Author Topic: P10 no option to dual boot (SOLVED)  (Read 1077 times)
Offline kloos
  • Fairly new at Linux
« on: October 10, 2019, 10:52:26 am »
Hi there,
I see a post re P9 for this, but it's quite old (https://forum.peppermintos.com/index.php?action=post;topic=7166.0;last_msg=73432)
Here is the output as requested from that post in the hope that you  can diagnose my issue of not having the option
sudo fdisk -l
Disk /dev/loop0: 1.4 GiB, 1472348160 bytes, 2875680 sectors
Disk /dev/sda: 465.8 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: dos
Disk identifier: 0x3833069c
Device     Boot   Start       End   Sectors   Size Id Type
/dev/sda1  *       2048   1126399   1124352   549M  7 HPFS/NTFS/exFAT
/dev/sda2       1126400 976771071 975644672 465.2G  7 HPFS/NTFS/exFAT
Disk /dev/sdb: 58.6 GiB, 62914560000 bytes, 122880000 sectors
Disklabel type: dos
Disk identifier: 0x0434560d
/dev/sdb1  *     2048 122879999 122877952 58.6G  c W95 FAT32 (LBA)
Disk /dev/zram0: 985.3 MiB, 1033150464 bytes, 252234 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
Disk /dev/zram1: 985.3 MiB, 1033150464 bytes, 252234 sectors
Disk /dev/zram2: 985.3 MiB, 1033150464 bytes, 252234 sectors
Disk /dev/zram3: 985.3 MiB, 1033150464 bytes, 252234 sectors
and sudo blkid
/dev/sda1: LABEL="System Reserved" UUID="C8625F27625F1A10" TYPE="ntfs" PARTUUID="3833069c-01"
/dev/sda2: UUID="6AF06352F0632413" TYPE="ntfs" PARTUUID="3833069c-02"
/dev/sdb1: LABEL="PEPPERMINT" UUID="191E-2C28" TYPE="vfat" PARTUUID="0434560d-01"
/dev/loop0: TYPE="squashfs"
/dev/zram0: UUID="49f3acfb-e432-465c-a85a-d5857db6cc04" TYPE="swap"
/dev/zram1: UUID="c20215d0-205e-409e-a229-eae0a151c27e" TYPE="swap"
/dev/zram2: UUID="2a463a25-5160-436a-ba60-1de379690192" TYPE="swap"
/dev/zram3: UUID="b0534acf-7c84-4cb3-ada9-89f42cd3352e" TYPE="swap"
Thanks
« Last Edit: October 27, 2019, 10:28:46 am by kloos »
Re: P10 no option to dual boot
« Reply #1 on: October 10, 2019, 01:31:50 pm »
Am I right in thinking ONLY Windows is installed to your hard drive .. and you're running Peppermint from a LiveUSB stick ?
If so, I'm not quite understanding the question .. if you only have one OS installed, where are you expecting a dual boot option ?
Or are you saying the installer isn't offering you the option to "Install alongside Windows" ?
« Last Edit: October 10, 2019, 01:35:52 pm by PCNetSpec »
Offline kloos
« Reply #2 on: October 10, 2019, 02:10:45 pm »
Sorry, I meant that whilst trying to install a new installation along side of an existing windows 10 there is no option to dual boot. At the moment there is just windows 10 and nothing else.  And yes I am booting from a USB.
« Last Edit: October 10, 2019, 02:12:29 pm by kloos »
« Reply #3 on: October 10, 2019, 02:35:56 pm »
From the LiveUSB, what's the output from:
inxi -Fzand when you say:-
I take it there's an option labelled "Something Else" ?
Offline kloos
« Reply #4 on: October 10, 2019, 02:57:40 pm »
Based on your recommendation (I asked for advice on a new laptop a few weeks ago), not quite the specs you suggested (i5 rather than i7) but for 80 quid you can't go wrong!
