Author Topic: Start an application on a specific workspace (with Python 3)  (Read 945 times)
Offline Fritz74
  • m, 46, Austria
« on: September 11, 2019, 01:17:11 pm »
I want my terminal to start on workspace 3. This can be achieved with the app wmctrl - which is complicated.
There is an easier way with Python. I am using Python 3.
First install pip, the Python package manager:
sudo apt install python3-pip
Then use pip to install pyautogui. This is a library that lets Python perform mouseclicks, keystrokes etc.
sudo pip install pyautogui
I want Python to click on the workspace switcher in my Xfce panel. To get the coordinates, I make a screenshot and open Gimp. If I move the cursor over the image, Gimp shows me the coordinates. On my desktop, a click on 1569/1056 will open workspace 3.
The script that clicks on workspace 3 gets the name clickonworkspace3.py:
#!/usr/bin/env python3
import pyautogui
pyautogui.click(1569,1056)
This can be used in shell scripts, whenever I want them to click on workspace 3.
The script gets the name sakuraonworkspace3.sh:
python3 clickonworkspace3.py
sakura
Make them executable with sudo chmod +x clickonworkspace3.py and sudo chmod +x sakuraonworkspace3.sh
Running the script sakuraonworkspace3.sh now opens the terminal Sakura on workspace 3.
Finally, put a starter that opens the script sakuraonworkspace3.sh into the Xfce panel.
« Last Edit: September 22, 2019, 08:10:51 am by Fritz74 »
Re: Start an application on a specific workspace (with Python 3)
« Reply #1 on: September 11, 2019, 01:42:01 pm »
Nice, thanks for that .. the pyautogui module is new to me, gonna need to look into this :)
https://pyautogui.readthedocs.io/en/latest/
« Last Edit: September 11, 2019, 01:44:11 pm by PCNetSpec »
Offline Fritz74
  • m, 46, Austria
« Reply #2 on: September 13, 2019, 05:59:05 am »
It is magic. ;) Some people use it for tasks that require doing the same thing on a desktop over and over again (for example uploading a lot of stuff).
« Last Edit: September 13, 2019, 06:38:36 am by Fritz74 »
