Author Topic: Unable to boot after using Systemback(SOLVED)  (Read 787 times)
Re: Unable to boot after using Systemback(SOLVED)
« Reply #15 on: November 16, 2019, 05:28:26 pm »
What happens if you try this:-
Boot the LiveUSB and run these commands in sequence:
sudo mount /dev/sdb2 /mnt
sudo mount /dev/sdb1 /mnt/boot/efi
gksudo xed /mnt/etc/fstab
when fstab opens make it read
# / was on /dev/sdb2 during installation
UUID=f4a64468-2bd4-450b-b573-3a1dd9ded925   /   ext4   noatime,errors=remount-ro   0   1
Back in the terminal run:
for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; done
sudo chroot /mnt
grub-install --efi-directory=/mnt/boot/efi
update-grub
then hit Ctrl+D (to exit the chroot environment)
and finally reboot without the LiveUSB (after setting sdb as the primary boot device in the BIOS).
This happens,
peppermint@peppermint ~ $ sudo mount /dev/sdb2 /mnt
peppermint@peppermint ~ $ sudo mount /dev/sdb1 /mnt/boot/efi
mount: /mnt/boot/efi: mount point does not exist.
peppermint@peppermint ~ $ sudo ls /mnt/boot/efi/EFI
ls: cannot access '/mnt/boot/efi/EFI': No such file or directory
peppermint@peppermint ~ $ for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; done
peppermint@peppermint ~ $ sudo chroot /mnt
root@peppermint / # grub-install --efi-directory=/mnt/boot/efi
Installing for x86_64-efi platform.
grub-install: error: failed to get canonical path of `/mnt/boot/efi'.
root@peppermint / # exit
To me this is showing that there is no efi directory in sdb2 /boot. I looked in my installed version of P 10 and it has an efi directory in /boot. That-s why I asked if we could copy it over some way. I was able to copy the directory to my Documents.
« Last Edit: November 16, 2019, 10:58:24 pm by alynur »
« Reply #16 on: November 16, 2019, 05:34:51 pm »
Make sure your BIOS is set to only boot in UEFI mode, not UEFI/Legacy.
« Reply #17 on: November 16, 2019, 05:44:51 pm »
Hi murraymint, I haven't been into my bios in a while, it could very well be set for UEFI/Legacy and the usb memory with the Systemback live image is just randomly booting into Legacy. I'll check that out now.
« Reply #18 on: November 16, 2019, 07:03:04 pm »
Yup that was it, my bios was set up for UEFI/Legacy. I switched it to UEFI only and the usb memory doesn't show up. Apparently Systemback is too old for UEFI, just like Unitbooten for installing from one partition into another. I took a Timeshift snapshot of the P 9 install I had just finished the last touches on, so we'll see if it will boot up after the snapshot is finished restoring. At least we know we can't recommend Systemback for a UEFI clone.  :'(
Offline clatterfordslim
« Reply #19 on: November 16, 2019, 07:39:13 pm »
Unfortunately Systemback only goes up to 4.4GB in ISO and for the life of me I could not get it going with Pep 10 only Pep 9 then upgraded to Pep 10 through PCNetSpec's upgrade tutorial.
But so is this Forum :)
« Reply #20 on: November 16, 2019, 10:56:10 pm »
I see where Systemback could be a real winner for cloning a not-too-big system that is going to be installed into a blank harddrive with an MBR file system. My live image was about 7.3g and would have had a better chance of working if it wasn't getting installed into a GPT file system. I was able to salvage the installation by restoring the last Timeshift snapshot I had taken of my laptop and then while still booted in P 10, mounting the systemback partition in nemo and changing the fstab to have the correct UUID numbers, including my DATA partition. When I rebooted, it booted right up, albeit a few seconds slower than before but that's no biggie. Everything is there, or here, I'm in it, P 9, now. I did have to rename my computer and host name and reestablish my symlinks for my home folders but the DATA partition was already there and ready to go. I'm especially happy because the nemo file system crawl that I was experiencing in the upgraded version of P 10, is not present. Yay! Bye the way, my fresh install of P 10 in sdb9 is starting to experience the nemo crawl and is getting worse.
I'll go ahead and mark this as solved since I accomplished what I was trying to do with a little bit of a work around. Thanks PCNetSpec and murraymint for your help, you guys pointed my thinking in the right direction. Peppermint people are the best!   :-*
« Reply #21 on: November 16, 2019, 11:10:50 pm »
Glad you got it sorted alynur, but I think murraymint deserves all the kudos for this one :)
« Reply #22 on: November 16, 2019, 11:19:22 pm »
Indeed he does, but you put some effort into it also.  ;)
« Reply #23 on: November 16, 2019, 11:29:37 pm »
Effort, but no cigar :))
« Reply #24 on: November 24, 2019, 09:39:55 pm »
As I had mentioned, before trying to boot into the systemback system, I changed the fstab file to reflect the proper UUID's of my hard drive and that bootup time was a few seconds slower. Well, it was actually about 40 seconds slower and that was starting to bother me, normal bootup was about 20 seconds. So I did a search for slow bootup in the forum search box and one of the listed posts was of the P 9 beta test by andymokum. In that it was discovered that not only in the fstab file did the correct UUID numbers have to be changed but also in the
initramfs-tools/conf.d/resume
  file. so I ran the code
sudo xed /etc/initramfs-tools/conf.d/resume
and made the necessary changes and then ran
sudo update-initramfs -uk all
Now my bootup is back to around 20 seconds. I am a happy camper!     :)
« Reply #25 on: November 24, 2019, 10:20:50 pm »
Glad you found the solution alynur .. that's what the forum is here for, a permanent repository of previously discovered solutions :)
« Last Edit: November 24, 2019, 10:22:22 pm by PCNetSpec »
