Author Topic: Lockscreen Suddenly Changing (SOLVED)  (Read 453 times)
Online PCNetSpec
Re: Lockscreen Suddenly Changing
« Reply #15 on: August 31, 2019, 12:45:00 pm »
Okay the suckless-tools package contains 'slock' which takes priority over i3lock in the in the screenlock script (/usr/bin/lxlock), so....
Uninstall suckless-tools and the screensaver should work again:
sudo apt-get remove --purge suckless-tools
if for some reason you cannot uninstall suckless-tools (maybe because something else you have installed depends on it), instead run:
gksudo xed /usr/bin/lxlock
and comment out these 2 lines
elif which slock >/dev/null; then
    slock &
so they now read
# elif which slock >/dev/null; then
#     slock &
SAVE the file .. and now test the screenlock
« Last Edit: August 31, 2019, 01:12:26 pm by PCNetSpec »
Offline completeidiot
« Reply #16 on: August 31, 2019, 02:26:53 pm »
Suckless tools sucked for me, but now they're gone.
Thank you.
Online PCNetSpec
Re: Lockscreen Suddenly Changing (SOLVED)
« Reply #17 on: September 01, 2019, 04:42:58 pm »
You're welcome .. thanks for marking the topic solved :)
