Author Topic: install VS Code (SOLVED)  (Read 258 times)
Offline maxiam
« on: August 26, 2019, 05:18:03 am »
I am trying to install VSCode to run Go-Lang.
As far as I can figure out, The config file .bashrc needs to be modified by adding
export GOPATH=$Home/go/GoCode
This is the path to the go workspace, as the go directory contains the install files, so I created this one :)This dosent work and VSCode gives me errors when running it. I have installed theMS go extention on VSCode. Can somebody pls help , thanks
« Last Edit: September 03, 2019, 07:31:46 pm by PCNetSpec, Reason: marked as (SOLVED) »
Re: install VS Code
« Reply #1 on: August 26, 2019, 08:54:17 am »
Hi maxiam,
It looks like you made a mistake in the line you added to the .bashrc file. Linux is case-sensitive so try modifying the line to look like this:
export GOPATH=$HOME/go/GoCode
because the variable $Home does not exist, but $HOME does (it looks somethings like /home/maxiam). To see its actual current value open a terminal and enter this:
echo $HOME
and press the ENTER key. Doing the same for this:
echo $Home
should not return anything.  ;)
Online PCNetSpec
Re: install VS Code
« Reply #2 on: August 26, 2019, 09:40:17 am »
Yeah as Slim.Fatz points out
$HOME is an environment variable equal to /home/<username> .. so $HOME/go/GoCode is the equivalent of /home/<username>/go/GoCode
Remember, case sensitivity **IS** important in Linux, so $Home is NOT the same as $HOME .. in fact $Home doesn't exists as an environment variable.
So..
You could either make the line read
or drop the environment variable altogether and specify the full path
export GOPATH=/home/<username>/go/GoCode
(obviously replacing <username> with your ACTUAL username.)
FYI...
(and hopefully not muddying the waters further)
Another option would be to use the $USER variable to set the username in the path, so
export GOPATH=/home/$USER/go/GoCode
should also work.
« Last Edit: August 26, 2019, 09:53:15 am by PCNetSpec »
Offline maxiam
Re: install VS Code
« Reply #3 on: August 27, 2019, 01:34:37 am »
Thank you for this.
Do I need to add anything else, such as PATH= or something. I have shown the echo $PATH as it exists benith., noticing that the /bin directory is referenced in the /go and in the /gocode directories.  Can I just add these lines to the bottom of the /.bashrc file? My g/gocode dir is actually /GoCode.
Andrew
o@ao-HP-ENVY-m6-Notebook-PC ~ $ echo $PATH
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/ao/gocode/bin:/home/ao/go/bin
ao@ao-HP-ENVY-m6-Notebook-PC ~ $
[/size][/size][/size]
Online PCNetSpec
Re: install VS Code
« Reply #4 on: August 27, 2019, 03:22:38 pm »
It's hard for us to say what you should do as we're not 100% sure what the goal is ?
adding:
to ~/.bashrc will add an environment variable to the terminal called $GOPATH which points at /home/ao/go/GoCode
you can test this by running
xed ~/.bashrc
and adding this line at the bottom
Now back in a NEW terminal run:
echo $GOPATH
and you should get
/home/ao/go/GoCode
Now what we can't tell you is if that's the correct directory path to the Go code as we don't know where you put it.
Offline maxiam
Re: install VS Code
« Reply #5 on: September 02, 2019, 11:50:05 pm »
Thanks for the help, how di I mark this as solve?
Online PCNetSpec
Re: install VS Code
« Reply #6 on: September 03, 2019, 07:30:50 pm »
Edit the FIRST posting in your topic, and append (SOLVED) to the subject line .. so for example in this topic, edit the FIRST posting and change
Subject: install VS Code (SOLVED)
I've done this one for you :)
