Author Topic: Launch using Dedicated Graphics Card  (Read 1101 times)
Offline ceaseuno
  • Peppermint version(s): peppermint 10
« on: November 08, 2019, 09:51:37 am »
Hello all,
I recently switch to Peppermint and was wondering if there is a way to launch application using the dedicated graphics card.
For instance, I have Steam and Civilization game series installed and I would like to launch the game using the dedicated graphics card. When I right click, I don't see any option for it.
Does peppermint support this?
Machine Info:
Dell Latitude E6530
Graphics: NVIDIA NVS 5200M 1GB
CPU: 3rd Gen i7
MemoryL 8GB
Thank you,
Cesar
Re: Launch using Dedicated Graphics Card
« Reply #1 on: November 08, 2019, 01:11:05 pm »
No...
You can switch between graphics adapters (intel/nvidia) in nvidia-settings, but this requires you log off and on again before the switch becomes active.
There is no way to switch on a 'per app' basis without logging off/on again.
I gather 'on demand' switching is now available in  Ubuntu 19.10 with the mate-optimus panel applet switcher, the 435 nvidia drivers, and the 5.3 kernel .. but I don't think there's any easy way to shoehorn all these into 18.04 (and hence Pep10) and have it work.
It will be coming in Pep11 though.
You can install mate-optimus if you wish
sudo apt-get install mate-optimusthen autostart it by running:
gksudo xed /etc/xdg/autostart/mate-optimus.desktopand when a blank file opens, make it read
[Desktop Entry]
Type=Application
Name=mate-optimus-applet
Comment=Launch the MATE Optimus panel applet
Icon=nvidia
Exec=/usr/lib/mate-optimus/mate-optimus-applet
Terminal=false
then log off/on.
You should now have a switcher in the system tray (by the clock) .. but it still requires you to log off/on between switches.
« Last Edit: November 08, 2019, 01:26:06 pm by PCNetSpec »
