Author Topic: Choppy Video playback on Youtube/Daily Motion or any streaming sites  (Read 2154 times)
Offline giftsonpm
Re: Choppy Video playback on Youtube/Daily Motion or any streaming sites
« Reply #15 on: November 05, 2019, 09:22:41 pm »
try the h264ify browser addon for firefox, may or may not help. id also try adding ublock origin to stop hidden stuff from loading on the sites youre trying to stream from.
Thanks Rayzer!
Unfortunately, this dint help either.
Offline giftsonpm
« Reply #16 on: November 05, 2019, 09:23:22 pm »
Are you up for trying a different version of Peppermint that has some tweaks specifically for cherrytrail CPU's ?
(may also sort out your audio)
If so, try this one
https://peppermintos.info/pm9r-testing/Peppermint-9-20190102-32bit-efi-amd64.iso
MD5: a1b0731db64976b62c23f299efcbb5cb
SHA256: 9f17afefe2ef5d1bd98d53ad0682f1f1b1edb3a3d12b8b77faeb18db3e844cb8
I know it's Peppermint 9, but if it performs well we can upgrade it to Peppermint 10 following this tutorial
https://forum.peppermintos.com/index.php/topic,8442.msg86655.html#msg86655
Thanks Mark!
I did write this iso as a bootable stick, but for some reason, it is not recognized during boot.
I had the same issue with Peppermint 10 installation, and had to disable Secure Boot.
However, the changes doesn't seem to have any effect with this image.
Mark,
Do you have any other suggestions?
Thanks!
« Reply #17 on: November 06, 2019, 06:54:40 am »
Which version of Mint worked ?
Offline giftsonpm
« Reply #18 on: November 06, 2019, 12:59:10 pm »
I believe it was Cinnamon.
The current issue I have is bootable USB is not even detected during boot.
I tried images of Peppermint 9 that you provided, in addition to Linux Lite (regular & UEFI), but none are detected.
Thanks!
« Reply #19 on: November 06, 2019, 01:04:38 pm »
No I mean which version (not the DE) .. eg. Mint 18.3
Offline giftsonpm
« Reply #20 on: November 20, 2019, 07:59:44 pm »
Hi Mark,
Apologies for the late response.
The Mint version I used is 18.3
Thank you!
« Reply #21 on: November 20, 2019, 08:06:23 pm »
Mint 18.3 was based on 16.04.3 .. and according to this
https://www.linuxmint.com/rel_sylvia_cinnamon_whatsnew.php
shippped with the 4.10 kernel series.
Maybe you should try Peppermint 9 which has the 4.15 kernel series (as opposed to Pep10's 5.0 kernel series).
If Pep9 works, you can manually upgrade it to Pep10 (but keep the 4.15 kernel) by following these instructions:
Might be worth just trying it on a LiveUSB first though.
Offline giftsonpm
« Reply #22 on: November 20, 2019, 09:12:32 pm »
Thanks Mark!
Unfortunately, as mentioned in my earlier post, bootable stick is not being recognized.
I tried with Peppermint 9 regular version as well as UEFI, but it's not recognized during boot.
In windows, I was able to do this through UEFI restart. Not sure how to enable that option in Peppermint.
Thanks again for your continued help with this.
« Reply #23 on: November 21, 2019, 11:58:48 am »
hello giftsonpm, are you using Peppermint's usb image writer to make your bootable usb sticks?
« Reply #24 on: November 21, 2019, 01:43:45 pm »
As Alynur is suggesting .. if you already have Pep10 installed
a) In Peppermint 10 use USB Stick Formatter - to format the USB stick.
b) In Peppermint 10 use USB Image Writer - to write the ISO image to the USB stick.
both USB Stick Formatter and USB Image Writer are in the main menu of Peppermint 10 (under the System category).
Offline giftsonpm
« Reply #25 on: November 21, 2019, 03:00:09 pm »
Thanks Anylur for the response.
I tried both Etcher and Rufus. Will try peppermint usb writer and see if it works.
Offline giftsonpm
« Reply #26 on: November 21, 2019, 03:00:47 pm »
Thanks Mark!
Will try it and update.
« Reply #27 on: November 21, 2019, 05:45:29 pm »
Personally I've never had those two apps fail to make a working LiveUSB .. hopefully you'll have the same experience :)
(he says, hoping he's now not jinxed the whole thing)
Offline Dyl
  • Peppermint Virgin
    • My Website
« Reply #28 on: November 26, 2019, 12:07:59 am »
was just about to post this. yes ive also had issues with pep 10 stuttering sometimes but h264ify helped.
Main PC -  i9-9900K - 32Gb RAM - NVIDIA RTX 2080
Lenovo Ideapad  - i7-7500U @ 2.70GHz -12Gb RAM - Nvidia GTX 940MX  - 15.6" HD 1920x1080
