Author Topic: Arduino serial port problem  (Read 417 times)
Offline mick
  • Recovering Apple Addict
« on: September 13, 2019, 07:18:25 pm »
My son's Arduino won't connect on peppermint.  It is my understanding that it is a common Linux problem that can be fixed, but I can't understand how. Upon opening the Arduino IDE reads "java.lang.NullPointerException thrown while loading gnu.io.RXTXCommDriver"
what do i do? please use small words :)
thanks in advance.
Re: Arduino serial port problem
« Reply #1 on: September 29, 2019, 09:27:35 am »
Hi mick, I had that problem and solved it by installing java 8, let me try and find that information for you but you can do a duckduckgo search for java 8 and download the deb file.
« Reply #2 on: September 29, 2019, 10:04:12 am »
Hi mick, okay it's not a deb file download, check this site out for how to install java 8 in ubuntu 18,04
https://computingforgeeks.com/how-to-install-java-8-on-ubuntu/.
