Author Topic: Can't choose partition for installation  (Read 2960 times)
Offline RTCarman
  • Peppermint version(s): OS7
« on: November 17, 2019, 06:10:56 am »
Hi -
  I have an HP h9-1215t with 2 TB drive, 32GB RAM, NVidia Ti-1050 video card. I recently added a Soundblaster Zx card to replace the onboard sound. My system currently has Windows 10 home and Peppermint 8.0 (P08). Dual-booting works fine, but my Peppermint 8 can't find or use my sound card. I tried running Peppermint 10 (P10) without installing and it finds my SoundBlaster Zx card and gives me sound. So, I want to add Peppermint 10 on a new partition and also keep my Windows and Peppermint 8.
   The P08 drive partition was 340 GB. I split it using GParted into two 170 GB partitions. I labeled the partitions as P08 and P10.  The P10 partition is ext4. When I run the installation of Peppermint 10, I do not get the option of installing to the new partition. If I chose to do something else, the drive diagram only shows one partition for Peppermint 8, it doesn't show a P08 and P10.
    How do I get Peppermint 10 to install on the P10 partition? I have a LOT of data on my HDD and do not want to lose it. I have backed up most of it, but still...
    Thanks for any help beforehand.
Have a nice day. - Rich
Re: Can't choose partition for installation
« Reply #1 on: November 17, 2019, 11:51:40 am »
Hi RTCarman, is your harddrive file system MBR or GPT? I'm guessing it's GPT. How much of the P 8 partition is used? My idea would be to end up with three ext4 partitions. two of about 30gb and the last with the rest. I would want to end up with P 8 on one partition of 30gb, P10 on another 30gb partition and the remaining partition as a DATA partition. With a DATA partition, you can symlink your home folders of as many linux distros you have installed on your harddrive and your home folders, or files, would be the same on all. It might take a little bit of work to get there, but it's doable. Food for thought, and any help you need getting there, we're here. There are many guys here that have such a setup with multiple partitions with different distros, creating the DATA partition is key. Good luck.  :)
edited: forgot to ask, did you do your partitioning while booted into a live session?
« Last Edit: November 17, 2019, 12:00:41 pm by alynur »
« Reply #2 on: November 17, 2019, 12:58:20 pm »
From within PM8 (or from a PM10 LiveUSB), can you post the output from:
sudo fdisk -land
sudo blkid
Offline RTCarman
« Reply #3 on: November 18, 2019, 01:05:44 pm »
Wow - you guys give me a lot to think about.
Yes - my system is GPT.
I've given Windows about 1.5 TB of the drive (MANY photos and videos).
I've already used about 48 GB on the P08 partition.
The P10 partition is 170 GB, ext4 and unused.
Here is my report from Windows 10 Disk Management...
(sorry... can't figure out how to put my screenshot in here...)
I'll go to Peppermint 8 and try from there.
Offline RTCarman
« Reply #4 on: November 18, 2019, 01:20:13 pm »
Ok - I'm in Peppermint 8 - here is the results of "fdisk -l"
rtcarman@rtcarman-h9-1215t ~ $ sudo fdisk -l
[sudo] password for rtcarman:
Sorry, try again.
Disk /dev/sda: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Disklabel type: gpt
Disk identifier: 28D4D603-3F65-406A-9100-F2E7564FECE6
Device          Start        End    Sectors   Size Type
/dev/sda1        2048     206847     204800   100M EFI System
/dev/sda2      206848     468991     262144   128M Microsoft reserved
/dev/sda3      468992 3185878198 3185409207   1.5T Microsoft basic data
/dev/sda4  3185879040 3186941951    1062912   519M Windows recovery environment
/dev/sda5  3186944000 3518975249  332031250 158.3G Linux filesystem
/dev/sda6  3850926080 3871809535   20883456    10G Linux swap
/dev/sda7  3872731136 3907028991   34297856  16.4G Microsoft basic data
/dev/sda8  3518976000 3850926079  331950080 158.3G Linux filesystem
Partition table entries are not in disk order.
Disk /dev/sdb: 14.3 GiB, 15376000000 bytes, 30031250 sectors
Disklabel type: dos
Disk identifier: 0x76a0918b
Device     Boot Start      End  Sectors  Size Id Type
/dev/sdb1  *     2048 30029823 30027776 14.3G  c W95 FAT32 (LBA)
and here is the result of "blkid"
rtcarman@rtcarman-h9-1215t ~ $ sudo blkid
/dev/sda1: LABEL="SYSTEM" UUID="8CAD-A5FD" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="2d1ceaae-b781-4902-a933-3077520193a4"
/dev/sda3: LABEL="OS" UUID="4642158C421581BB" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="143e16ed-47ab-4db9-8afb-f708492b54e1"
/dev/sda4: UUID="BAD0E7D5D0E79643" TYPE="ntfs" PARTUUID="41ea5ab7-1280-4185-83ce-72002ffaeb5f"
/dev/sda5: UUID="963a3167-09bc-4ed7-8414-0d1197997c48" TYPE="ext4" PARTLABEL="Pep08" PARTUUID="797ffc5b-82c8-40f1-90da-6ea15438bf76"
/dev/sda6: UUID="aa543be5-3557-4ad1-afa1-fb6a534a303c" TYPE="swap" PARTUUID="3af600be-4410-4d6a-91d4-0350e2fe5833"
/dev/sda7: LABEL="HP_RECOVERY" UUID="BAD8EA7FD8EA38F1" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="870650e4-f4e8-4451-a1ba-aebf00209f8b"
/dev/sda8: LABEL="P10" UUID="bf88e8bc-21d8-4e36-af09-4ed7d1799dea" TYPE="ext4" PARTLABEL="Pep10" PARTUUID="d35922f7-9570-4875-8e57-96502ac2c6bc"
/dev/sdb1: LABEL="1A1FLASH" UUID="361D-0AC3" TYPE="vfat" PARTUUID="76a0918b-01"
/dev/sda2: PARTLABEL="Microsoft reserved partition" PARTUUID="8c9f91b2-3fc5-434f-b878-ea2c85f7b030"
I hope that helps.
