Author Topic: (SOLVED) opera browser with vpn  (Read 419 times)
Offline penrose1950
« on: October 25, 2019, 07:57:18 am »
hello i installed opera browser on my laptop running Peppermint 10 but when i clicked on vpn it tried downloading again.
does anyone know a command line way of installing opera browser with vpn please ?
thank you.
« Last Edit: November 01, 2019, 06:47:20 am by penrose1950 »
Re: opera browser with vpn
« Reply #1 on: October 26, 2019, 08:47:14 am »
You'll have to explain that a little better, Opera has a built in VPN (really more of a proxy), but I'm a bit baffled about this statement:-
Click on VPN where exactly ? .. and what exactly happened when you clicked it ?
also, what's the output from:
dpkg -l | grep operaand
cat /etc/apt/sources.list.d/opera-stable.list
« Last Edit: October 26, 2019, 08:49:21 am by PCNetSpec »
Offline penrose1950
« Reply #2 on: November 01, 2019, 06:46:28 am »
what was happening is i downloaded it and i could not see vpn so i tried downloading again.
its ok i am sticking with chromium browser.
sorry to bother everyone.
thank you.
Offline VinDSL
Re: (SOLVED) opera browser with vpn
« Reply #3 on: November 01, 2019, 07:32:23 am »
Opera is my primary browser. I love it, warts and all. I use the stable ver on my desktop; and the beta ver when following links in Thunderbird email.
Being a long-term user, I can tell you that Opera's VPN feature is rather spotty and undependable, especially since the chicoms took control of Opera. So, it isn't necessarily a prob with your install, or your hardware. Put another way, most of the time the VPN feature works; but, other times it doesn't.
Opera VPN ebbs and flows; like sitting on a shoreline, and watching waves crash on the beach.
Here's some sample CLI output, from this working machine, if it helps:
╭─vindsl@Boogaloo-6 ~
╰─$ dpkg -l | grep opera-
ii  opera-beta                                        65.0.3467.24                                amd64        Fast, secure, easy-to-use web browser
ii  opera-stable                                      64.0.3417.83                                amd64        Fast, secure, easy-to-use web browser
╰─$ sudo grep -Erh ^deb /etc/apt/sources.list* | grep opera-
deb https://deb.opera.com/opera-stable/ stable non-free #Opera Browser (final releases)
deb https://deb.opera.com/opera-beta/ stable non-free #Opera Browser (final releases)
I might also mention, to their credit, Opera is constantly being updated - sometimes, several times a week. So, just because their pseudo-VPN feature isn't working today doesn't necessarily mean it won't be working tomorrow   ;)
« Reply #4 on: November 01, 2019, 01:51:25 pm »
Now Opera just need to update their pointers to Chrome's:-
/opt/google/chrome/WidevineCdm/_platform_specific/linux_x64/libwidevinecdm.so
and include a more recent version of:-
/usr/lib/x86_64-linux-gnu/opera/libffmpeg.so
so video will work properly, including widevine DRM support :)
If you're using 64bit Peppermint:-
Run these commands in sequence:
cd /usr/lib/x86_64-linux-gnu/operathen
sudo mv -v libffmpeg.so libffmpeg.so.originalthen
sudo wget https://github.com/iteufel/nwjs-ffmpeg-prebuilt/releases/download/0.41.3/0.41.3-linux-x64.zipthen
sudo unzip 0.41.3-linux-x64.zipOkay that's libffmpeg.so sorted (so any non-DRM video should now work), now let's fix widevine DRM support.
Firstly you MUST have Google Chrome installed
Once Chrome is installed, run:
gksudo xed /usr/lib/x86_64-linux-gnu/opera/resources/widevine_config.jsonand make it read
      "preload" : "/opt/google/chrome/WidevineCdm/_platform_specific/linux_x64/libwidevinecdm.so"
      "preload" : "/opt/google/chrome/libwidevinecdm.so"
      "preload" : "/opt/google/chrome-beta/libwidevinecdm.so"
      "preload" : "/opt/google/chrome-unstable/libwidevinecdm.so"
SAVE the file and close the text editor.
Close ALL running instances of Opera   <-- this is IMPORTANT
Reopen Opera and go to
https://bitmovin.com/demos/drm
it should now say "Detected O using widevine" .. and clicking the video should make it play without error.
also, go here:
https://shaka-player-demo.appspot.com/
and see if the film "Sintel" will play, because that's widevine DRM protected ?
« Last Edit: November 01, 2019, 01:53:40 pm by PCNetSpec »
