Author Topic: Mouse cursor [SOLVED]  (Read 401 times)
Offline Crippled
« on: August 24, 2019, 04:24:47 pm »
I just installed Peppermint and the mouse cursor is tiny. This is the first Linux distro that I can't find a way to to adjust the size of the mouse cursor through the use of the G.U.I. I looked in the Peppermint manual and returned no results in the search. I searched the Peppermint forum and could only find command line which I don't understand. How do I adjust the mouse cursor size using only the G.U.I.?
« Last Edit: August 24, 2019, 07:22:03 pm by Crippled »
I am command line illiterate. I am a copy & paste command line user.
Offline VinDSL
Re: Mouse cursor
« Reply #1 on: August 24, 2019, 05:03:07 pm »
Welcome aboard, Crippled  :)
Doing a quick search, I found this, in an old thread: https://is.gd/GWeHXd
Might give it a whirl...
Offline Crippled
Re: Mouse cursor
« Reply #2 on: August 24, 2019, 05:27:34 pm »
Thank you for trying. I found the same thing, but nothing about a G.U.I. way to adjust it's size so I can understand. It looks like all gibberish.
Re: Mouse cursor
« Reply #3 on: August 24, 2019, 07:15:19 pm »
Try this...
Run:
sudo xed ~/.config/lxsession/Peppermint/desktop.conf
find the line that currently reads
iGtk/CursorThemeSize=18
and change it to say
iGtk/CursorThemeSize=36
or maybe even
iGtk/CursorThemeSize=72
or any other size you wish.
then SAVE the file .. the cursor should change as soon as you click 'Save'.
Offline Crippled
Re: Mouse cursor
« Reply #4 on: August 24, 2019, 07:21:10 pm »
Try this...
Run:
or maybe even
  It's not the way it needs to be done in 2019, but it worked. Thank you very much.
Re: Mouse cursor [SOLVED]
« Reply #5 on: August 24, 2019, 07:25:08 pm »
Now you've brought it up, I'll see about writing a little GUI utility to change cursor size in the PM10 Respin
BTW, (even though I love Ghost 67's poetic style) can you please remove the video link from your signature, it kinda looks a mess when it's in every post you make so repeated multiple times on a forum page .. TIA :)
« Last Edit: August 24, 2019, 07:32:38 pm by PCNetSpec »