Thank-you.
« Last Edit: November 18, 2019, 01:32:04 pm by zebedeeboss »
Offline RTCarman
« Reply #5 on: November 18, 2019, 01:23:51 pm »
So, I want to install Peppermint 10 on...
I will try running the install again and see what I get.
Sorry to be a pain guys. Thanks for your patience.
- Rich ;D
« Reply #6 on: November 18, 2019, 01:32:54 pm »
Hi
You need to encapsulate the terminal output with the Insert, Code # function.  For extra long outputs, please use the Spoiler, Sp function.  If you’re a Chromium Browser and/or a Google Chrome user, please don't combine these functions.  For some reason, they don’t work well together with these browsers.  The formatting gets all goofed up.  Only use one or the other  ;).  These forum functions preserve the original format of the output.  This makes it easier for future visitors to relate to their own issues.  These functions are found in the forum editor, above the,  :-[ Embarrassed and  the :'( Cry emoticon respectively.  Use the Preview button to check how it'll look after you post it to forum.  I hope this helps  ;).
I've done this for you this time.  Many thanks  :)
EDIT - I copied and pasted too much - this post is obviously not closed. Apologies.
« Last Edit: November 18, 2019, 03:29:13 pm by zebedeeboss »
Offline RTCarman
« Reply #7 on: November 18, 2019, 02:32:47 pm »
Zeb - First, my apology for my ignorance. I have no idea what this means... "You need to encapsulate the terminal output with the Insert, Code # function.  For extra long outputs, please use the Spoiler, Sp function.  ".  FYI, I use Mozilla.
Also, this issue is not resolved and I was going to post some screen shots of the issue, but I anticipate that you would not be happy with that.
Is there a YouTube video for n00bs on how to use your forum?  I have never had any computer training or Linux training and only use the computer a few times during the week. In the swimming pool of computer knowledge, I am wading at the low end of the pool.  I am learning as I go and just trying to slash a path through the jungle of Linux.
Thank you. Have a nice day.
« Reply #8 on: November 18, 2019, 02:47:56 pm »
Hi
No apology needed.  We all started out new at one time or another.
if you look along the row of icons you should see the # icon
This is the icon for  [code ] [ / code]   I have deliverately put spaces there else it will do its thing.    So when you copy and paste stuff from a terminal.  Copy    hit the little # icon and then place the cursor in the middle and then paste.
So instead of
random text here
line after line
after line
you get
random text here
line after line
after line
Does that explain it a little better ?
EDIT: I will produce a video on it tomorrow and will try and show what each part of that post I made meant :)
« Last Edit: November 18, 2019, 03:14:00 pm by zebedeeboss »
« Reply #9 on: November 18, 2019, 02:54:04 pm »
Plus screen shots are fine as long as you upload the images to a hosting service and then provide the links.
You cannot post screenshots direct to the forums.
There should be a video how to for that here  :)
https://forum.peppermintos.com/index.php/topic,7892.0.html
Offline RTCarman
« Reply #10 on: November 18, 2019, 05:25:13 pm »
Zeb -
   Thanks for your time.
   Ok - I understand both. Good explanation and good video from emegra. Kudos to you both.
- Rich
« Reply #11 on: November 18, 2019, 05:44:55 pm »
Here are photos of my hard drives, sda has my DATA partition while sdb has the various operating systems. All the operating systems are symlinked to the same DATA partition.
In your instance, if you were planning on creating a DATA partition, I would grow your p8 partition to 60gb, create a 10gb partition and leave the remainder as an ext4 partition. Once that was all done, I would boot up P 8 and create a DATA partition with symlinks of the last, largest partition which includes moving all your home folders and files to. Then I would shrink the P 8 partition and grow the smallest partition both to 35gb. and that would be that. Then you could install P 10 to the second 35gb partition and again create and symlink the DATA partition. Sound confusing? It is a little, but it's really easy.
« Reply #12 on: November 19, 2019, 12:45:15 am »
As promised, here is the short tutorial video
https://forum.peppermintos.com/index.php?topic=9040.new#new
Offline RTCarman
« Reply #13 on: November 19, 2019, 03:26:59 am »
Well, I thank you all for your input. This has been a real learning experience.
I obviously have to learn a lot more about the Peppermint Linux file system. I thought all the data for each distro is saved right on the partition for that distro. That's why I make my partitions so big. I'm into photography and videography - and so I make my partitions big enough to hold all that stuff. So, I am not sure why DATA drives and SWAP drives are needed. Also, it would be good if the P10 installation partition manager showed as much info as GParted.
Anyway, the snag I run into now is that I get the message
"No Root File System is defined. Please correct this from the Partitioning Menu."
My system boots up and gives me a choice of Peppermint or Windows. Therefore I must have a Root File System, right?
Thanks again for the help.
Offline RTCarman
« Reply #14 on: November 19, 2019, 03:49:14 am »
Okay - I created an Imgur acc. and managed to put up a screenshot of the error msg.
How do I tell where my root file system is?
Thanx
