Author Topic: New SSD Slower Than Mechanical Drive [SOLVED]  (Read 784 times)
Offline jlschwartz
  • Forum User
« on: November 21, 2019, 09:12:17 pm »
I just installed a new Crucial SSD cloned from a mechanical drive with Peppermint 10.  It seems run slower than my old drive.  Any thoughts how to speed it up?  Thanks.  See my system specs:
[code]
System:    Host: jls-X130e-P10 Kernel: 5.0.0-36-generic x86_64 bits: 64 gcc: 7.4.0
Machine:   Device: laptop System: LENOVO product: 062223U v: ThinkPad X130e serial: N/A
           Mobo: LENOVO model: 062223U serial: N/A
           UEFI [Legacy]: LENOVO v: 8RET54WW (1.17 ) date: 10/24/2012
Battery    BAT1: charge: 43.9 Wh 100.0% condition: 43.9/57.7 Wh (76%)
           model: LGC 42T4961 status: Charging
CPU:       Dual core AMD E-450 APU with Radeon HD Graphics (-MCP-)
           arch: Bobcat rev.0 cache: 512 KB
           flags: (lm nx sse sse2 sse3 sse4a ssse3 svm) bmips: 6585
           clock speeds: max: 1650 MHz 1: 1646 MHz 2: 1317 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Wrestler [Radeon HD 6320]
           bus-ID: 00:01.0
           Display Server: x11 (X.Org 1.20.4 )
           drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
           Resolution: 1366x768@60.02hz
           OpenGL: renderer: AMD PALM (DRM 2.50.0 / 5.0.0-36-generic, LLVM 8.0.0)
           version: 3.3 Mesa 19.0.8 Direct Render: Yes
Audio:     Card-1 Advanced Micro Devices [AMD/ATI] Wrestler HDMI Audio
           driver: snd_hda_intel bus-ID: 00:01.1
           Card-2 Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA)
           driver: snd_hda_intel bus-ID: 00:14.2
           Sound: Advanced Linux Sound Architecture v: k5.0.0-36-generic
Network:   Card-1: Realtek RTL8188CE 802.11b/g/n WiFi Adapter
           driver: rtl8192ce port: 3000 bus-ID: 01:00.0
           IF: wlp1s0 state: up mac: <filter>
           Card-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet
           driver: atl1c v: 1.0.1.1-NAPI port: 2000 bus-ID: 02:00.0
Drives:    HDD Total Size: 500.1GB (3.9% used)
           ID-1: /dev/sda model: CT500MX500SSD1 size: 500.1GB
Partition: ID-1: / size: 86G used: 18G (23%) fs: ext4 dev: /dev/sda5
Sensors:   System Temperatures: cpu: 60.0C mobo: 0.0C gpu: 61.0
           Fan Speeds (in rpm): cpu: 569
Repos:     Active apt sources in file: /etc/apt/sources.list
           deb http://mirrors.rit.edu/ubuntu/ bionic restricted main
           deb http://mirrors.rit.edu/ubuntu/ bionic-updates restricted main
           deb http://mirrors.rit.edu/ubuntu/ bionic universe
           deb http://mirrors.rit.edu/ubuntu/ bionic-updates universe
           deb http://mirrors.rit.edu/ubuntu/ bionic multiverse
           deb http://mirrors.rit.edu/ubuntu/ bionic-updates multiverse
           deb http://mirrors.rit.edu/ubuntu/ bionic-backports restricted universe multiverse main
           deb http://archive.canonical.com/ubuntu bionic partner
           deb http://mirrors.rit.edu/ubuntu/ bionic-security restricted main
           deb http://mirrors.rit.edu/ubuntu/ bionic-security universe
           deb http://mirrors.rit.edu/ubuntu/ bionic-security multiverse
           Active apt sources in file: /etc/apt/sources.list.d/peppermint.list
           deb http://ppa.launchpad.net/peppermintos/p10-release/ubuntu bionic main
           Active apt sources in file: /etc/apt/sources.list.d/teejee2008-ubuntu-ppa-bionic.list
           deb http://ppa.launchpad.net/teejee2008/ppa/ubuntu bionic main
Info:      Processes: 176 Uptime: 32 min Memory: 1384.9/7571.8MB
           Init: systemd runlevel: 5 Gcc sys: 7.4.0
           Client: Shell (bash 4.4.201) inxi: 2.3.56
« Last Edit: November 22, 2019, 11:07:33 am by jlschwartz »
Offline clatterfordslim
Re: New SSD Slower Than Mechanical Drive
« Reply #1 on: November 22, 2019, 01:43:41 am »
Hello jlschwartz, The problem with SSD's is that they need time to adjust, when did you clone it over to SSD? Plus I wonder because where you cloned it from old spinning drive, that it replicated the speed of the drive too? Could it do that?  what I have found here could be the answer that your SSD was not aligned properly before cloning. Link Below
https://www.reddit.com/r/techsupport/comments/32ws3k/very_slow_ssd_after_cloning_os_from_hdd/  ;D
But so is this Forum :)
« Reply #2 on: November 22, 2019, 03:28:29 am »
I have never had to wait for any of my SSD's to adjust ?
The problem may be cloning, that is not to say others havn't,   I have never successfully "cloned" an install.
