Author Topic: IPhone usb tethering not working [SOLVED]  (Read 370 times)
Offline Mat361
« on: November 22, 2019, 06:01:19 pm »
Hi everyone, I recently tried out some Linux distros and I have never had problems connecting my iPhone se for tethering via usb, I used Linux mint and Ubuntu 19.04 and lubuntu 19.04. Yesterday I installed peppermint 10 because I was curious and interested by its features.
When I tried to connect my iPhone tethering via usb nothing happened it didnít worked. I tried also to connect as a standard WiFi hotspot and there was no problem, it got connected to Internet.
So the problem is that it doesnít recognise the Ethernet via usb.
The laptop Iím using is a Samsung q310,  anyone can help me to sort this out? Iím sure is something to configure on the networking side, i have done some research but didnít found anything helpful.
Maybe it has to do something with the fast that peppermint is a light distro so it doesnít include some things pre installed on other distros.
Thanks to everyone in advance.
« Last Edit: November 23, 2019, 04:48:53 am by Mat361 »
Re: IPhone usb tethering not working
« Reply #1 on: November 22, 2019, 06:45:44 pm »
When you plug in your iPhone, does a message appear on the iPhone asking you if you want to accept the connection ?
Now I don't know if this is related (no longer own an iPhone so can't test), but some while ago we noticed a problem where the iPhone DCIM (camera) folder wouldn't show up when first connected .. you had to do this
https://forum.peppermintos.com/index.php/topic,6692.msg67924.html#msg67924
Offline rayzer
  • Graphics n Stuff
« Reply #2 on: November 23, 2019, 12:52:07 am »
had this issue a while back, there was 3 packages i had to install.. gigolo usbmuxd and libmobidevice (or however its spelled in synaptic). once those were installed it worked right away
Offline Mat361
« Reply #3 on: November 23, 2019, 04:33:07 am »
Yes, it appear that message, i give him the conset and then i can browse the DCIM folder from my laptop so there is no problem there
Offline Mat361
« Reply #4 on: November 23, 2019, 04:37:01 am »
Okay thankyou now i'll try this and see if it works
Offline Mat361
« Reply #5 on: November 23, 2019, 04:47:09 am »
I have installed this three packages and now it works, thanks a lot!
Re: IPhone usb tethering not working [SOLVED]
« Reply #6 on: November 23, 2019, 09:10:48 am »
Thanks rayzer :)
Can either of you say if gigolo absolutely necessary ?
The other 2 'library' type packages I could add to upcoming the Pep10 respin .. but I don't want to add gigolo as it's a GUI app and I'd have thought network-manager would have been able to do the same thing anyway (?)
In fact - is the only package necessary usbmuxd ?
« Last Edit: November 23, 2019, 09:18:32 am by PCNetSpec »
Offline rayzer
  • Graphics n Stuff
« Reply #7 on: November 23, 2019, 01:09:10 pm »
not entirely sure but i went with that during troubleshooting my own issues
