Author Topic: Grey screen after clicking install or try live os, peppermint 10. (SOLVED)  (Read 498 times)
Offline superuser
Hello,
Newbie here in need of help. After 2 days of testing linux distros i decided to go with peppermint.
I did the following downloaded iso from offical site, used rufus first  from my windows machine then i used unetbootin from another machine,
i run always into the same problem. When i boot my usb i press escape and i select my usb.
I get : Try peppermint live os, Install pepermint os, doesnt matter which one i choose always the same result. After clicking any of those i get a grey screen and from there i cant do anything.
I tried 34bit and 64bit but still the same issue.
My laptop is asus Intel celeron cpu n2840 2.16ghz 4gb of ram.
Could someone help or did somone run into the same problem?
« Last Edit: October 21, 2019, 11:35:28 am by superuser »
Re: Grey screen after clicking install or try live os, peppermint 10.
« Reply #1 on: October 19, 2019, 08:59:04 am »
If you hit the Esc key, is there any text displayed onscreen ?
Offline superuser
« Reply #2 on: October 20, 2019, 04:21:23 am »
Sorry for late reply, been trying all kind of distros. Curently running linuxmint, Installation went without problems but i still want to install PP10.
Nothing happens when i hit any key, i tried nomodeset it doenst do anything. I just have to shut my laptop on power button cant do anything.
By the way i tried PP10 in virtualbox and it installs and runs better then almost any distro on my laptop, if that helps.
« Last Edit: October 20, 2019, 04:27:34 am by superuser »
« Reply #3 on: October 20, 2019, 04:53:13 pm »
From within Mint, can you give us the output from:
Offline superuser
« Reply #4 on: October 21, 2019, 08:34:35 am »
Could it be kernel issue maybe.
I also get black screen when booting installed version of linux mint, then i choose older kernel and it runs.
But i had no trouble booting from live usb.
« Last Edit: October 21, 2019, 08:54:05 am by superuser »
« Reply #5 on: October 21, 2019, 08:54:51 am »
a) Can you please copy/paste the terminal output AS TEXT into this forum .. pictures aren't searchable.
b) Even in your picture you have a window covering half the text :-\
« Last Edit: October 21, 2019, 09:03:23 am by PCNetSpec »
Offline superuser
« Reply #6 on: October 21, 2019, 09:01:05 am »
System:
  Host: user-X553MA Kernel: 4.15.0-54-generic x86_64 bits: 64
  Desktop: Xfce 4.12.3 Distro: Linux Mint 19.2 Tina
Machine:
  Type: Laptop System: ASUSTeK product: X553MA v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: X553MA v: 1.0 serial: <filter>
  UEFI [Legacy]: American Megatrends v: X553MA.210 date: 12/25/2014
Battery:
  ID-1: BAT0 charge: 2.7 Wh condition: 17.4/29.4 Wh (59%)
CPU:
  Topology: Dual Core model: Intel Celeron N2840 bits: 64 type: MCP
  L2 cache: 1024 KiB
  Speed: 503 MHz min/max: 500/2582 MHz Core speeds (MHz): 1: 538 2: 500
Graphics:
  Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
  driver: i915 v: kernel
  Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel Bay Trail v: 4.2 Mesa 19.0.8
Audio:
  Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
  Sound Server: ALSA v: k4.15.0-54-generic
Drives:
  Local Storage: total: 111.79 GiB used: 10.41 GiB (9.3%)
  ID-1: /dev/sda vendor: HP model: SSD M700 120GB size: 111.79 GiB
Partition:
  ID-1: / size: 108.56 GiB used: 10.41 GiB (9.6%) fs: ext4 dev: /dev/dm-0
  ID-2: swap-1 size: 976.0 MiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-1
Sensors:
  System Temperatures: cpu: 6280.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2700
Info:
  Processes: 168 Uptime: 32m Memory: 3.74 GiB used: 674.5 MiB (17.6%)
  Shell: bash inxi: 3.0.32
« Last Edit: October 21, 2019, 09:04:29 am by PCNetSpec »
« Reply #7 on: October 21, 2019, 09:03:37 am »
It certainly could be as Mint is running the 4.15 kernel from 18.04, where Peppermint 10 is running the 5.0.0 kernel from 19.04
Try Peppermint 9 instead:
https://peppermintos.com/iso/Peppermint-9-20190102-amd64.iso
then if you wish follow this tutorial to upgrade Peppermint 9 --> Peppermint 10, but keeping Peppermint 9's 4.15 kernel:
https://forum.peppermintos.com/index.php/topic,8442.msg86655.html#msg86655
Offline superuser
« Reply #8 on: October 21, 2019, 09:08:44 am »
Thats what i was afraid of, thank you for providing a link to PP9.
Offline superuser
Thanks, kernel was the issue, booted easily from usb. Gonna use PP9 for a day or two than im gonna follow the steps to upgrade to 10.
 ;) :D 8)