For me clean and hose and then report back is it still slow.
Online PCNetSpec
« Reply #3 on: November 22, 2019, 08:48:15 am »
Can  you define "slower" .. do you just mean boot times ?
I'm gonna guess something changed in the cloning process, such as UUID's .. either do as Zeb suggests and do a full fresh install (after clearing the SSD by creating a new GPT partition table in GParted run from a LiveUSB), or post the output from:
sudo fdisk -l
sudo blkid
cat /etc/fstab
df -h
cat /etc/initramfs-tools/conf.d/resume
dmesg | egrep -i "error|fail|warn"
systemd-analyze blame
systemd-analyze critical-chain
« Last Edit: November 22, 2019, 08:52:36 am by PCNetSpec »
« Reply #4 on: November 22, 2019, 09:18:26 am »
I was just about to ask the same question, but when I went to submit it, SMF said you beat me to it   :D
@jlschwartz: Do you mean boot times are slow - or things are lagging out while you're in a session - etc?
Also, which cloning software did you use???
If you used the free cloning software that came with the Crucial SSD - I've read many, many, complaints about it NOT cloning the drive correctly - mostly from winders users. As a matter of fact, it's sort of a universal criticism - great drive, but crappy cloning software...
I must say, the only cloning software that has ever worked for me, every time, is Clonezilla.
IMO, the Clonezilla UI has always been a kludge and it's counterintuitive, but I haven't found anything else that actually WORKS better.
That said, I had a hella time installing PM10 on my Asus Eee PC. Luckily, before I started the PM10 install, I had cloned my old PM ver using Clonezilla. LoL.
I must have restored my original clone/backup 5 times, with success, before I finally got PM10 working. It was very reassuring to know that I hadn't wiped out years of haxoring, if it turned out that PM10 wouldn't work on my Eee PC
Clonezilla is your friend.  I'll stop now...   :)
Offline jlschwartz
  • Forum User
« Reply #5 on: November 22, 2019, 10:13:51 am »
Thanks for all the ideas.  It turns out the UUID for the swap partition was not the same as blkid.  I changed that and it made a huge difference.  :)  I think I'm ok now.  For what it's worth, Clonezilla was used to clone the drive.  This is an old Lenovo x130e laptop that only has Sata II so it will never be as fast as Sata III but at least it's a bit faster.  Before I made this change it took over a minute for the bar to go across on the starting screen.  Now the starting screen flies by.   ;D
Online PCNetSpec
« Reply #6 on: November 22, 2019, 11:00:21 am »
Great news :)
Can you please remember to mark the topic (SOLVED) .. TIA ;)
« Last Edit: November 22, 2019, 11:03:33 am by PCNetSpec »
Offline mintspider
  • Solus Budgie - Peppermint - Linux User
    • Spider's Webtrail
  • Peppermint version(s): 10R
« Reply #7 on: November 24, 2019, 03:28:20 pm »
Clonezilla is awesome!
I use it often for creating backup images, and also when replacing a HD or SSD.
Yesterday I updated my wife's Window's 8.1 Alienware Area 51 desktop from a 128GB SSD (which is now running Peppermint 10 in a laptop) with a 2TB SSD.
Clonezilla worked perfectly.
Scotsman in Kentucky
Solus and Peppermint User
BDLL Tester
Believer in Jesus Christ
Online PCNetSpec
Re: New SSD Slower Than Mechanical Drive [SOLVED]
« Reply #8 on: November 24, 2019, 05:21:38 pm »
Yep, perfect tool for cloning to a drive that's equal to or larger in capacity .. but I've personally never managed to get it to clone to a smaller drive adjusting partition sizes on the fly (even where the used space should have left enough room .. if that made sense).
I'm not saying that function never works, just that it's never worked for me .. IIRC that function is still marked as 'experimental' (or it was the last time I tried it).
« Last Edit: November 24, 2019, 05:23:55 pm by PCNetSpec »
« Reply #9 on: January 15, 2020, 02:46:01 pm »
Hi Jlschwartz, you may also need to change the UUID's in your initramfs-tools/conf.d/resume file. I had a similar problem that I resolved by fixing that.
Offline az2020
« Reply #10 on: January 30, 2020, 10:05:16 am »
I know this is an older thread, but I'm using my first SSD and installing Peppermint 10 today (after speed dating a dozen distros the past few days). I found this guide for optimizing SSD for Linux, and plan to follow it (mainly the part about trimming. Also "swappiness" sounds important. I have gobs of memory, so I won't have a swap partition. And, some tips about configuring your web browser not to beat on the drive so much.).
BTW: That guide says Linux will align partitions (apparently that used to be something you were supposed to do yourself.). I was thinking that's what @clatterfordslim meant by "time to adjust." (But, I don't know anything about it. First SSD for me.).
Offline Jack
  • Peppermint version(s): for working
« Reply #11 on: March 19, 2020, 07:37:28 am »
The issue with SSD's is that they need time to alter, when did you clone it over to SSD? Furthermore I wonder since where you cloned it from old turning drive, that it imitated the speed of the drive as well?
« Reply #12 on: March 19, 2020, 05:04:47 pm »
And perhaps the sound of the spinning disk as well ??  ::) :D
