Author Topic: ERROR message? SOLVED Sort of  (Read 584 times)
Offline windrose
  • Peppermint version(s): PM 10
« on: September 24, 2019, 10:06:10 am »
Good day all,
I have an old tower desk top l have been playing with and had decided to load it with LM but it is not capable of handling the OS so l had looked into other distros and came upon PEPPERMINT and it looked very nice.
I just downloaded the latest version (?) and verified it, burned it onto a dvd and attempted to load it. I have tried running live and a full install but am receiving a message on the screen (error?) as follows:
[    3.182299] sis630_smbus 0000:00:02:0: SIS630 compatible bus not detected, module not inserted.
Now this has me totally stumped...l am just an amateur computer geek and relatively new to Linux Mint
There is nothing on this computer worth salvaging so l can do whatever it needs to try to get it up and running...it has Pentium 4 , 2.66Ghz CPU , 8kb with 512 kb ram.
Thanks
Dave
« Last Edit: September 27, 2019, 12:43:36 pm by windrose »
Re: ERROR message?
« Reply #1 on: September 24, 2019, 10:49:27 am »
Does it finish booting or not ?
Offline windrose
Re: ERROR message?
« Reply #2 on: September 24, 2019, 11:26:22 am »
Sorry l took so long to reply but l only just realized l had to log in to reply to posts..l was going dulali trying to find "reply"
Short answer..no it does not boot...l only get to the menu page where l can select my choice of Live, Boot, Check disc etc
D
Re: ERROR message?
« Reply #3 on: September 24, 2019, 11:40:34 am »
But Mint does boot ?
If so, which version ?
Offline windrose
Re: ERROR message?
« Reply #4 on: September 24, 2019, 12:01:49 pm »
There is no version number displayed on the start up screen but l had literally downloaded it off the site earlier today.
Offline windrose
Re: ERROR message?
« Reply #5 on: September 24, 2019, 12:04:22 pm »
Peppermint 10 32 bit
Offline windrose
Re: ERROR message?
« Reply #6 on: September 24, 2019, 12:06:28 pm »
I had tried an older Linux Mint 17 32 bit but could not load it all so ran it Live but as l said would not boot from the HD
Re: ERROR message?
« Reply #7 on: September 24, 2019, 12:10:21 pm »
Maybe try Peppermint 8 32bit then, which is based on the same 16.04 code base as LM17 .. because I think you'll struggle with that SiS chipset on recent distros (SiS hasn't been supported for some time now).
https://peppermintos.com/iso/Peppermint-8-20180203-i386.iso
md5sum: f20531e392018bb5ebb13adae0e7fa79
All previous Peppermint versions:
https://peppermintos.com/previous/
Offline windrose
Re: ERROR message?
« Reply #8 on: September 24, 2019, 01:59:20 pm »
well it looked promising got to the menu selected live and went from a dark screen to a grey one but this time there was no error message but still did not boot..l tried all...install, OEM install and live no difference. L just cleaned windows XP off it so it was running fine yesterday???
Offline windrose
Re: ERROR message? SOLVED!
« Reply #9 on: September 26, 2019, 11:53:32 am »
Just spent the morning disassembling  the old tower..parts are now in plastic bags hoping l may find someone needing a part l have rather than placing in landfill. Thanks for the suggestions!
