Author Topic: Printer works on Peppermint 9, not on Peppermint 10 (SOLVED)  (Read 523 times)
Offline jozefmw
« on: September 21, 2019, 03:23:43 pm »
Printer works on Peppermint 9, not on Pepper4mint 10, although I get the meddage: Printer installed, does not show up under Printers.
It is about the Lexmark CS 417 dn: Driver  to be found on:
https://www.freeprinterdriverdownload.org/lexmark-cs417dn-printer-driver-download-for-windows-10-8-7-server-linux-mac/
 Lexmark-AD2-PPD-Files-1.0-02242017.amd64.deb
« Last Edit: October 19, 2019, 01:22:26 pm by jozefmw »
Re: Printer works on Peppermint 9, not on Pepper4mint 10
« Reply #1 on: September 21, 2019, 03:41:05 pm »
Does it show up in the CUPS web interface
http://localhost:631/admin
if you click "Find New Printers" ?
Offline jozefmw
« Reply #2 on: September 22, 2019, 10:44:33 am »
Does not show up there ...
« Reply #3 on: September 22, 2019, 02:03:34 pm »
Is this a network printer?
n/m
I see that last time the problem was a "defective cable",e.g. a printer cable  ;)
« Last Edit: September 22, 2019, 02:10:03 pm by VinDSL »
Offline windrose
  • Peppermint version(s): PM 10
« Reply #4 on: September 30, 2019, 08:36:22 am »
I am amazed how well PM 10 is it found my computer like they were old friends Brother 2740 all in one laser.
Offline jozefmw
« Reply #5 on: October 16, 2019, 02:39:28 pm »
Had to be a while abroad. Just back and installed Peppermint 10 anew.(this time verified) and again the printer driver won't work. Does work under windows and still works under Peppermint 9 on another laptop.
Re: Printer works on Peppermint 9, not on Peppermint 10
« Reply #6 on: October 19, 2019, 11:53:37 am »
Why not install Peppermint 9, then follow this tutorial to upgrade PM9 --> PM10 but without the newer kernel and xorg stack from the hwe-18.04 (hardware enablement stack) .. which is likely where the problem lies.
https://forum.peppermintos.com/index.php/topic,8442.msg86655.html#msg86655
Basically you'd end up with Peppermint 10, but with Peppermint 9's kernel and xorg stack (ie. the kernel and xorg stack from the original 18.04 which both PM9 and PM10 are based on instead of the updated ones from 19.04).
« Last Edit: October 19, 2019, 11:57:25 am by PCNetSpec »
Offline jozefmw
« Reply #7 on: October 19, 2019, 01:21:54 pm »
I am happy with this proposal, as I can use it on two other laptops running on Peppermint 9.
Thank you.
