Author Topic: install tar.gz  (Read 158 times)
Offline maxiam
install tar.gz
« on: September 03, 2019, 12:32:34 am »
from new user, how do i install a tar.gz . I have downloaded and extracted the tar.gz file. the sudo make install command as i understand needs an executable file? How do I find that in the directory, thanks? :(
Re: install tar.gz
« Reply #1 on: September 03, 2019, 06:46:54 am »
No, if you've extracted it, cd into the folder you extracted to and then run the commands in your instructions.
Offline clatterfordslim
Re: install tar.gz
« Reply #2 on: September 03, 2019, 01:16:49 pm »
Hello maxiam, Open Terminal with
Ctrl+Alt+T
Then you need to type
cd Downloads
Push enter That has changed directory to your Downloads folder
Next type
ls
ls is short for list if you like and lists everything in that particular directory or folder
Next we need to see if there is a install file
cd name of file after you extracted
You said that you had already extracted the file, so once you have changed directory into it, as that is what cd command means.
We then type ls again and that lists everything in this folder.
If there is a install it would be something like systemback.sh
Below is a screenshot of me installing Systemback via Terminal.
Here is the extracted file of Systemback in Downloads.
Here in Terminal
Changed to Downloads folder
Now showing ls command
We now need to cd into the correct file, in this case systemback the one I extracted earlier.
Then push enter
We then type ls again and push enter
The
install.sh
is the one we need.
We then type
Pushing enter gave me this, but 16.04 is the version that works in 18.04
So I pick number 4.
After two seconds or maybe at least ten it's installed
I know your file maybe different, but it should inside it's folder include a read me file, giving instructions of how to install.
I hope this has helped a little?  ;D
« Last Edit: September 03, 2019, 01:22:11 pm by clatterfordslim »
But so is this Forum :)
