3.111) inxi: 2.2.28
inxi from PM6 incl. WiFi Mouse; booted with USB-WiFi-Stick
System:    Host: Classic-C150 Kernel: 3.16.0-77-generic x86_64 (64 bit, gcc: 4.8.4) Desktop: N/A Distro: Peppermint Six
CPU:       Dual core Intel Core i3-5005U CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 7980.82
           Clock Speeds: 1: 2000.156 MHz 2: 2000.078 MHz 3: 2000.312 MHz 4: 2000.078 MHz
           X.Org: 1.16.0 driver: intel Resolution: 1920x1080@60.0hz
           GLX Renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2) GLX Version: 3.0 Mesa 10.3.2 Direct Rendering: Yes
Audio:     Card-1: Intel Wildcat Point-LP High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Card-2: Intel Broadwell-U Audio Controller driver: snd_hda_intel bus-ID: 00:03.0
Network:   Card-1: Intel Wireless 3165 bus-ID: 01:00.0
           Card-2: Ralink RT2070 Wireless Adapter driver: rt2800usb ver: 2.3.0 usb-ID: 002-003
           IF: wlan0 state: up mac: c8:3a:35:c1:5d:b5
Drives:    HDD Total Size: 512.1GB (0.9% used) 1: id: /dev/sda model: FORESEE_512GB_SS size: 512.1GB
Partition: ID: / size: 16G used: 4.3G (29%) fs: ext4
Info:      Processes: 174 Uptime: 0 min Memory: 426.2/7900.3MB Runlevel: 2 Gcc sys: N/A
           Client: Shell (bash 4.3.11) inxi: 1.9.17
« Last Edit: December 03, 2019, 05:50:32 pm by LordKaan »
« Reply #12 on: December 03, 2019, 06:27:49 pm »
Okay I'm still lost as to which version of Mint worked with the wireless ?
As you can see, Mint 17.3 has a much more recent kernel than Peppermint 6
Now Mint 17.1 on the other hand came with the 3.13 kernel out of the box, but it MIGHT have been on the HWE meaning it would have a more recent kernel only after updates.
So what we really need to know is if Mint 17.1 worked BEFORE any updates .. my guess is not.
You might still be able to push 14.04 (and therefore Pep6) up to a more recent kernel by adding the HWE (aka. LTS Enablement Stack) .. try running the command for "MULTIARCH DESKTOP" under "Ubuntu 14.04 LTS - Trusty Tahr" here:
https://wiki.ubuntu.com/Kernel/LTSEnablementStack
then rebooting.
That should bump you up to the 4.4 kernel (as in Mint 17.3).
For clarity, this command:
sudo apt-get install --install-recommends linux-generic-lts-xenial xserver-xorg-core-lts-xenial xserver-xorg-lts-xenial xserver-xorg-video-all-lts-xenial xserver-xorg-input-all-lts-xenial libwayland-egl1-mesa-lts-xenial libgl1-mesa-glx-lts-xenial libgl1-mesa-glx-lts-xenial:i386 libglapi-mesa-lts-xenial:i386
« Last Edit: December 03, 2019, 06:31:42 pm by PCNetSpec »
Offline LordKaan
« Reply #13 on: December 05, 2019, 11:02:51 am »
I made as u wrote, but i got the error-msg
libgl1-mesa-glx-lts-xenial:i386 : Hängt ab von: libudev1:i386 soll aber nicht installiert werden
Means: Need "libudev1:i386", but it's not recommand to install
I searched on Softwaremanger for "libudev1:i386", and i found it, but i couldn't install it from there;
PM6 ist up to date (all green) by updatemanger
I got the same error-msg, when i tried the sudo from "Wiki-Ubuntu" -> "Ubuntu 14.04 LTS - Trusty Tahr" -> MULTIARCH DESKTOP
OT: Linux Mint 17.3 LXDE works fine; out of the Box (USB Stick made with "Rufus"  with the ISO; no updates while installing)
« Last Edit: December 05, 2019, 11:05:18 am by LordKaan »
« Reply #14 on: December 05, 2019, 01:19:59 pm »
so why exactly can't you install it .. I mean what's the output from:
sudo apt-get install libudev1:i386
That would be because 17.3 already had the HWE pre-applied .. I bet it wouldn't work in 17.0
