Author Topic: Unable to install peppermint 10 on acer aspire one (SOLVED)  (Read 823 times)
Offline yo
« on: November 16, 2019, 09:31:50 am »
Hi,
First of all, sorry for my english.
I am trying to install Peppermint 10 on my notebook, Acer Aspire ONE 725 (Processor: AMD C60 64 bits, RAM: 4 GB, Graphics adapter: AMD Radeon HD 6290)
and I get a black screen with      do_IRQ: 1.55 No irq handler for vector  and ^[[D^[[D^[[D^[[D^[[D^[[D^[[D....
I tried to install peppermint from an usb drive and from an usb CD player and I also try Peppermint OS live.
I hope someone will be able to help me.
Thanks
« Last Edit: November 20, 2019, 04:07:41 am by yo »
Re: Unable to install peppermint 10 on acer aspire one
« Reply #1 on: November 16, 2019, 10:25:25 am »
Do you know how to add the:-
nomodeset
or
radeon.modeset=0
option to the kernel boot line ?
Offline yo
« Reply #2 on: November 16, 2019, 10:51:46 am »
No, I am new at this. How can I do that?
« Reply #3 on: November 16, 2019, 11:21:38 am »
Boot the LiveUSB or LiveDVD, and when you get to the "Try Peppermint / Install Peppermint" screen, hit the "Tab" key.
some white writing should appear at the bottom of the screen that ends with
quiet splash --
change that to end with:-
quiet splash nomodeset --
and hit "Enter" to continue booting.
did it boot this time ?
Offline yo
« Reply #4 on: November 16, 2019, 01:25:59 pm »
Yes, it booted. Now i am installing it.
Thank you very much
Offline yo
« Reply #5 on: November 16, 2019, 02:56:09 pm »
I installed it without any problem. But when i restarted, it said failed to start load/save  screen backlight brightness of backlight: acpi_video0
« Reply #6 on: November 16, 2019, 08:12:15 pm »
is the screen blank (as in a black screen but the backlight is still on) .. or is the backlight completely OFF ?
and can you boot to the LiveUSB (using the earlier fix again) and post the output from:
sudo fdisk -land
blkid
« Last Edit: November 16, 2019, 08:14:11 pm by PCNetSpec »
Offline yo
« Reply #7 on: November 17, 2019, 03:35:37 am »
Hi again!
It booted after a while and I installed some updates. Now it boot faster but the error is still there.
yo@yo ~ $ sudo fdisk -l
[sudo] contraseña para yo:
Disco /dev/sda: 232,9 GiB, 250059350016 bytes, 488397168 sectores
Unidades: sectores de 1 * 512 = 512 bytes
Tamaño de sector (lógico/físico): 512 bytes / 512 bytes
Tamaño de E/S (mínimo/óptimo): 512 bytes / 512 bytes
Tipo de etiqueta de disco: dos
Identificador del disco: 0x11028b93
Dispositivo Inicio Comienzo     Final  Sectores Tamaño Id Tipo
/dev/sda1   *          2048 488396799 488394752 232,9G 83 Linux
yo@yo ~ $ blkid
/dev/sda1: UUID="5a7a4a5e-1c93-4f55-8fa3-353bb265ee52" TYPE="ext4" PARTUUID="11028b93-01"
Thanks
« Reply #8 on: November 17, 2019, 10:37:25 am »
If you mean
it seems safe to ignore and is just a kernel message .. not an 'error'.
Offline yo
« Reply #9 on: November 17, 2019, 11:44:16 am »
Yes, I mean that message. Besides that it is working fine.
Thanks a lot.
« Reply #10 on: November 17, 2019, 11:57:52 am »
So it's booting normally now, or are you still unable to boot with a black screen ?
Offline yo
« Reply #11 on: November 17, 2019, 01:07:49 pm »
It is installed and booting normally.
