Author Topic: Saving for a brand new desktop pc.  (Read 11707 times)
Offline iamesperambient
  • a totally awesome dude
Re: Saving for a brand new desktop pc.
« Reply #45 on: September 01, 2014, 09:18:51 am »
im totally lost as far as finding a new computer....im scared ill make a purchase and it won't be what i'm looking for.
im also not sure if i trust buying something used on ebay i dont really like ebay in general.
http://iamesper.bandcamp.com
boring drone music from NJ
rjm65
  • Guest
« Reply #46 on: September 01, 2014, 10:00:20 am »
Well then expect to pay full price then, I can't see a difference in walmart selling a refurbished or used off lease machine and or a guy on ebay doing the same thing...  Only difference is the guy on ebay is selling it cheaper then walmart or other stores are selling it...  I can only steer you towards a deal, I can't make you take advantage of it....
Offline 10i
  • Peppermint Enthusiast
    • My Peppermint Blog
« Reply #47 on: September 01, 2014, 10:13:04 am »
Why not burn a live cd, or make a live install usb drive - and take it to a pc shop that sells the model you want. Ask if you can boot and test it.
That way you know everything works.
Peppermint user since Fire / Ice
« Reply #48 on: September 01, 2014, 10:35:25 am »
i'll look into it, im going to take a few months of research and testing before i buy the desktop.
for now i need to find a 500 gig external drive that will plug  in and go with linux (if anyone can recommend
one you all know works with peppermint 5) and i'm trying to find a docking station for my laptop (dell latitude d630
but cant seem to find out if its exactly for this model and it they come with the power suppy) at least for now
with a external i will have more storage (which i need) and i will be able to power it on and off with out
opening the lid with the docking station i suppose i will just connect my monitor from that also.
if anyone can help me source those 2 items i would be greatful.
« Reply #49 on: September 01, 2014, 11:51:54 am »
http://www.ebay.com/itm/Dell-OptiPlex-755-Tower-Core-2-Duo-E6550-2-33GHz-3GB-160GB-DVD-Linux-Ubuntu-01-/351141633195?_trksid=p2054897.l5667 considering this as an option
seems like a good deal im iffy on ebay but may be worth buying considering the price.