System:    Host: peppermint Kernel: 4.18.0-18-generic x86_64 bits: 64 Desktop: N/A
           Distro: Peppermint Ten
Machine:   Device: laptop System: Dell product: Latitude E6430 v: 01 serial: N/A
           Mobo: Dell model: 0CPWYR v: A00 serial: N/A
           BIOS: Dell v: A17 date: 08/19/2015
Battery    BAT0: charge: 34.0 Wh 96.2% condition: 35.3/62.2 Wh (57%)
CPU:       Dual core Intel Core i5-3340M (-MT-MCP-) cache: 3072 KB
           clock speeds: max: 3400 MHz 1: 1196 MHz 2: 1196 MHz 3: 1197 MHz
           4: 1196 MHz
Graphics:  Card: Intel 3rd Gen Core processor Graphics Controller
           Resolution: 1366x768@60.01hz
           OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile
           version: 4.2 Mesa 18.2.8
Audio:     Card Intel 7 Series/C216 Family High Def. Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.18.0-18-generic
Network:   Card-1: Intel 82579LM Gigabit Network Connection (Lewisville)
           driver: e1000e
           Card-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
Drives:    HDD Total Size: 563.0GB (1.0% used)
           ID-1: /dev/sda model: HGST_HTS545050A7 size: 500.1GB
           ID-2: USB /dev/sdb model: USB_DISK size: 62.9GB
Partition: ID-1: / size: 3.9G used: 55M (2%) fs: overlay dev: N/A
           ID-2: swap-1 size: 1.03GB used: 0.00GB (0%) fs: swap dev: /dev/zram0
           ID-3: swap-2 size: 1.03GB used: 0.00GB (0%) fs: swap dev: /dev/zram1
           ID-4: swap-3 size: 1.03GB used: 0.00GB (0%) fs: swap dev: /dev/zram2
           ID-5: swap-4 size: 1.03GB used: 0.00GB (0%) fs: swap dev: /dev/zram3
Sensors:   System Temperatures: cpu: 47.0C mobo: N/A
Info:      Processes: 207 Uptime: 2 min Memory: 702.2/7882.3MB
« Reply #5 on: October 10, 2019, 04:08:14 pm »
Hmm, okay it should work on that :)
Is the BIOS set to boot efi or legacy BIOS ?
(I'm gonna bet legacy BIOS as there doesn't appear to be an ESP partition)
Is it Win10 Pro or Home ? .. and have you extracted the Win10 installation key yet (in case you need to reinstall Windows without charge at any point) ?
My point is, we can try shrinking the Windows partition from within Windows .. then install Peppermint in the free space (manually specifying the partitions if necessary) .. but it'd still be a VERY good idea to have your Windows 10 key written down somewhere in case anything goes wrong and you need to be able to download Win10 and reinstall without having to pay.
I can tell you how to extract your Windows 10 key with Produkey if you need ?
https://www.nirsoft.net/utils/product_cd_key_viewer.html
« Last Edit: October 10, 2019, 04:14:29 pm by PCNetSpec »
Offline VinDSL
« Reply #6 on: October 10, 2019, 09:43:46 pm »
Good choice!
Dell Latitude E6430 FTW   8)
Offline kloos
« Reply #7 on: October 11, 2019, 12:54:26 am »
thanks guys.  As always, top advice.  I'm gonna be offline for a few days so will feedback again after next Wednesday.  Have a great weekend and speak next week  :P
« Reply #8 on: October 22, 2019, 08:40:12 am »
Hi kloos, As PCNetSpec mentioned, run a defrag in Windows and shrink the Windows partition, I would shrink it drastically, then boot up the Peppermint live session and go into Gparted and reformat the empty space you made to ext4. You can then install using "Something else" as the installation method and install the boot(/) into the new partition. Don't forget to install the bootloader into the harddrive, it should already be selected but make sure.
Offline kloos
« Reply #9 on: October 27, 2019, 12:33:36 am »
Hi there,
I have now split the harddrive into two main partitions, one for W10 and the other is unallocated.  When I try to install Peppermint it does now give me an option to install alongside.  Before I chose that I need to know whether that will use the unallocated partition or whether it will create a 3rd partition.
On the install, if I select other option and try to manually select the unallocated, it asks me to format it.  When I go into GParted app the format is greyed out so I can't seem to do this.
What do I do next?
« Reply #10 on: October 27, 2019, 05:54:23 am »
1)   "Install alongside" will use unallocated space with no partition in it.
2)   No, "something else" can be used to create partitions or format existing partitions. Don't use the "something else" option unless you understand how to do this.
Offline kloos
« Reply #11 on: October 27, 2019, 06:06:56 am »
Thanks MurrayMint
So the Windows partition tool tells me that it is Unallocated.  I created it in Windows by shrinking the main partition but I have done nothing with the space since.  Does this mean that I am safe to 'install alongside' and it will use this unallocated bit of the drive?
« Reply #12 on: October 27, 2019, 07:46:34 am »
Yes, that should work fine. The partition is created automatically for you, using all of the free space.
Offline kloos
« Reply #13 on: October 27, 2019, 10:28:22 am »
aaaaaand relax... Peppermint installed and working fine, thanks to everyone for your help.  Top notch as always :D
