Author Topic: External display problem  (Read 967 times)
Offline Ru5en
Re: External display problem
« Reply #15 on: November 22, 2019, 11:36:51 am »
Hello, tryed in ubuntu bugie and Manjaro os... the problem is the same...
« Reply #16 on: November 24, 2019, 08:24:34 am »
Okay let's create an xorg.conf file .. then later we can add a new modeline to it.
First write this bit down because you'll be without a GUI for a while.
Hit Ctrl+Alt+F2 (to drop to a console)
at the text console, log in.
Once logged in, run:
sudo service lightdm stopthen
X -configure(that's a capital X .. a space .. then -configure)
sudo service lightdm startand you should be back at your desktop.
Can you now post the contents of
xed ~/xorg.conf.new
