Author Topic: May Switch Win7 Gaming PC to Peppermint  (Read 2240 times)
Offline Snow
« on: October 13, 2019, 06:47:59 pm »
Not sure if this is the right section as I'm beginning to collect data on my system, before I officially switch over. My system currently is a Ryzen 2200 CPU running on a Gigabyte B450M-DS3H mobo with an AMD RX570 GPU.
Right now I'm running Peppermint 10 on my little HP Stream 11 and it works flawlessly - installed with no guides, no extra drivers. It's impressively fast and full featured (for what I need). I just installed Steam on it, so I can test out Steam Play and try out some of my low-system-requirement games. My only problem with it so far, is that I can't get Dwarf Fortress running. From what I can tell, it attempts to load a specific library, but then crashes and I can't get enough info from the terminal. Plus, I'm a linux newb (perhaps n00b as well).
Back to my PC. I put it together as a budget gaming PC and according to manufacturer specs from all my components - this system would be Win7 compatible. It is - but it has been the biggest pain (and took 3 weeks) to finally get Win7 64 bit pro running on it. The OS is mostly stable atm. However, I'm still getting the odd out of the blue crash, BSOD, or startup error. I also can't use sleep mode as while it's sleeping - it horrendously crashes.
My partner keeps telling me to upgrade to Win10. I would rather chop off my hands.
On my PC if I boot up a USB image of Peppermint. It runs perfect. Of course, I still need drivers for the card. So I'm thinking I might just format the drive for the umpteenth time and install happiness. So, before I do so, does anyone have any knowledge about Peppermint running on my hardware? Any possible red flags that I might encounter? I'm also really curious about Vulkan, but know little about it at the moment.
Thank you for your time and I appreciate any responses. :)
-Snow
Re: May Switch Win7 Gaming PC to Peppermint
« Reply #1 on: October 16, 2019, 02:26:57 pm »
I can't say for sure how that would run as I don't have any of the same hardware, I gather that graphics card will work with either the built in amdgpu or the downloadable amdgpu-pro, but 'how well' is anyones guess.
Maybe try Linux out on a LiveUSB first.
